help bleeding front brakes (280z master cyl.)
  • Please log in to reply
10 replies to this topic
#1 Friscolada
Friscolada
    Advanced Member
  • Members
  • PipPipPip
  • 83 posts
  • Cars:rhd datsun 510 1971
Posted 10 November 2012 - 03:20 PM
I have datsun 510, i was upgrading from 3/4 to 7/8. I have 280zx front brakes. My rear brakes bleed just fine, but front wont bleed at all. Master reservoir not moving any fluid down, i open bleeder at reservoir and no fluid coming out.
280z master cylinder is brand new
Any ideas?
thanks
#2 datzenmike
datzenmike
    KING RAT
  • User Administrator
  • 72,560 posts
  • Cars:'74 710 sedan, '76 710. prevoius... '78 620, '71 521, '68 510 new '76 B-210
Posted 10 November 2012 - 04:09 PM
They can be bad from the box.
Did you 'bench bleed' it?
Loosen the line to the rear of the master cylinder marked F. Gently pump brake, anything come out?
Posted Image
#3 john510
john510
    Hall Monitor
  • Senior Member
  • PipPipPipPipPip
  • 2,023 posts
  • Cars:71,510 2000 toyota truck
Posted 10 November 2012 - 04:14 PM
Get some clear tubing that fits on the bleeders at the master cylinder.Make it long enough to go from the bleeder into the fluid resevoir.Make sure resevoirs are full.Crack both open and start pumping.You should eventually see fluid and air going through the tubes and then nothing but fluid.I had the same problem and it took about ten minutes of pumping the pedal to get the air out.
#4 Friscolada
Friscolada
    Advanced Member
  • Members
  • PipPipPip
  • 83 posts
Posted 10 November 2012 - 04:38 PM
i will go try see if any ideas work, will be back in bit with report on failure or success.
#5 Friscolada
Friscolada
    Advanced Member
  • Members
  • PipPipPip
  • 83 posts
Posted 10 November 2012 - 05:08 PM
1. so we pumped it no fluid movement for front brakes. (10 min)
2. Lose the line and pump it no fluid going down what so ever, took the line off and pumped it.
Bad Master Cylinder?
Would it effect if use rod of 510 and installed it into 280z?
#6 thisismatt
thisismatt
    Senior Damon
  • Senior Member
  • PipPipPipPipPip
  • 7,954 posts
  • Cars:'71 521, '69 521 donor
Posted 10 November 2012 - 05:23 PM
Make sure there is a little slack/play in the rod when the pedal isn't pressed.
I'm your huckleberry.
One jump ahead of the lawmen
That's all, and that's no joke
These guys don't appreciate I'm broke
#7 john510
john510
    Hall Monitor
  • Senior Member
  • PipPipPipPipPip
  • 2,023 posts
Posted 10 November 2012 - 05:32 PM
Yes,the 510 push rod is too short.
#8 Friscolada
Friscolada
    Advanced Member
  • Members
  • PipPipPip
  • 83 posts
Posted 10 November 2012 - 05:34 PM
Yes
Thanks for help, im going to get replacement then. :thumbup:
#9 Friscolada
Friscolada
    Advanced Member
  • Members
  • PipPipPip
  • 83 posts
Posted 10 November 2012 - 05:44 PM
yes i had some play, i gave a lot of play, took most of it out... nothing made a difference
#10 macgyver
macgyver
  • Senior Member
  • PipPipPipPip
  • 468 posts
  • Cars:72 2dr. 510
Posted 29 November 2012 - 03:39 AM
Any update? I'm in the middle of doing the same swap right now and I'm not sure if I can use the stock 510 push rod? Do I just lay it on place and take out the slack? Then need to bleed everything. Any insight would be great.
#11 CableDroid
CableDroid
    Member
  • Members
  • PipPip
  • 61 posts
  • Cars:510 Goon
Posted 18 March 2017 - 08:37 PM
Having similar issues with a brand new 7/8" master. Did you ever get it figured out?
Cable
-1970 Datsun 510 Wagon: L20B, Weber DGV, 4 speed, 280zx struts/brakes/coilovers, 15x7 Konig Rewinds, Nitto 205/50/15
-1974 Chevrolet K5 2wd, Full Convertible, LSx 6.0 swap, turbo, etc
