datsun76_620 Posted April 30, 2007 Report Share Posted April 30, 2007 Any idea if a 510 stearing wheel will fit a 620? Want the horn & Turn signals to function...not worried about the collumn cover. Quote Link to comment
Pacific coast Datsun Posted July 4, 2007 Report Share Posted July 4, 2007 I was able to remove an aftermarket wheel from a 75 Z car..adapter & all & it fit right onto my 74 620! Im assuming you want a stock wheel though...Datsun made so many parts interchangable id assume they would swap. Quote Link to comment
Jason Posted July 4, 2007 Report Share Posted July 4, 2007 It would depend on how the 620 wheel "clocks" it's turn signals. Z car steering wheels are direct, bolt on replacements for 510 steering wheels, however the signal clocking is out by 90 degrees. You can move the pins to get the correct clocking though. Quote Link to comment
kiznook Posted July 4, 2007 Report Share Posted July 4, 2007 who needs turn signal cancelation? I don't have it in my 510, it's kinda fun sometimes...drive three blocks and continue signaling the whole way...why make the effort to signal twice? Motorcycles (most, my old RZ did) don't have them, and they don't have loud ass flashers to remind you. Quote Link to comment
510_Dillon Posted July 4, 2007 Report Share Posted July 4, 2007 i do the same thing :D Quote Link to comment
DISLEXICDIME Posted July 4, 2007 Report Share Posted July 4, 2007 my left side sticks on 3/4 of the time. i don't notice the flashers clicking because of my sub so i end up driving for blocks with it on. "o well" Quote Link to comment
datzenmike Posted July 5, 2007 Report Share Posted July 5, 2007 I put an '80?? Z wheel on my stock 620 column. The posts that work the signal cancel weren't long, enough so I cut some nails and pushed them into the (roll pins?) whatever, and it was fine. There was a slight gap. When I installed my present 720 column, it fit and worked perfectly!! URL=""] Quote Link to comment
Bleach Posted July 5, 2007 Report Share Posted July 5, 2007 basically all the older Datsuns (about 1984, older) are the same large spline connection and should interchange. Then in 1983/84 Nissan started going with a smaller diameter column. I wanted to put a 300ZX steering wheel on a 620 but it wouldn't just bolt on. Probably not worth the effort. So I bolted it onto my Pulsar. Easy 10 horsepower upgrade! Quote Link to comment
