bilzbobaggins Posted March 25, 2016 Report Share Posted March 25, 2016 I'm thinking about pulling the exhaust manifold and painting it. It's too ugly.. but I don't want to bake it in my oven. I might see if I can get the BBQ up to 400 degrees to cure the paint. Could watch Craigslist for a free functional oven. They pop up here regularly. 1 Quote Link to comment
bilzbobaggins Posted March 25, 2016 Report Share Posted March 25, 2016 And the gauges look right. So so right 2 Quote Link to comment
Draker Posted March 25, 2016 Author Report Share Posted March 25, 2016 Could watch Craigslist for a free functional oven. They pop up here regularly. I looked today. Nothing good in the area. I figure if I mess up the paint, I'll just blast it back to bare metal.. and start over. 2 Quote Link to comment
Coda Posted March 25, 2016 Report Share Posted March 25, 2016 Burned an hour reading this whole thread. I dig your style and your work. Also, SU carbs are so beautiful. I used one on a stuffed VW and that thing got more attention at shows than the turbo did. Add me to the list of buyers if you ever decide to produce the gauge cluster. 2 Quote Link to comment
Draker Posted March 25, 2016 Author Report Share Posted March 25, 2016 Burned an hour reading this whole thread. I dig your style and your work. Also, SU carbs are so beautiful. I used one on a stuffed VW and that thing got more attention at shows than the turbo did. Add me to the list of buyers if you ever decide to produce the gauge cluster. Thanks! 1 Quote Link to comment
Draker Posted March 27, 2016 Author Report Share Posted March 27, 2016 Got a few items from around the world. Sidemarkers(repop), NOS fuel pump, 2 door 510 door seals. 2 Quote Link to comment
Draker Posted March 27, 2016 Author Report Share Posted March 27, 2016 I only bought the repops for the light housing. Wired into old harness and used original lenses. No one will ever know.. 3 Quote Link to comment
Draker Posted March 27, 2016 Author Report Share Posted March 27, 2016 Installed pump and painted the exhaust manifold. 6 Quote Link to comment
Draker Posted March 27, 2016 Author Report Share Posted March 27, 2016 Rigged a few adapters together so I can run an oil pressure gauge and the stock sensor. Not sure what I think about it... open to recommendations. 6 Quote Link to comment
Lockleaf Posted March 27, 2016 Report Share Posted March 27, 2016 Stock 720 4x4 has an oil pressure sending unit that operates both a gauge and the idiot light. The gauges are independent 2" gauges that can be put anywhere. I'm running that and the companion volt meter in my 510 and also in my 240sx (and my 720, but it came with them). I like them because they also match the other gauges well and look stock. These are the gauges. The sender is the gold can right behind the filter. Seen again here in the middle. 2 Quote Link to comment
Coda Posted March 27, 2016 Report Share Posted March 27, 2016 Rigged a few adapters together so I can run an oil pressure gauge and the stock sensor. Not sure what I think about it... open to recommendations. I like it. Looks factory-ish. Wouldn't hurt to paint the brass adapters black, if they stick out to your eye. 3 Quote Link to comment
KoHeartsGPA Posted March 27, 2016 Report Share Posted March 27, 2016 I have a pair of those gauges... Quote Link to comment
Draker Posted March 27, 2016 Author Report Share Posted March 27, 2016 I might paint it and see what it looks like. The brass doesn't flow well. I like the idea of the 720 sensor. I would need to make sure it read correctly on the speedhut gauge. Both good ideas! 1 Quote Link to comment
Draker Posted March 27, 2016 Author Report Share Posted March 27, 2016 Got 3 more of these. They are painted and installed now. 1 Quote Link to comment
Eagle_Adam Posted March 27, 2016 Report Share Posted March 27, 2016 I have a charcol grill at Jessi's you can borrow ;) I wasn't impressed with the cure it on the car method when I tried :/ Quote Link to comment
Draker Posted March 27, 2016 Author Report Share Posted March 27, 2016 Yeah, I probably won't be either. I did sand blast it first.. but I just want to get it together now. It's all bolted down. 2 Quote Link to comment
Draker Posted March 28, 2016 Author Report Share Posted March 28, 2016 Some weekend progress: Starter installed and wired Dizzy in and wired. Cleaned up and ran fuel lines. Still not happy with the routing.. might look for hard lines. 3 Quote Link to comment
Draker Posted March 28, 2016 Author Report Share Posted March 28, 2016 See my Ad in the classified for SU fuel hardline... want it... need it... Quote Link to comment
KoHeartsGPA Posted March 28, 2016 Report Share Posted March 28, 2016 Meantime wrap those in heatshield tape to prevent vapor locks, I did with mine. Napa sells the roll. Quote Link to comment
Draker Posted March 29, 2016 Author Report Share Posted March 29, 2016 Radiator in.. tried cleaning up the shroud.. probably going to have to blast it down and paint it. Few other minor things completed.. 1 Quote Link to comment
denmarkboy Posted March 29, 2016 Report Share Posted March 29, 2016 So excited for you , this thing is getting so close , and looks great. O . . you can add me to the list of people asking for the center caps & gauge cluster . Both very cool pieces ! Yeah, I probably won't be either. I did sand blast it first.. but I just want to get it together now. It's all bolted down. Time to get the shake down happening . 2 Quote Link to comment
KoHeartsGPA Posted March 30, 2016 Report Share Posted March 30, 2016 Can't wait for this dime to be done so we can share the road again :thumbup: BTW...Craig...I FINALLY got around to ordering the speedo cable....Damn it I just kept forgetting :lol: 1 Quote Link to comment
kerleybird Posted March 30, 2016 Report Share Posted March 30, 2016 looks killer draker! Keep up the good work! 2 Quote Link to comment
Draker Posted March 30, 2016 Author Report Share Posted March 30, 2016 Got the fan shroud blasted.. hoping to get it painted before I go to bed. That way I can bolt it on tomorrow after work. I'd love to get a few pieces replated.. but I need to get this on the road and start back up on body work. Eventually.. 2 Quote Link to comment
Draker Posted March 30, 2016 Author Report Share Posted March 30, 2016 Before I blasted it (looked pretty good.. not great) 1 Quote Link to comment
