MKLOTZ 411 Disc brake conversion project
  • Please log in to reply
50 replies to this topic
#41 p411
p411
    Hall Monitor
  • Members
  • PipPip
  • 67 posts
  • Cars:67 WPL411, 66 PL411, 65 SPL310
Posted 14 March 2013 - 09:16 AM
The 3/16 line is big enough, so you can scratch that one.  Have you checked to see if you're getting any movement in the calipers or wheel cyls(in back) when the pedal is pressed?  Does it ever get firm when pumping them up?  If it does, you can pull the ebrake so that you eliminate any adjustment issues in the rear circuit.
Hmmm....you might try putting that plastic plug in the m/c on the line closest to the radiator so that it stays pumped up and the movement is all in the circuit closest to the firewall.
Thanks Mike Im thinking about doing just that.  Start there and if that doesnt work start plugging line by line.
I have had this same problem on several vehicles and now I always pressure bleed. no need to bench bleed.
This is what I use.
http://www.bmw-m.net...roc/bleeder.htm
Thanks Charlie thats awesome!!
 A little off topic but what is the offset on those sweet VTO's and what size tire's do you have mounted on them. I am wanting to pick up a set for my 411, not sure which offset to go with in the 14" rims. Also, it looks as if they will "tuck in" when it's lowered, is that your impression as well?
No problem on the off topic. they are 15x6  +24 and they fit PERFECT!! and yes they do like they will tuck in when lowered.
#42 p411
p411
    Hall Monitor
  • Members
  • PipPip
  • 67 posts
Posted 12 April 2013 - 03:15 PM
Okay guys need your help after hours of bleeding and nothing. Its actually weird the lines have no air bubbles coming out and I still have little to pedal. So I plugged up the rear line at  the MC and bleed the front on their own still nothing. then I plugged off the drv sd caliper at the tee bled till solid fluid came out then did the same to the drv sd with the pass pugged off at the tee. still no pedal. Mc is good because I plugged off both lines and the pedal is then rock hard.
So heres where iam at please input your ideas.
Im thinking my hardline routing is a bit crazy.
Right now the hardline comes out of the MC straight down about 3 inches curves back up over the MC and over to the tee
. then from the tee up and over the over flow bottle mounted on the firewall then back down to the pass caliper
then from the tee again up and over the MC then back down to the drv sd caliper.
Maybe just maybe theres too many UP AND OVERS?? will that affect anything?
Im thinking I should reroute all lines so that they are on a downward path as much as possible? and try to eliminate all up and overs?
Im all out of ideas so that's all I got. your help greatly appreciated. If that's too much to picture Ill snap a few shots and post the current set up if needed. Thanks again
#43 bananahamuck
bananahamuck
    S&S chicken/rice
  • Senior Member
  • PipPipPipPipPip
  • 5,195 posts
  • Cars:chicken sedan
Posted 12 April 2013 - 04:20 PM
Open up  the bleeders one at a time and hook a hose (free flowing ) into a bottle to catch fluid,,, and have a little helper just constantly fill master, whilst you pump , it`s very wasteful but sometimes it gets the flow going rapidly enough to flush funky bubbles out..
No promises though.
I belong to both sites,and there's a world of difference in them. They are kids for the most part and act like it. I like both of them.but I know I'll always get more support here.
..........................I shall call it, narclops.
#44 themadpants
themadpants
    Newbie
  • New Members
  • Pip
  • 12 posts
Posted 22 April 2013 - 06:41 AM
If you have a line looping above the MC, that is likely your problem. Air will not be able to be bled from hardline above the MC without major hassle.
2010-01-04_015734_Bleeding_diag.JPG(Example of trapped air on a loop. This also applies to routing above MC reservoirs)
#45 p411
p411
    Hall Monitor
  • Members
  • PipPip
  • 67 posts
Posted 23 April 2013 - 02:24 PM
Thanks madpants  last couple of days ive been rerouting all hardlines to run downhill with no up and overs. Bench bled and  Put it all back together and still nothing. I ordered a single res MC just got it in today lets see what happens thanks for your help.
