Four door dimes
iwayman
  • Replies 177
What brand of sound deadener did you end up using?
It's some ebay brand sound deadener my dad had left-over from when he was last doing interior work.
Installed a radiator from the po that's made for some v-dub, not sure if I want to run it yet though.
i got the same radiator in mine itl never go past half with a 14" fan, got a nismo thermostat as well. but your radiator seems to be a bit shorter..
only problem i have is that its a bitch to mount a FMIC because it takes up too much space.
what rims are these?! wow your build is nothing but epic.. love everything about it. keep it up bro bro
They're 17x7 konigs off of my 240, thinking about running them but I'm leaning towards a set of snowflakes I've got
Spent time working on my harness.
Looks like I need to swap these buttons with the ones in my LSD in order to mount the axles
where is the center console from?
PO said it's a custom fiberglass console made for the dime.
Not as productive in the afternoon/evening, as usual.
Intake piping made out of scrap parts
PO neglected to mention he forgot to install the exhaust gasket before mounting the engine with the header already on...
Waiting for parts has put a slight hold on the build.
Found a pathfinder upper coolant neck that should work much better than the 300zx one and a power transistor & coil pack out of a stanza that I am going to try to wire into the 300zx harness since PO didn't include a power transistor. Was also able to find a few other missing parts out at a local junkyard.
Also took care of some surface rust in the bay and freshened up the motor a little.  Due to time constraints I can't tear down the engine anymore than it is now.
Had to pull this fucker since I wasn't strong enough to lift it while under the car
Nearly ready to go back in.  Wiring is basically complete, need to plumb fuel, build/have built exhaust, and cut driveshaft
Looking like I might also have time to install my a series cam in my l28et before it's time to back to school so switched the 240 with my bike... sadly 60>13mpg
