4perrev Posted May 25, 2015 Author Report Share Posted May 25, 2015 One thing I forgot to add to the window replacement. Make sure you take out all the window seals before trying to put it back in. Even with them out, it is really tight in there. Couple sketchy moments where I thought the window might break, but going slow, it is doable. Don't want to try it again! 1 Quote Link to comment
4perrev Posted November 6, 2015 Author Report Share Posted November 6, 2015 (edited) Well, she finally let me know that it was time to rework her guts. Had a knocking noise in the front end and found that the cam chain tensioner was suspected to be the issue. Once I took the front cover off, I found different: This one was sideways across the cam chain. This other half was in the bottom of the oil pan. Here are the remaining two bolts where it was attached: That being said, it led to this: Once inside, there wasn't any damage that I could see. I decided to just rebuild the engine anyways! Ordered all my parts from Rockauto and they showed up fast in 6 boxes. Not too bad a job. Replaced all the main and rod bearings, every seal possible, cam chain, guides, tensioner, cam sprocket, new water pump and did a clean valve job. Here's my crank, no pun intended here??!! With all the goods out, I figured why not do the transmission input and output shaft seals, plus change the oil. Wow does gear oil smell crazy when it's old! The tranny seals were available, but the input gasket was not anywhere to be found. So, I just made a gasket and used some good RTV. The rear seal was easy to remove, but the tail shaft was long as hell. Kept turning and turning to get it out. New Seal: All in all, she runs much better and it was a good weekend to kill. Just gets me ready to work on the dime's L20B with mods!! Edited June 23, 2019 by 4perrev 3 Quote Link to comment
skyblue Posted November 6, 2015 Report Share Posted November 6, 2015 Good work. Ready for another 20 years. 1 Quote Link to comment
4perrev Posted November 6, 2015 Author Report Share Posted November 6, 2015 Yeah, I think she's good for awhile now. Just add gas, spark, create fire and have fun!! 1 Quote Link to comment
banzai510(hainz) Posted November 6, 2015 Report Share Posted November 6, 2015 I dont get the rear trans seal whith the PULLER. My 521 trans is a big 22mm nut I unscrew that and the that whole 4 bolt fralng comes out like a 510 drive line ,just slips right off. but looks good. done more than me lately 1 Quote Link to comment
4perrev Posted November 6, 2015 Author Report Share Posted November 6, 2015 I took the nut off and had to use the puller to get the flange out. Big thanks to you Banzai for the engine video as I used it to time the cam back up when going together. That was awesome to see it as I did it!! :thumbup: :thumbup: 1 Quote Link to comment
banzai510(hainz) Posted November 7, 2015 Report Share Posted November 7, 2015 Good I just Winged It one nite when making the vid , I could have done better I just don't remember a hole on where the threaded nut goes on.Like in yours splined shaft. 1 Quote Link to comment
4perrev Posted February 7, 2016 Author Report Share Posted February 7, 2016 hainz, I bolted the puller to the outside flange and used the center of the puller on the shaft. It was the only way to get the entire shaft out. Worked well, instead of beating the sh!t out of it. 2 Quote Link to comment
4perrev Posted February 7, 2016 Author Report Share Posted February 7, 2016 On another note from my Ratsun hiatus, been busy as crap. Ordered all the parts and disc brake replacement kit from Mike at Blue Hands Inc to hook up the truck and put her into the 80's! Mike's parts showed up in two days. All the other Rockauto stuff is on the way. Hopefully have her good and rolling next week. I did get down to replacing my blue seats with black ones from a Dodge Neon today. Long day, so I didn't get any pictures yet, but will post some tomorrow. 2 Quote Link to comment
4perrev Posted February 8, 2016 Author Report Share Posted February 8, 2016 (edited) Out with the old and in with the new: Edited June 23, 2019 by 4perrev 2 Quote Link to comment
