620 with SR20DET with AC
  • Please log in to reply
93 replies to this topic
#81 skyshadow
skyshadow
    Advanced Member
  • Members
  • PipPipPip
  • 131 posts
  • Cars:1973 Datsun 620, 2012 Ford Focus, 2016 Lexus NX200t
Posted 12 November 2015 - 01:17 PM
Great build, very involved project. Just out of curiousity, Why not use a Prius A/C compressor remote mounted somewhere on the frame? I just remember you saying retaining the A/C was causing a lot of work. That would be a easy fix.
BUT, good ingenuity to keep the A/C
#82 gene knight
gene knight
    Hall Monitor
  • Senior Member
  • PipPipPipPip
  • 1,661 posts
  • Cars:various datsun toys, vw bug, chevy silverado, mitsubishi outlander,plymouth barracuda fastback
Posted 12 November 2015 - 02:56 PM
Looks good, I still need to come by and get those brake parts from you and anything else you want get rid off.
#83 orangie
orangie
    Advanced Member
  • Members
  • PipPipPip
  • 269 posts
  • Cars:99 vette 402ci
Posted 12 November 2015 - 06:39 PM
The AC is sorted out already, just need to run the lines.  Is the Prius compressor electric? If so I'd imagine it has a pretty big current draw and you would need a really big alternator.  I'm going to run an S14 alternator and I think its only rated at 80 amps.
#84 orangie
orangie
    Advanced Member
  • Members
  • PipPipPip
  • 269 posts
Posted 12 November 2015 - 06:47 PM
Custom turbo setups take quite a bit of fabrication.
On a side note.  The paint I used for the front of the dash came out nicely.  It was something I picked up from Ace Hardware.  I don't remember the brand.  It was a popular brand like Krylon, an all in one paint and primer, in satin.  Out of a rattle can, sand it with 600 grit and hit it with the buffer.
#85 orangie
orangie
    Advanced Member
  • Members
  • PipPipPip
  • 269 posts
Posted 12 November 2015 - 06:48 PM
Oops, I forgot to put the picture of the dash.
#86 skyshadow
skyshadow
    Advanced Member
  • Members
  • PipPipPip
  • 131 posts
Posted 13 November 2015 - 07:24 AM
yeah, it would pull a good amount of power. Could couple a beefy Alt with a capacitor bank maybe.
#87 orangie
orangie
    Advanced Member
  • Members
  • PipPipPip
  • 269 posts
Posted 14 November 2015 - 10:05 AM
The easiest fix would be to relocate the AC compressor a couple of inches higher.  At the time, I wanted to run power steering and keep the stock power steering pump.
#88 Eagle_Adam
Eagle_Adam
    Datsunahaulic
  • Banned
  • 10,386 posts
  • Cars:1978 620 KC KA DD 76 610 coupe project Jessi's 77 710 wagon DD
Posted 03 February 2016 - 02:01 AM
Damn fine build, looking forward to seeing this one drive
Chuck it in the Fuck it bucket, cus I'm done
#89 orangie
orangie
    Advanced Member
  • Members
  • PipPipPip
  • 269 posts
Posted 27 February 2016 - 04:48 PM
Got the wiring sorted out.  I had to redo a couple of the relay setups since the NIssan triggers relays by grounding them.  Fuel pump now starts to prime when the key is switched to the "on" position.  Time to put gas in the tank and see if she starts, but before I did that I wanted to check the fuel lines for leaks since I found a write up on the internet saying the brass compression rings are only for aluminum lines.  I am running stainless lines, so I made a leak checker.  It is simple and works quite well.  Pressurize the lines to 100 psi and see how long it can hold pressure.  Both send and return lines lost only 1 psi after a couple of minutes.  FYI, those swivel end for AN lines all leak when you test the way I did. Gas at 50-60 psi would probably be okay.
#90 Charlie69
Charlie69
  • Senior Member
  • PipPipPipPipPip
  • 6,180 posts
  • Cars:1966 520, 1985 720 ST King Cab, 1986 720 King Cab
Posted 28 February 2016 - 06:15 AM
Nice test and you are correct air will leak where gas will not.  This is a build I will drive to the Pavilions to see.
#91 tr8er
tr8er
    Datsun Mechanic
  • Senior Member
  • PipPipPipPipPip
  • 6,906 posts
  • Cars:'71 PL510; 01 Frontier 4X4
Posted 28 February 2016 - 11:04 AM
Great work.
#92 ol' 320
ol' 320
  • Senior Member
  • PipPipPipPip
  • 328 posts
  • Cars:67.5 roadster, M3, TR6 w/ 302
Posted 23 November 2017 - 12:52 PM
Orangie:
Can we get an update?
What did you do for turn signal switch .... does the Ididit column use a GM switch? Same question for wipers.
Does it run yet?
Is it driving?
If so, How do you like the steering?
#93 Farmer
Farmer
  • Senior Member
  • PipPipPipPipPip
  • 2,486 posts
  • Cars:'78 Datsun 620 KingCab
Posted 24 November 2017 - 10:40 AM
He was last active 14 months ago. Hope this build is still moving forward
#94 banzai510(hainz)
banzai510(hainz)
    L motor God
  • Senior Member
  • 15,059 posts
Posted 24 November 2017 - 11:24 AM
14 months????? OH NO another oone gone
Throw on some Weber sidedrafts, Rising Sun hood.... call it good
