My '72 two door 510
JPE16
  • Replies 82
Having it on the floor beside a KA, SR, and K24 was interesting. My reasoning for ditching the NIssan motors was: It's a tiny motor, and weighs in at a fraction of any of the others (before you add turbo ancillaries no less). It makes a fair amount of power stock, with great midrange (well suited to our local road courses I'll be competing on). It can make alot more power, very easily. Parts are cheap and plentiful.
Packaging wise in the 510, it's a nightmare and a dream at the same time. It shouldn't be a major pain to get in the car though. I may build a jig while I'm at it and produce a bare bones kit. Who knows.
At any rate, I took alot of time to decide on a drivetrain. In the end, weight, power, and reliability were my main concerns, and the F20 knocked the ball out of the park in all those three categories. But yes....it's not a Nissan motor.
lb for lb i think its the best engine made, right? a small 2L engine putting out 200hp? not a bad choice, plus the aftermarket is pretty large for anything honda.
240BHP stock actually. Reasonably easy to get near that in torque with carefully chosen parts and a good tune too.
We installed AVO control arm bushings, Whiteline sway bars, and did a brake service. All just in time for winter.
first thing... I think I shit talked a few pages ago but I love the look and direction of the 510......hate the yellow but see what your doing and like it ....... a lot ...... i loved the ka so it will be tough to sway me ......but u already did when u posted that fucking gem^^^^^^^^^^^^sexy wagon
I love the engine choice!  A buddy just picked up the same setup, he wanted to know if I would wire it if he got it installed.  I said he should send the engine my way instead.  haha  You should post details of all the little problems installing it.  There was one local guy who installed one.  Crappy install and the kid was annoying as F***K.  So I didn't get to lean anything cool.  So now it's up to you.
well if icehouse likes it I guess I will like it too  :fu:  :fu:  :fu:  :fu:  :fu:  :fu:  :fu:  :fu:
it is a solid engine and great support
Its just not nissan  :devil:  :devil:  :devil:
I was honestly in the same boat. I couldn't get over the fact the motor wasn't Nissan built. But after a lot of research, it was hard not to go with it.
I got the steel bent for the cross member, so ideally that will start to take shape this weekend. It's going to be very tight with the bell housing clearance. I know I'll have cut the tranny tunnel to accommodate the shift rod, but I'm hoping to avoid making any major cuts in the engine bay.
At any rate, I was thinking of making a jig for the cross members if anyone needs one in the future, and my wiring guy has everything laid out for future use, so if anyone has any questions, I would be happy to answer them about the swap.
I stopped by his place to look at my oh, so pretty Deatsch Works connectors:
1455154_10152049715655926_1239010057_n_z
My ecu board is done enough for me to find it a reasonable home in the car:
1479249_10152049715855926_1233799280_n_z
We're just waiting on the raychem for the engine harness, and it will be all done.
So, as a result of the engine change, I'm going to have to build a custom cross member, and the first step of that is to cut apart the old one. So within hours of my last exam, I had the cross member cut apart and ready to have the ends plated, go back in the car, and get squared up to start building the new member.
6D4DF376-51D9-4230-A2C5-1C69996D9D6D_zps
9589E013-7ACE-4068-8BCB-182D62DC582D_zps
263AAEF0-5AE1-493C-AAEB-CF85122697E2_zps
I didn't snap any pictures, but I did get the plates on the ends of the cross member ends. I also removed the engine mounts. The motor will be sitting further back, and at a different angle, so my plan is to use the stock s2000 mounts and build a lower part onto the cross member to accommodate a bushing/isolator of some sort. I also Tig'd together the plates, and noticed I'm getting quite a bit of porosity. I'm going to take them into work tomorrow and blast them and hot it's just dirty metal, as it's fine in some spots, and terrible in others; but any input is welcome.
I also realized I hadn't posted any pictures of the new shop. I love this place! We have a great group of guys, six amazing projects, lots of skill, and a great selection of tools.
plus puppies. Sorry to gush, but I'm so pumped to build so many things. Having a hoist, tube bender, chassis table, and the people, skills, and other tools to build pretty well anything has me quite excited!
At any rate, here's a couple pictures of why I love this place.
344D600D-3C11-415C-9081-69D409F504BB_zps
874BF958-F364-4CB2-99C3-B84A75722909_zps
I also got the aluminum bosses in from the machine shop to weld onto my core so I can put my aluminum top mount on the legacy.
898DD6C9-F5B1-49C1-A3DA-6B5942F511B6_zps
  • 4 weeks later...
Lets see if I can make sense of what I have done over the past few weeks. Unfortunately life happened over the break and I didn't get to spend nearly as much time on the car, however I now have more room to sleep, and less time I'm required to be at home.
