My latest 510 build.
scooter stuff
  • Replies 323
It's alive!!!          10959116_10204075950603327_1020407594948
  • 3 weeks later...
How did you mount the ProCar seats up? Did you have to make any modifications to the stock brackets? Are they any taller than the stock seats? I ask because I've been thinking of going that route with my own car.
Thanks!
I
Thanks!
I used the Procar runners. I used the stock mounting points on the front & welded a 1x2 tube across for the back. they're the same height as stock but have 3 mounting points
Any chance you got a pic or two of how it looks? I think I have a good idea of what you did, but an image would probably make it really clear.
Typically, a specifically sized shank nut is used in this situation to match the shock thread to the inner diameter of the pillowball... In most cases this is 5/8" as most camber plates use a similar sized pillowball for this application. Looks like you had the shock machined to match and then used a nylock to secure the shock in place. While this will work fine, with the right hardware it's avoidable.
Example ^^^^
  • 4 weeks later...
