More 510 parts gotta go. OBO
New stuff added, All proceeds will be going to my repro grill project. I will be adding more as I dig through stuff so if you don't see anything check back later. Prices DO NOT include shipping or PayPal fees. You can estimate shipping from 97229. All prices are OBO.
510 slash pan brackets $10
510 tension control rods. $25
New 510 poly rear control arm bushings $20
510 rear crossmember mounts in useable shape $5
R160 Subi 4\11 rear diff, NOT LSD. turns smooth. $45
510 rear drive axles. One end needs new bearings. $20
Complete 510 rear drums breaks, cylinders are like new (less that 500 mi.) drums are smooth with no gouging. needs new shoes. $40 PENDING SALE
Italian made Weber 32\32 carb and intake mani. Carb ran good when I first got the car but has been on the shelf for about three years. It should work fine but I recommend a rebuild to be safe. FYI, I'm not currently interested in separating the carb and mani at this time. $120
New Datsun steel wheel 14X5. I got this for a spare and didn't end up using it. $20
510 right side eyebrow trim, its a bit rough $10
510 door pulls, OK shape $20
510 stock sending unit, worked when pulled $10
510 stock trans mount, rubber is a bit perished but still usable $30
SU carb air box $20
Datsun EI dizzy, in good shape no slop in shaft. $120
510 bolt on fiberglass hood, way lighter than the steel one. $200
510 dealer option console. Excellent shape, great for restoration cars. hole was cut by the original dealer installer (for the stock 4 speed). I had the armrest recovered. $300
If you have question or want more pics of anything just let me know.
  • Replies 31
Forgot to update here, sent feedback in buyer and seller thread though.
Great seller and fair prices. Got the steering wheel and hub fast and description was very accurate. thanks again CorAce :thumbup:
No problem man. Did the hub fit your 620?
I haven't had time to check yet, the alternator went out and I had to quick fit a 200sx alt (only one available locally). Then the alternator bolt broke the next day on the way home from work... It has been an interesting week to say the least. I will try to work on installing the steering wheel tomorrow and see if it works.
  • 1 month later...
