Draker Posted December 27, 2015 Author Report Share Posted December 27, 2015 (edited) Bought this: Edited January 21, 2021 by Draker 1 Quote Link to comment
Draker Posted December 27, 2015 Author Report Share Posted December 27, 2015 (edited) Installed here: Edited January 21, 2021 by Draker 3 Quote Link to comment
Draker Posted December 27, 2015 Author Report Share Posted December 27, 2015 (edited) Dug this out of the parts bin: Edited January 21, 2021 by Draker 3 Quote Link to comment
Draker Posted December 27, 2015 Author Report Share Posted December 27, 2015 (edited) Cleaned it up: Edited January 21, 2021 by Draker 3 Quote Link to comment
Draker Posted December 27, 2015 Author Report Share Posted December 27, 2015 (edited) Looked at this: Edited January 21, 2021 by Draker Quote Link to comment
Draker Posted December 27, 2015 Author Report Share Posted December 27, 2015 (edited) Cleaned it up: Edited January 21, 2021 by Draker 5 Quote Link to comment
Draker Posted December 28, 2015 Author Report Share Posted December 28, 2015 (edited) Finally found a nice door panel. thanks Kim! now I need to find nice (but not too nice ($$$)) arm rests to go with it. I've been searching for this door panel for 3 years. Bought a full set and will be using the front two and stashing the rear two and the front passenger side. Edited January 21, 2021 by Draker 4 Quote Link to comment
Rhino13 Posted December 28, 2015 Report Share Posted December 28, 2015 Damn this thing is looking good! You're getting shit done for the holidays! 2 Quote Link to comment
Busta Nut Posted December 31, 2015 Report Share Posted December 31, 2015 Lookin Great!!!! Quote Link to comment
B-Mackin Posted December 31, 2015 Report Share Posted December 31, 2015 Nice stuff! I got a chance to see your car briefly at Blue Lake, but the kiddo was melting down so we had to head home sooner than I planned :( Blue Lake!!! That takes me back, I have around 8 trophies from those shows. Quote Link to comment
KoHeartsGPA Posted January 16, 2016 Report Share Posted January 16, 2016 Progress? 1 Quote Link to comment
uberkevin Posted January 16, 2016 Report Share Posted January 16, 2016 Right!! Is it gone? We need to know! 2 Quote Link to comment
Draker Posted January 16, 2016 Author Report Share Posted January 16, 2016 Still working on it behind the scenes. I looked into doing some zinc plating, and I'm not quite ready to invest into a home plating setup. I think I estimated it at a $300-500 to start. I don't remember.. So I send a few emails to places that do plating in town. I need to round up some parts and take them down to get an estimate. I've also got some parts that I painted... they look good. I might send them to jrock.. maybe. Still thinking about that one. 2 Quote Link to comment
Draker Posted January 16, 2016 Author Report Share Posted January 16, 2016 (edited) I am picking up a W58 closed head from Wayno tomorrow. It's not the best head out there but it's better than my open head (W58 I believe).. going to verify that here in a second. I just checked the head I've got and it's an N58. The W58 will almost be a lateral move.. but it's closed. So marginally higher compression. Edited January 16, 2016 by Draker 3 Quote Link to comment
Draker Posted January 16, 2016 Author Report Share Posted January 16, 2016 I also picked up some more color matched paint.. I'll apply a few more coats to the engine bay. Once I get my valve cover and oil pan, I'll be dropping this back in and strapping on the SU's. 3 Quote Link to comment
Rhino13 Posted January 16, 2016 Report Share Posted January 16, 2016 Wooo rebuilt SU's and fresh paint! Can't wait to see it. 3 Quote Link to comment
KoHeartsGPA Posted January 16, 2016 Report Share Posted January 16, 2016 What's wrong with the head you had?, just upgrading to more compression? Also, do you remember the part # for the door hinge pins you got?, I desperately need to replace all of mine, it's the reason why my doors don't close smoothly... 1 Quote Link to comment
Draker Posted January 16, 2016 Author Report Share Posted January 16, 2016 What's wrong with the head you had?, just upgrading to more compression? Also, do you remember the part # for the door hinge pins you got?, I desperately need to replace all of mine, it's the reason why my doors don't close smoothly... The head I have is an open smog head with round ports.. Ideally I'd like a closed square port head but I haven't found one. I found a good deal on a closed W58. It will flow the same as the one I have but have marginally higher compression. Which is a very slight upgrade. Other than that, there is nothing wrong with the one I have. It works just fine. I'll look for the part# for the hinge pins I used. I got them from NAPA. 2 Quote Link to comment
moath Posted January 16, 2016 Report Share Posted January 16, 2016 Good to see you're still working on it! Hopefully that noise will be gone after everything's back together. 2 Quote Link to comment
Draker Posted January 16, 2016 Author Report Share Posted January 16, 2016 The head I have is an open smog head with round ports.. Ideally I'd like a closed square port head but I haven't found one. I found a good deal on a closed W58. It will flow the same as the one I have but have marginally higher compression. Which is a very slight upgrade. Other than that, there is nothing wrong with the one I have. It works just fine. I'll look for the part# for the hinge pins I used. I got them from NAPA. Napa 675-5157 http://www.napaonline.com/Catalog/CatalogItemDetail.aspx/Door-Hinge-Pin-Bushing-Kit/_/R-NDP6755157_0531829749 Good to see you're still working on it! Hopefully that noise will be gone after everything's back together. I looked at everything under the timing cover.... didn't see anything! I changed the front cover though.. so we'll see. It could have the same sound.. but I'll be 100% sure everything is tight. I really hope it's gone though. 1 Quote Link to comment
KoHeartsGPA Posted January 16, 2016 Report Share Posted January 16, 2016 Thanks Craig!, I'll order them up :thumbup: 1 Quote Link to comment
Draker Posted January 16, 2016 Author Report Share Posted January 16, 2016 Stealing this for my reference. From DQ... Originally Published in DQ Volume 6.2 Submitted by John Roper I’ve always had problems with the small clip that holds the fuse box cover on. It seems as though they all broke sometime back when the Bee Gees were still touring... I’ve never heard of a fix for it other than buying a new lid. I happened to be pointing it out the other day to a friend who is a tech at a local Lexus body shop. He said "Hey, that looks just like the pin on an access panel under some Lexus dashes". So I went to the dealer parts department and they kindly let me rifle through about 40 3'x4' drawers of clips until I found what I was looking for. It took me about an hour, but I was finally successful. Go to your local Toyota or Lexus dealer and tell them you need Part # 90467-08119. List price from my dealer was $1.36 each. 3 Quote Link to comment
datsunfreak Posted January 16, 2016 Report Share Posted January 16, 2016 Stealing this for my reference. Post it in as many threads as you can. That's what DQ was/is for. ^_^ 1 Quote Link to comment
moath Posted January 17, 2016 Report Share Posted January 17, 2016 Some day I'll find a fuse box cover so I can have that problem to solve :P 1 Quote Link to comment
Draker Posted February 8, 2016 Author Report Share Posted February 8, 2016 (edited) This is as far as I got over the weekend. Edited January 21, 2021 by Draker 5 Quote Link to comment
