cfmotorsports909 Posted June 24, 2008 Report Share Posted June 24, 2008 Any one know if there was ever a turbo made for the L20. Or where I could get one made????? Quote Link to comment
Guest DatsuNoob Posted June 24, 2008 Report Share Posted June 24, 2008 It's not the turbo that has to be custom made. You can make almost any turbo work, it's the adaptation of the turbo to the manifold that's the issue. Depending on the setup you plan to use determines how easy or hard it would be to make. A TDO3 or TDO4 from any stock Mitsubishi eclipse or Eagle Talon would be easy to find and ideal to use. Easy to rebuild, parts are readily available. If it were me, I'd look into a supercharger though. Traditionally more carb friendly, and generally more efficient on both fuel consumption and less wasted power in my opinion. If you really want to use a turbo, think about setting up a fuel injection system and a low comp. motor built that'll handle what you wanna throw at it 1st. Quote Link to comment
datzenmike Posted June 24, 2008 Report Share Posted June 24, 2008 Hmm, I'd have to say the oposite. A supercharger is belt driven all the time weather you're 'into it' or not, where as the turbo is driven by down stream exhaust and not mechanically connected to the motor. When not in use it just idles away. The turbo also uses wasted exhaust energy that just gets dumped out the tail pipe. The s/c uses power from the motor just like any belt driven accessory like an alternator, only a LOT more. For example a s/c may produce 75 extra hp but require 20 hp to turn it... net gain 55 hp. The s/c has one BIG difference... when you step on it it produces power instantly at any RPM. The turbo relys on exhaust flow which is lacking at lower RPMs. The turbo (I think) lends itself better for use with an inter-cooler before going to a carb box blow through, or EFI. A s/c is usually a draw through and isn't inter-cooled. Just an opinion. Quote Link to comment
Fineline Posted June 24, 2008 Report Share Posted June 24, 2008 Any one know if there was ever a turbo made for the L20. Or where I could get one made????? Crown manufacturing made a kit back in the 70's that bolted a t-3 to the stock exhaust manifold. Getting hard to find and is limited in its HP production because of it being a draw through system. EFI and intercooling is definately the way to go but again the parts are hard to find. I had to build everything for my setup from intake to exhaust manifold. Heres a pic. I am also a turbo over S/C guy. Mike is correct in saying that superchargers "take power to make power." Turbo lag can be almost elimited by matching the turbo to your motor. I am using a GT28r Garrett and there is no real noticeable "lag" time. Its fully boosting at 14 psi by 2500 rpm and holds it to redline. Quote Link to comment
ariascarlos1990 Posted July 4, 2008 Report Share Posted July 4, 2008 thats sick. how much did that hole setup cost you? Quote Link to comment
L24 510 Posted July 14, 2008 Report Share Posted July 14, 2008 Where did you get that fuel injection setup? And how is it installed with the ECU and all that stuff? Thats a L20? Quote Link to comment
datzenmike Posted July 14, 2008 Report Share Posted July 14, 2008 We're all proud of Fineline's homemade abilities. If you want EFI for your Z24 take a look at the Z20E and Z22E motors used in the '80-'83 200sx (S11) cars. That manifold will bolt to the Z24. Hell, the whole system will work on it with some effort. Quote Link to comment
novita1021 Posted July 23, 2008 Report Share Posted July 23, 2008 so hey who did you run the oil lines for the turbo on your L20?or is there onother way? Quote Link to comment
RacnJsn95 Posted July 23, 2008 Report Share Posted July 23, 2008 http://forum.ratsun.net/showthread.php?t=3693 Quote Link to comment
sycloned916 Posted July 24, 2008 Report Share Posted July 24, 2008 Crown manufacturing made a kit back in the 70's that bolted a t-3 to the stock exhaust manifold. Getting hard to find and is limited in its HP production because of it being a draw through system. EFI and intercooling is definately the way to go but again the parts are hard to find. I had to build everything for my setup from intake to exhaust manifold. Heres a pic. That's Very NICE! Quote Link to comment
Fineline Posted July 26, 2008 Report Share Posted July 26, 2008 Thanks. I used a sandwich adaptor for the oil cooler and a fitting that had a 1/8th npt takeoff for the oil line to the turbo. Quote Link to comment
ariascarlos1990 Posted July 27, 2008 Report Share Posted July 27, 2008 Very Nice. I would like to see a video of this thing run! :D Quote Link to comment
Fineline Posted July 28, 2008 Report Share Posted July 28, 2008 Thanks. Here ya go http://www.youtube.com/results?search_query=brj4448&aq=f or http://forum.ratsun.net/showthread.php?t=1816 Quote Link to comment
