What motor do these L4 engine parts fit: Crankshaft & Dual SU Inlet Manifold
OgreZL24
http://www.flickr.com/photos/90175897@N07/sets/72157632204490892/
http://www.flickr.com/photos/90175897@N07/sets/72157632204192292/
These were found in a hoard of Roadster, 510, Z car and other L series Datsun parts.
An L-4 or maybe a Z series cranshaft, but which one...L16, L18, L20B, Z22, Z24 ?
Dual SU manifold which appears to have the bolt pattern for Roadster 1600/R16 carburetors
Anyone in Ratsunville have a guess?
  • Replies 7
Road Warrior wrote: "...Do you mean L-series four banger? L4 is a generic term for any inline four cylinder engine. http://en.m.wikipedi...iki/Inline-four
Thanks for the replies...it still doesn't clarify much, but it's more than I knew before. I was referring to a Datsun L-series four cylinder engine when I used that term ("L4"), to distinguish it from an R, U, A, J, CA or Z series motor. I didn't bother to open the Wikipedia link, but I thought "I-four" or "inline 4" was the generic way of denoting a four cylinder--to me, L4 has always meant an L-series Datsun 4 cylinder overhead cam motor which first appeared in the Datsun 510, as it's called in the US market.
I know the manifold will fit an "L4" cylinder head, but I just wanted to know is it meant for 1600 Roadster SUs, or those smaller flattop SU carbs I've seen here & there on other Datsuns running non-US spec carburetion?
My fault for taking a picture of the crank casting upside down, I thought it was M90, not O6W. If I'm correct, a Z22 crank will work in an L20B block?
