jrock4224 Posted January 26, 2015 Report Share Posted January 26, 2015 nice looking good for my car...lol 1 Quote Link to comment
Draker Posted January 26, 2015 Author Report Share Posted January 26, 2015 Got the valves and cam in, but then I ran out of time. Still need to install the rockers and get it all setup. Quote Link to comment
Busta Nut Posted January 30, 2015 Report Share Posted January 30, 2015 Here you are....damn I'm slow sometimes..... Just so you know...... I know this ain't Oregon.... .....but MY cost for a complete head job could hit $375...if valve's need replacing.... ............but I live in a place where money doesn't mean much to people..... Sucks for people like me...... Keep it up dude!! See ya soon B) 1 Quote Link to comment
banzai510(hainz) Posted January 30, 2015 Report Share Posted January 30, 2015 post #124 You should hook B of mactchbox(assume its the red wire) to the blk/ white wire(keyON) on the ballast as this will give the box a true 12/14volts. Since you still using the point coil and ballast the + side coil is only like 6--9 volts when running as the ballast is cutting the current. might run better this way Quote Link to comment
Draker Posted January 31, 2015 Author Report Share Posted January 31, 2015 post #124 You should hook B of mactchbox(assume its the red wire) to the blk/ white wire(keyON) on the ballast as this will give the box a true 12/14volts. Since you still using the point coil and ballast the + side coil is only like 6--9 volts when running as the ballast is cutting the current. might run better this way Actually, The ballast is bypassed. I bridged it with a hidden wire on the bottom side and the coil is for the matchbox. I should probably just remove the ballast so it doesn't confuse people, but I was leaving for aesthetics. Its more confusing than anything though. I have been running into issues getting it to run right though. It stumbles.. and idles like shit. It's either the shit carbs.. and/or the dizzy setup. Thanks for the tip though. I'll probably just remove the ballast. Quote Link to comment
Draker Posted January 31, 2015 Author Report Share Posted January 31, 2015 Here you are....damn I'm slow sometimes..... Just so you know...... I know this ain't Oregon.... .....but MY cost for a complete head job could hit $375...if valve's need replacing.... ............but I live in a place where money doesn't mean much to people..... Sucks for people like me...... Keep it up dude!! See ya soon B) If I added valves these fools probably would want over $500.. lol crazy talk. I'm gonna run it, and if issues come up, I'll pop the head off. This was a running engine before I tore it down.. I just wanted to inspect and refresh it. Plus it was dirty as fuck. Can't have that. 1 Quote Link to comment
banzai510(hainz) Posted January 31, 2015 Report Share Posted January 31, 2015 yeah long as its a EI coil and the B is to plus with the blk wht (ON) wire. sometime people hook the HOT start(blk/blu) wire up also to this to have 3 connections. and Blk to C that's all. make sure the dist shaft isn't worn. I had this happen to a Point dizz with pertronix and at high end it would cut out. find out bushing was worn swapped another dizzy with same Pertronix was a whiole new car. I alwsy ck the valve lash also then if sideddrafts ck my jets and venturis for wiggle down draft I guess for vaccume leaks also had a dizzy were the weights flew off the springs. so maybe a pull to spin it would be EZ to do also Quote Link to comment
Draker Posted February 1, 2015 Author Report Share Posted February 1, 2015 yeah long as its a EI coil and the B is to plus with the blk wht (ON) wire. sometime people hook the HOT start(blk/blu) wire up also to this to have 3 connections. and Blk to C that's all. make sure the dist shaft isn't worn. I had this happen to a Point dizz with pertronix and at high end it would cut out. find out bushing was worn swapped another dizzy with same Pertronix was a whiole new car. I alwsy ck the valve lash also then if sideddrafts ck my jets and venturis for wiggle down draft I guess for vaccume leaks also had a dizzy were the weights flew off the springs. so maybe a pull to spin it would be EZ to do also I actually swapped the Dizzy out for another one I had. Same issue :( I've had it running good a few times. None of those times were with the SU's though. I have a hunch one of the needles are bent. Probably looking at new needles and seats sometime soon if I want to run these carbs. Quote Link to comment
Janksun Posted February 9, 2015 Report Share Posted February 9, 2015 Damn those seats look good..... 1 Quote Link to comment
Draker Posted February 9, 2015 Author Report Share Posted February 9, 2015 Damn those seats look good..... thanks, I just got finished putting new skins on them. 1 Quote Link to comment
Anonymous Waffle Posted March 2, 2015 Report Share Posted March 2, 2015 ^ I thought 68's and 69's came with a bumper license plate light, or is that only a 68 thing? Quote Link to comment
Draker Posted March 2, 2015 Author Report Share Posted March 2, 2015 ^ I thought 68's and 69's came with a bumper license plate light, or is that only a 68 thing? 68 only. :) 3 Quote Link to comment
Anonymous Waffle Posted March 2, 2015 Report Share Posted March 2, 2015 68 only. :) Ah alright, good to know ^_^ Quote Link to comment
jrock4224 Posted March 4, 2015 Report Share Posted March 4, 2015 that blue car ahd a quarter put on like this .. i wished i knew before hans and his friend did filler work on it .. it blew the fuck up ...something about mechanics doing body work and not asking me then wet sanding bondo...never wet sand bondo ... EVER 1 Quote Link to comment
jrock4224 Posted March 4, 2015 Report Share Posted March 4, 2015 this is my car too by theway 2 Quote Link to comment
Draker Posted March 8, 2015 Author Report Share Posted March 8, 2015 No real updates. Swapped Weber carb on.. still runs like turds. Took a better picture of the welds above. Quote Link to comment
Draker Posted March 8, 2015 Author Report Share Posted March 8, 2015 I've checked the timing, swapped dizzy's, swapped spark plug wires.. I got video of it running with a vacuum gauge on it. Will post when it finishes uploading. It's wack.. and I'm not 100% that the exhaust isn't kinda clogged either. I know for sure there were rats up in that business at one point. Quote Link to comment
Draker Posted March 8, 2015 Author Report Share Posted March 8, 2015 My thoughts.. timing is fucked.. but I've confirmed it's fine. Massive vacuum leak somewhere, I checked around the manifold and base of the carb with propane, no change in idle at all. ?? Quote Link to comment
Atomic Posted March 8, 2015 Report Share Posted March 8, 2015 Take the intake manifold off? Quote Link to comment
Draker Posted March 8, 2015 Author Report Share Posted March 8, 2015 Take the intake manifold off? Why? Suspecting leaks at the head? Quote Link to comment
mrbigtanker Posted March 8, 2015 Report Share Posted March 8, 2015 If you need a bumper light check crags list in los angeles, search datsun and it will come up. If you need it. :thumbup: 1 Quote Link to comment