4perrev Posted February 15, 2016 Author Report Share Posted February 15, 2016 Well, all the 7 boxes of parts showed up from Rockauto and I got started on the disc brake conversion. Man those old hubs were nasty inside. Grease had solidified into cheese! Cleaned em up, got the new bearing races in and painted the caliper brackets from Mike. Tomorrow (baring the weather) I will finally step into the 80's with brakes. Can't wait to be able to stop on time!! 2 Quote Link to comment
4perrev Posted February 18, 2016 Author Report Share Posted February 18, 2016 (edited) Alright, finally got them brakes good. Now I can stop for real!! What a difference the discs make. Big thank to Mike for the goods and sweet videos! Everything bolted right up (except those crazy brake line keepers, pain in the a$$) and looks nice. The mags clear the calipers with ease. Couldn't be happier!! I know there are pics out there, but I figure that I have to post the goods! Edited June 23, 2019 by 4perrev 3 Quote Link to comment
skyblue Posted February 18, 2016 Report Share Posted February 18, 2016 Did u change the master cylinder? 1 Quote Link to comment
4perrev Posted February 18, 2016 Author Report Share Posted February 18, 2016 I already have a 620 brake booster installed. I did buy a new master but haven't put it in. Might change it out if the old one works terrible, but if not, I'll save it for the Dime. 1 Quote Link to comment
datson4life Posted February 18, 2016 Report Share Posted February 18, 2016 Looks good! 1 Quote Link to comment
datson4life Posted February 18, 2016 Report Share Posted February 18, 2016 Careful with that jack stand tho 1 Quote Link to comment
4perrev Posted February 18, 2016 Author Report Share Posted February 18, 2016 Not usual, just quick 4 x 4 s bolted. Super strong. I have traditional jack stands for real business! 1 Quote Link to comment
Charlie69 Posted February 18, 2016 Report Share Posted February 18, 2016 Just read through this entire thread again, great read! I bet you love the disk brakes. Mike puts out quality parts. I will bet you would not take $4000 for your 521 now! LOL 2 Quote Link to comment
4perrev Posted February 18, 2016 Author Report Share Posted February 18, 2016 Yeah, you're right. It was a wired time back then, but sure glad I kept the ol girl. Love it everyday I drive. Which is everyday!!! The Ratsun folks are good motivators!! 1 Quote Link to comment
skyblue Posted February 18, 2016 Report Share Posted February 18, 2016 So you upgraded to a 620 master? Did you run separate brake lines for the front? 1 Quote Link to comment
4perrev Posted February 19, 2016 Author Report Share Posted February 19, 2016 Here is a picture of the space between the caliper and rim: Ok, I did after all change out the master cylinder because the old one was going on its own program. Nothing I hate more than bleeding brakes. Well, doing it twice!! When I did the first master, I did bend all new lines. Two reasons, they were nasty and completely in my way when I re did the engine bay. Plus, I already had the power brake assembly from a 620. Bending and swedging is not hard, but you gotta have the right flaring tool. I borrowed one from a friend who had a hydraulic one. Super nice, but over 2 bills for the whole thing. Here's the new master: 1 Quote Link to comment
4perrev Posted February 29, 2016 Author Report Share Posted February 29, 2016 So the old drive shaft was doing some vibrating at 50 MPH. Decided to get down and change out the U-joints. All 3 of them. The first 2 were not so bad, just a little void of grease. The third one was completely gone. Once the cap was pulled off, the bearings fell out along with metal shards. Glad I got in there before it really went bad. Did notice that the mid bearing is getting bad as well. Maybe get to that one soon! Just gotta get one!! Here's the picture of the carnage! Quote Link to comment
banzai510(hainz) Posted February 29, 2016 Report Share Posted February 29, 2016 What is the plastic canister? near the carb Quote Link to comment
4perrev Posted February 29, 2016 Author Report Share Posted February 29, 2016 Oh, that little guy? That's my air/oil separator. Fabricated out of PVC pipe, caps and plastic scrubber material inside. There is a drain on the bottom. I had made this a long while back for my GMC Duraslut, but never used it. So I decided to put it on the ol Datsun to see how well it works!! Quote Link to comment
banzai510(hainz) Posted February 29, 2016 Report Share Posted February 29, 2016 Still not getting it. What it goes to and from? Quote Link to comment