#46 MikeRL411
MikeRL411
  • Senior Member
  • PipPipPipPipPip
  • 2,278 posts
  • Cars:67RL411, 90 240SX, 97J30T
Posted 23 April 2013 - 05:26 PM
See my entry under "Brakes" for new 411 master cylinder!  It is on my RL411 so should be a "no problemo" on your WPL411.
#47 p411
p411
    Hall Monitor
  • Members
  • PipPip
  • 67 posts
Posted 25 April 2013 - 08:46 AM
Okay either Iam no longer qualified  to touch brakes or I just received another bad MC from Rock auto.
Soo far Ive gone through 3 dual MC"s and 1 single MC
Heres what I do B4 installation. Mount to bench, hook up my hardline loops from output to inside the res. under fluid. stroke the piston slowly until all bubbles are gone. Ive also tried plugging the outputs and stoking piston slowly until I can no longer push it in.
Then mount it on the car with the loops or plugs still installed. hook up hardline to the front output "the one closest to the firewall"  and also plug the rear output "the one closest to the radiator sd" with a plug so that I can only focus on the front and by the way  ive replaced the hardlines now so that they all travel downhill into a tee and then downhill again into calipers.
Then have a friend pump 3-5 times and hold pedal down. I open bleed valve at pass sd caliper draining it into a clear tube container and close . repeat repeat repeat and then on drv sd over and over again. then back to the pass sd until all air is out of the lines. Then I get it to the point of all fluid coming out no air at all. Pedal still feels super soft not even a spongey feel.   Ive also tried mityvac, and  gravity bleed,
Ive made sure the pedal rod is adjusted to where theres a tiny gap before engagement with the piston. and theres no leaks anywhere. this is how I feel >>>>  :rofl: :rofl: :rofl:  !!!!!!!
#48 bananahamuck
bananahamuck
    S&S chicken/rice
  • Senior Member
  • PipPipPipPipPip
  • 5,195 posts
Posted 25 April 2013 - 11:47 PM
Seems like a rhetorical question but,,,,, have you bled the back brakes??
Again try the  just pump fluid without closing bleeder into CLEAR container of fluid at the farthest points and work your way back...Sometimes the fluid just needs to roll out to the extremities washing the air out with it,,,  then worry about,,, doing it the " right " way.
or not
#49 p411
p411
    Hall Monitor
  • Members
  • PipPip
  • 67 posts
Posted 26 April 2013 - 08:32 AM
or not
 Thanks Banana I"ll try that next.
#50 graveltrapp
graveltrapp
  • Senior Member
  • PipPipPipPip
  • 1,168 posts
  • Cars:1967 Datsun 411 wagon,1972 1200sedan, Mazda rx2 sedan
Posted 26 April 2013 - 01:26 PM
Last time I bled after removing and replacing front pads and rotors, I had to adjust my rear brakes signifigently via the manual adjusters to get any pedal back. If the car is on jack stands see if the rear pads are at all hitting the drums.
#51 mklotz70
mklotz70
    Beelzebub
  • Senior Member
  • PipPipPipPipPip
  • 6,073 posts
  • Cars:'64 Fairlane wgn, '11 Kia SOUL,'70 521(wife's), '72 521(daughter's)
Posted 26 April 2013 - 03:57 PM
If your e-brake is working, you can typically set it and eliminate the rear adjustment issues.....at least as they affect the bleeding operation.  Once you set the e-brake, you pump the pedal once.....after that, the rear cyls are not going anywhere.....but the e-brake has to be working for this to work.
It's usually a real pain to deal with both circuits at the same time.  Once you get some kind of pressure in the fronts, then you can release the e-brake and bleed the rears.
As much as it might sound like I know this stuff......I still end up fighting with brake bleeding sometimes. :(
Don't have to be too bright to be me!! :D
Sadly, I prove this nearly everyday!!! :(
www.bluehandsinc.com
youtube.com/bluehandsvideo
