Draker Posted November 11, 2017 Author Report Share Posted November 11, 2017 Got a little something from our friends across the pond. Will need for when the entire car is painted. I've put a few of the gaskets on already. 3 Quote Link to comment
Draker Posted November 23, 2017 Author Report Share Posted November 23, 2017 Pics fixed through page 8 1 Quote Link to comment
Draker Posted January 19, 2018 Author Report Share Posted January 19, 2018 After the run up to the Sonic meet, I noticed my alternator making noise. Shut it off and hit it with the temp gun.. it was really hot. So I bought a new one. Saturn CS130. Also engine temps stay low about 140F when on the highway. I can feel it's affecting the carb performance.. so I got a new thermostat. Also picked up some stainless hardware for the camber plates. Trying to clean it up a little bit.. but the paint chips aren't helping... 6 Quote Link to comment
Draker Posted January 23, 2018 Author Report Share Posted January 23, 2018 Got the old GM alternator out, and swapped in the new alternator. I thought I bought the same alternator, which would have made the swap really easy.. turns out it was completely different. Had to redo the top and bottom mounts. Pics will be soon.. should have taken them as I was swapping.. wtf. 1 Quote Link to comment
hobospyder Posted January 23, 2018 Report Share Posted January 23, 2018 I'm gonna start a new thread in project Dayton I think, just doing time lapse video of when I'm in the shop now 3 Quote Link to comment
Draker Posted January 24, 2018 Author Report Share Posted January 24, 2018 I thought my rear main was leaking.. but after getting intimate with the alternator it appears to be the oil pan gasket, again. I tightened the bolts just a little bit to see if it would stop. I'm guessing it's the same or worse now. Meh. 1 Quote Link to comment
Draker Posted January 26, 2018 Author Report Share Posted January 26, 2018 Found a local datsun for sale in craigslist. Had a dealer datsun ate on it. On a whim emailed him to see if he would part with just the plate. Turns out we made a deal. Kendall was our dealer in Eugene. 5 Quote Link to comment
Draker Posted January 26, 2018 Author Report Share Posted January 26, 2018 Still looking for beverton datsun frames. That's where the car was originally sold. 1 Quote Link to comment
Draker Posted February 19, 2018 Author Report Share Posted February 19, 2018 Been thinking about getting some new wheels... maybe equip 03s. 3 Quote Link to comment
HOGIE Posted February 19, 2018 Report Share Posted February 19, 2018 Found a local datsun for sale in craigslist. Had a dealer datsun ate on it. On a whim emailed him to see if he would part with just the plate. Turns out we made a deal. Kendall was our dealer in Eugene. Score. I’ve only seen plastic ones on 210’s 1 Quote Link to comment
Mattndew76 Posted February 19, 2018 Report Share Posted February 19, 2018 I thought it was Hutchins Nissan / Datsun in Springfield? 1 Quote Link to comment
Draker Posted February 19, 2018 Author Report Share Posted February 19, 2018 I thought it was Hutchins Nissan / Datsun in Springfield? I've heard of that too. The person I had install my windshield (in JC) used to work at Kendall Datsun back in the day. 1 Quote Link to comment
Draker Posted March 7, 2018 Author Report Share Posted March 7, 2018 Weekend report.. pulled donor crossmember to clean up and modify. Adding byrons brackets and opening up the exhaust port. 4 Quote Link to comment
Draker Posted March 28, 2018 Author Report Share Posted March 28, 2018 Make a hole Make a round thing out of a flat thing Stick it in the hole and weld it. Mock them up Clamp it down Weld it up 4 Quote Link to comment
Draker Posted April 1, 2018 Author Report Share Posted April 1, 2018 Finished, time to install. 4 Quote Link to comment
Draker Posted April 24, 2018 Author Report Share Posted April 24, 2018 Out with the old Removing rake Lower. 5 Quote Link to comment
Draker Posted April 24, 2018 Author Report Share Posted April 24, 2018 I still need to set the rear camber and toe a bit. Then may have to lower it a bit more in the rear. I could always raise the front a 1/2" or so to even it out. We'll see.. Alignment coming soon once I get the height figured out. 2 Quote Link to comment
KoHeartsGPA Posted April 25, 2018 Report Share Posted April 25, 2018 Just.how.low.do.you.want.to.go? :lol: 1 Quote Link to comment
Draker Posted April 25, 2018 Author Report Share Posted April 25, 2018 I'm already feeling the pain of the hunt for lows. Wheels are 15s and making getting low without crazy camber hard. I cut the bump stops tonight. Still pretty excessive rake. Front coils at max height. Would need to remove spit collars and raise perch about 2 inches and weld in place. That would allow a wide range of adjustment.. or I could get longer threaded coil sleeves. I might look into that. 3 Quote Link to comment
datsunfreak Posted April 25, 2018 Report Share Posted April 25, 2018 or I could get longer threaded coil sleeves. I might look into that. Are you using the 4" tall Ground Control sleeves? If so, SRP makes a 7" version... http://www.smileysracing.com/shopping/productDetails.aspx?i=10536&c=0 Quote Link to comment
Draker Posted April 25, 2018 Author Report Share Posted April 25, 2018 Are you using the 4" tall Ground Control sleeves? If so, SRP makes a 7" version... http://www.smileysracing.com/shopping/productDetails.aspx?i=10536&c=0 I think 4 or 5. I bought a 7" from amazon for $8. I'll use that to check. If it works, I'll order the other. I like the height in front, but could go up just a little bit. I already have a good dent in the oil pan.. don't need another. 2 Quote Link to comment
Draker Posted May 4, 2018 Author Report Share Posted May 4, 2018 Got the rear crossmember in and alignement done. Didn't go well.. see this thread for details: http://community.ratsun.net/topic/73752-alignment-issues-on-510/ 1 Quote Link to comment
Draker Posted July 3, 2018 Author Report Share Posted July 3, 2018 Did a little more work to fix some dents, dings, and rust. Still a work in progress.. 4 Quote Link to comment
