411 SSS dual carb setup $200obo
i have a 411 SSS carb setup comes with air cleaner but no filter and missing stuff, what you see is what you get.
Will take trades for 5spd L series Tranny, Coilovers that fit on the front of a 510, drivers side door for 2door or some 4x114.3 wheels
  • Replies 11
Both the 411 SSS and the 1600 roadster share the R16...
The difference is the length of the filter case and element. About 1 inch shorter in the sedan vs. the roadster. You would need the accelerator shaft and fittings to make this operable, it is do-able.
