* * * * * 1 votes
The forgotten Beige 69 510 build *Pics fixed through page 8*
  • Please log in to reply
897 replies to this topic
#881 Draker
Draker
    Ratsun-Erect
  • Senior Member
  • 13,459 posts
  • Cars:1971 2 door 510, 1969 4 door 510, 2002 Tacoma double cab
Posted 23 January 2018 - 07:20 PM
View my 69 510 4dr Sedan - Build Thread
View my 72 1200 Sedan - Build Thread
View my 71 510 2dr Sedan - Coming soon.. ish
http://drakers.pl510.info
#882 Draker
Draker
    Ratsun-Erect
  • Senior Member
  • 13,459 posts
Posted 23 January 2018 - 07:25 PM
I thought my rear main was leaking.. but after getting intimate with the alternator it appears to be the oil pan gasket, again. I tightened the bolts just a little bit to see if it would stop. I'm guessing it's the same or worse now. Meh.
#883 Draker
Draker
    Ratsun-Erect
  • Senior Member
  • 13,459 posts
Posted 25 January 2018 - 10:15 PM
Found a local datsun for sale in craigslist. Had a dealer datsun ate on it. On a whim emailed him to see if he would part with just the plate.
Turns out we made a deal. Kendall was our dealer in Eugene.
#884 Draker
Draker
    Ratsun-Erect
  • Senior Member
  • 13,459 posts
Posted 25 January 2018 - 10:16 PM
Still looking for beverton datsun frames. That's where the car was originally sold.
#885 Draker
Draker
    Ratsun-Erect
  • Senior Member
  • 13,459 posts
Posted 18 February 2018 - 11:19 PM
Been thinking about getting some new wheels...  maybe equip 03s.
#886 HOGIE
HOGIE
  • Senior Member
  • PipPipPipPip
  • 1,637 posts
  • Cars:70 521, 64 NL320
Posted 19 February 2018 - 08:05 AM
Turns out we made a deal. Kendall was our dealer in Eugene.20180125_184324.jpg
Score. I’ve only seen plastic ones on 210’s
#887 Mattndew76
Mattndew76
    Hall Monitor
  • Senior Member
  • PipPipPipPipPip
  • 3,908 posts
  • Cars:Datsun 1200 Coupe
Posted 19 February 2018 - 09:14 AM
I thought it was Hutchins Nissan / Datsun in Springfield?
An idea doesn't work unless you do.
#888 Draker
Draker
    Ratsun-Erect
  • Senior Member
  • 13,459 posts
Posted 19 February 2018 - 01:48 PM
I've heard of that too. The person I had install my windshield (in JC) used to work at Kendall Datsun back in the day.
#889 Draker
Draker
    Ratsun-Erect
  • Senior Member
  • 13,459 posts
Posted 06 March 2018 - 08:44 PM
Weekend report.. pulled donor crossmember to clean up and modify. Adding byrons brackets and opening up the exhaust port.
#890 Draker
Draker
    Ratsun-Erect
  • Senior Member
  • 13,459 posts
Posted 27 March 2018 - 09:54 PM
Make a hole
Make a round thing out of a flat thing
Stick it in the hole and weld it.
Mock them up
Clamp it down
Weld it up
#891 Draker
Draker
    Ratsun-Erect
  • Senior Member
  • 13,459 posts
Posted 31 March 2018 - 08:24 PM
Finished, time to install.
#892 Draker
Draker
    Ratsun-Erect
  • Senior Member
  • 13,459 posts
Posted 24 April 2018 - 12:54 PM
Out with the old
Removing rake
Lower.
#893 Draker
Draker
    Ratsun-Erect
  • Senior Member
  • 13,459 posts
Posted 24 April 2018 - 12:55 PM
I still need to set the rear camber and toe a bit. Then may have to lower it a bit more in the rear. I could always raise the front a 1/2" or so to even it out. We'll see..
Alignment coming soon once I get the height figured out.
#894 KoHeartsGPA
KoHeartsGPA
    Datsunahaulic
  • Senior Member
  • 10,070 posts
  • Cars:1970 2-door 510, 1977 620 KC, 1973 610 Goon.
Posted 24 April 2018 - 07:21 PM
Just.how.low.do.you.want.to.go? :lol:
#895 Draker
Draker
    Ratsun-Erect
  • Senior Member
  • 13,459 posts
Posted 24 April 2018 - 08:48 PM
I'm already feeling the pain of the hunt for lows.
Wheels are 15s and making getting low without crazy camber hard. I cut the bump stops tonight. Still pretty excessive rake.
Front coils at max height. Would need to remove spit collars and raise perch about 2 inches and weld in place. That would allow a wide range of adjustment.. or I could get longer threaded coil sleeves. I might look into that.
#896 datsunfreak
datsunfreak
  • Senior Member
  • 13,773 posts
  • Cars:'73 1200 Coupe, '77 280Z
Posted 25 April 2018 - 12:41 PM
Are you using the 4" tall Ground Control sleeves? If so, SRP makes a 7" version...
http://www.smileysra...spx?i=10536&c=0
It's your car, just don't ruin it.
This seems like an elaborate ploy to get me to say "I like the D".
#897 Draker
Draker
    Ratsun-Erect
  • Senior Member
  • 13,459 posts
Posted 25 April 2018 - 01:14 PM
I think 4 or 5. I bought a 7" from amazon for $8. I'll use that to check. If it works, I'll order the other. I like the height in front, but could go up just a little bit. I already have a good dent in the oil pan.. don't need another.
#898 Draker
Draker
    Ratsun-Erect
  • Senior Member
  • 13,459 posts
Posted 04 May 2018 - 03:15 PM
Got the rear crossmember in and alignement done. Didn't go well..
see this thread for details:
http://community.rat...-issues-on-510/
