280zx: thinking rat rod bosozoku style, and off i go
Jomz Shakes
I've thought of the color a lot and want to really make my car stand out. I'm going to have the crown royal bag shift boot and I'm going for a purple steering wheel and royal purple carpets and eventually a rollcage.
Here's a pic I found of purple ones. I'm hoping they won't clash with the red pinstripe.
Screenshot_2014-05-24-08-54-48_zpsxymaol
  • Replies 187
I'm getting parts together for my turbo swap.so far I have
440cc supra injectors
Non egr intake manifold
Free ebay boost controller w gauge
Walbro 255 fuel pump
Rx7 fc oil cooler
steel mandrel u-bends for intercooler piping that's left over from exhaust work
Aeromotive a1000 -6an FPR w gauge
89 240sx throttle body
-Need to get a whole megasquirt package.
Thinking ms2v3 w relay board and whatever makes it easier to install. Still doing research.
-Need turbo engine w everything attached
Manifold,oil line,harness,dist,
-Need t3/t4 turbo (don't know what type?)
-Need intercooler (large npr)
-Need wide band O2 (?)
-Need BOV (going cheap 1rst gen dsm)
-Need radiator fan (taurus fan mod)
-Need plans for ignition (msd 6a?-stock?)
-Need pallnet fuel rail and TB spacer
-Need nissan injector seals for supra inj.
-Need manual steering rack so I can add steering angle
-Need 2.5 downpipe
-Need help installing all this crap haha
-Need help filling in the blanks for my parts list
  • 3 months later...
Okay I got more parts now my setup consists of
Rx7 fc oil
Megasquirt 3 3.57
3" downpipe with t3 flange
Large Npr intercooler
2.5" piping
Turbo manifold
Turbo oil feed
P90 head
Msd 6a
Innovate mtx wideband 02 w af gauge
Boost gauge
Hallman in cabin boost controller
I'm going to shoot for a 400hp build and build it strong enough to handle it and then tune it down for reliability.
The part that I'm stuck at "since this is my first engine build" is that I don't know how to match all my internals together so they synchronize well.
I mean I don't know how to make my pistons create a compression ratio that my turbo will like or a turbo compressor wheel that my cam will like.
I like torque so I want the compression ratio kinda high.
I need new pistons so I'm going Forged
I'm porting the head stage 2 or 3
I want to run near 20 psi. I've read the 50 trim on a t3t4 hybrid will start boosting pretty low to 6500?
I'm going to lighten the stock flywheel but don't know how much if my pistons are going to be lighter.
My final drive is at 3.9 w 17" rims
Do I plug all these things into a website and it will tell me what type of cam grind to get on my na cam??
What other questions should I have answers to??
Ya that's cuz I live on the road as a truck driver. I'm only home one every 2 months. Did you not see the 2k of parts I just bought??? The rims I have?? It's coming man jeez all you've posted is negative stuff why you even here??
I'm asking "what other questions do I need" in regards to synchronizing a balanced engine build by matching up my pistons ,cam,turbo,and port work so they have good synergy with each other.
I need professional help I'm talking with elgin cams and they need me to have specs on everything else related. I gotta slow down hhere and do this right.
I've heard there is a engine builder website??Where you plug in specs and I guess it fills in the blanks.
Any one know about this?
Or have done a similar build and has insight on how to approach this part of the build??
  • 2 months later...
  • 2 months later...
  • 3 weeks later...
