help! replacing the timing chain on my 82 720 4x4.
hurts donut
  • Replies 42
Apparently this timing chain manufacturer sells unmarked chains? Which that is kind of stupid if you ask me but whatever. So I marked the new chain with the same marks and I can't get either chain to line up I have the valves closed and the 1st piston at TDC and the timing marks are no where near lining up. No matter what I do I can not make the timing marks on the chain match the marks on the sprockets. Are they just not supposed to match? It seems like if I put the chain on it shouldn't matter where it is positioned as long as the sprockets are in the right spot.
watch my vid.?
The cheaper kits are mostly taiwan made chains and dont have the brite links
TDC the block and head.
then if old chain has the links you can put them side by side and ink pen mark the new chain
Yes I put ink on the new chain to match the links on the old chain. The block and head are at TDC.
You've got some fortitude captain! I always enjoy reading others efforts and it helps ease the pain that this shit doesn't only happen to me. Keep it up and it is always interesting to watch a team effort (although it is your knuckles) such as this have a happy ending.
Thanks man! Really appreciate the encouragement.
Timing chain tensioner was pretty far gone. The guides had pretty good grooves in them too and the chain appeared to have stretched significantly.
New parts look pretty good if you ask me. Got the new tensioner squished all the way in like the picture in the FSM and managed to get the chain put in the right way, after several tries. ;)
Does this thing go on this way?
Or this way?
The picture in the book is not clear to me, but if I stare at it long enough it starts to show whatever I want. :rofl:
  • 3 weeks later...
Or this way?
Oil slinger is on backwards in picture #3.
A terrible development.......
I just put a compression tester on it an turned it over with a breaker bar (yes I put a plug in the other hole so just hang on a sec). And I got nothin, should I expect nothin when I turn it over by hand like that? Also when it got to compression on #1 it hisses! Maybe I have a bunch of busted valves ?:( Would that muck up my pistons too?
I don't think you can do a compression test like that.... I always thought it need a few cycles to the engine to get the number on the gauge to come up properly, and I believe you want to be holding the throttle wide open while cranking....
I usually crank it over till the gauge stops....
The hiss is probably from the valve not sealing properly to the valve seat....
The could be carbon on the valve, a nick in the seat or valve or even a tight valve lash holding it slightly open....
You could probably pull the plugs out and catch a view of the valves through the spark plug hole as you rotate the engine...
 At the moment the crank and cam are properly aligned so turning it with the starter is not going to do any harm.
If there is a hissing sound on #1 on the upward stroke to TDC then you have some compression. Try again maybe your method was faulty (get a second opinion) and use the starter