I had the engine in and out a few times. I have been looking at other swaps, and I don't really see any I'm in love with. i don't really like how alot of them solved some of the problems. So, I took some time to think and come up with some solutions. On the top of my list was not hacking up the firewall and transmission tunnel. Secondly was to leave room to add a rack down the road.
So after much consideration, I decided the best way to keep the engine forward (to allow me to access things on the firewall, and leave room for the largest part of the bell housing, making it easier to work on) and as low as possible. To do this I would need to either a) make a new drag link (or bend the existing one, although adding that much heat to a 40 y/o cast part doesn't strike me as smart) b) switch rack and pinion immediately or c) make a new oil pan.
After some investigation, it turns out the rear portion of the pan that's in the way doesn't hold any oil. So, that made my decision rather easy.
DBF28B44-798B-44CF-9E0E-45E3E2E38183_zps
00778F01-D8F9-4B8A-8912-688989275249_zps
1508087_10152138838300926_652722657_n_zp
923233A5-DBBB-49AF-B706-95F03752F858_zps
Next job was to make up a new crossmember. I had started on this before the last step, and it looks ugly now, but the ultimate goal is to make it look like one piece.
1374769_10152138837840926_451794710_n_zp
It also allows me to mount a rack on it down the road.
So, I sent the pan out to have the offending casting machined off, got it back, and welded some plates on to give it back SOME structural rigidity. I test fit it, and it worked a treat. i could now position the engine exactly where I wanted it, retain the factory drag link, keep the tranny tunnel massaging to a minimum, and have room to work on the back of the motor. Unfortunately I dont have any pictures, but my dialing in of the tig welder on aluminum hardly went smoothly, so perhaps it for the best no one see those. However I did get it close enough to stick two pop cans together. A few tacks was the best I could manage after a few minutes practice
1506923_10152138839140926_230093602_n_zp
Having the pan off, i also had a look at the bottom end. I think I believe this guy now about the whole 8000km thing
1545688_10152138838510926_1035562244_n_z
Jumping ahead slightly, after a ton of measuring, and positioning, and measuring, I popped the motor back out and began fabbing mounts. 200 points to whoever guesses with the rubber isolators are made of.
Bolts welded to the back of the plates
E98BB220-9CB9-48C0-A666-724918110A95_zps
Bolt, plate, and isolator in their home
BF8395AB-7FA1-4853-A4C9-C62977A31E74_zps
D525387E-9B84-4912-9149-58BA03BD2BA7_zps
Side plates added, and buzzed onto the crossmember
10254EDF-2144-4A58-9DC3-23783F42DF45_zps
Tomorrow I will likely put the inside plates on, tig it all up, and get it ready for final instal.
So, over the break I got a bunch of other things done, not all of them productive. I spent some time practicing my tig welds (naturally on someone else's car) and welded some struts up for my friend James who's building a heck of a 280z!
1530525_10152138838640926_1760548778_n_z
4E78EF45-DF53-4B0C-BEC5-02D2C6E8A6BC_zps
Tig welding is all practice, so I stuck together a new holder for cellphones at the door (the only place we get reception)
1545089_10152138839240926_1627784769_n_z
Got my seats all mounted and ready to go in
199F4A19-E033-43D6-94ED-E743BB4D4C5E_zps
and popped by my parents place to use their, rem, parts washer
4CB9E0EC-7930-44B3-B359-FFEBFBC111AC_zps
B9EEE127-6485-4F46-89D4-33E91F01380C_zps
Also got a pretty sweet christmas present from my dad
0C0DD342-F91E-4667-91CC-FA6782DAFA5D_zps
E7549D2C-2A1E-41B9-B814-59C138224D57_zps
And lastly, I hit up the motorcycle show with some friends and picked up all the gear I need to ride my other new toy
5E69B8ED-CF56-4E58-98CE-753C9F9E1709_zps
7B6A0758-3AF2-4605-AEC0-552202A0CDBE_zps
Anyway, I'm sure there's things I'm forgetting. At any rate, for those who've been following the build, I should have more updates to come, and look forward to any input.
Thanks for reading guys!
reminds me of working at my buddys shop ... the cell phone stays in the window inthe far corner ... the only decent phone reception in the whole building ...
nice bike
EDIT;  oh and in the first pic on this page ... i will take that whole wall of suspension tabs.....
Hahaha, If that's the only thing wrong with the build, then I accept that! I'll try to be more careful in the future though.
The isolator is a piece of a roller from a boat trailer.
I finally got around to replacing the sheet metal screws that were holding the brake lines on with nut-serts
1544604_10152155782860926_1871871113_n_z
1560529_10152155782935926_1796362231_n_z
1017386_10152155782975926_342735598_n_zp
Next up, was something else rather exciting. I buttoned up the engine mounts, put the cross member in, and then stuck the motor in. Turns out I can measure, and stick metal together. Crank was dead nuts centered, and the motor was straight and exactly where I wanted it. I was pretty happy after it was all tightened down.
1609794_10152168269355926_834639553_n_zp
1688305_10152168269480926_1130422964_n_z
1656430_10152168269540926_1809754257_n_z
1506630_10152168269685926_1950318329_n_z
Next up, Ryan from Ryan Maxwell Racing came by and finished up the wiring on the trunk
484796_10152141222385926_692747284_n_zps
1609754_10152141222455926_933902594_n_zp
And he also finished the center console:
1005815_10152168269810926_706032797_n_zp
1601153_10152168269980926_14572493_n_zps
1622852_10152168269895926_1899830575_n_z
And then he stuck it all together, and turned the key, annnnnnndddd....
1779908_10152168269275926_955055224_n_zp
1551521_10152168269195926_1969253609_n_z
1619420_10152168269040926_742455873_n_zp
We have electricity! From the light on the ecu and fuse box to the tail lights, everything fired right up and worked. I tell you it was a majorly uplifting feeling to see that car sitting there with the motor in and the hazards flashing away.
And this is all after we had a major party to celebrate my cousin heading to Sochi to represent Canada on the women's Snowboard team, competing in slope style! Everyone send good vibes Jenna Blasman's way!
1502340_10151803977886714_944380453_o_zp
  • 1 month later...
Small update:
So We had the engine in and out, and in and out, and it's looking like the tranny tunnel needs to be remade to accommodate the S2000 six speed. So I did a little cutting, and bam, it fits.
10006983_10152264412245926_1384304576_n_
971713_10152267576190926_1080067106_n_zp
1925207_10152264412390926_95847400_n_zps
1511628_10152267576755926_456872072_n_zp
I'm hoping to build the new tunnel tonight.
Some other less significant things happened:
The walbro found its way into the tank:
1939653_10152224196710926_1706329511_n_z
I made my lexan rear quarter windows:
1779820_10152241122285926_538869024_n_zp
10003528_10152241122225926_2078840767_n_
and my dash face finally showed up from laser cutting:
1654297_10152224194845926_1373433799_n_z
The body work is coming along as well, but who wants to look at pictures of sanding.
  • 4 months later...
This car hasn't been forgotten about!
It went away for some things and came back a running, turning, stopping, moving car...on the back of our resident bad-ass car-hauler of course:
10557402_10152577033540926_6523488986044
It's also no longer yellow:
10600633_10152581036220926_5142981855870
And way more complete:
10580167_10152585103960926_3023485184847
I will update accordingly with the full story and way more pics when I have time
  • Like 4
  • 4 weeks later...
So, some things have happened since I last updated this.
I drove the car the other night, and to my delight, found very few issues that need addressing (besides working on my driving...). I'll just go through and let the pictures and captions do the talking.
Oscar primed the car:
10300238_10152581705970926_8163522510182
10644961_10152611864260926_4745014853440
I then finished up the underside, including the exhaust:
10345580_10152592214845926_5152890849085
10410550_10152597313270926_4440874250409
10569059_10152581706080926_2234754303758
Next, I finished up the heat shield, made a coil pack cover, and finished up some odds and ends in the engine bay:
983771_10152601255190926_721394949365921
10570438_10152581706015926_5569098348136
10615525_10152603472540926_5214387402340
H at Spec-Auto sourced a second set of wheels for me on short notice:
10373712_10152626679170926_6064928650190
Finished up the trunk:
10583844_10152627857300926_9209053383354
The gauges went in their home and got wired up
10645171_10152611861830926_3050888609173
The front of the car got assembled:
10616137_10152613401970926_1236523403993
Brake and clutch set up:
10624998_10152604011395926_5242131672625
And finally, off to paint:
10486208_10152629670045926_5728961381751
10645190_10152633460265926_1286425036622
10628050_10152633271120926_4476915091758
10538621_10152633460405926_4188005471400
1544329_10152633460525926_36809687141183
14960_10152633460245926_2713782313168860
10556326_10152635203610926_4984604628835
That's all for now!
Indeed I do
SO, we took the car out to to TMP for a shakedown run on sunday, and I couldn't be happier. The car did nine sessions, and only encountered a couple small issues, with no mechanical failures. IT just wanted more. It definitely requires ALOT of work still to make it work well. Because of how poorly it was handling under braking, cornering, and accel we only times one session, and the fastest lap from that session was a 1:26.3
At any rate, my parents surprised me at the track, and I took both my mom and dad out for a few laps. It was pretty surreal to be bombing around tmp in the car with them on board. It was a great day, I'm still on a high, and can't wait to go back on Friday and start to get the car dialled in.
Anyway, Papa Ellis snapped a few photos:
I will get some video friday if i remember.
