My dads old 1975 620 DD - Sold now
i pulled my spare 4 speed out of storage and came to the sad conclusion that its a short tail so it wont work in the truck. Which let me down the road of finding a 5 speed......
I was at PnP when they opened at this morning with jassifrass and converted to datsun and picked up a good 5 speed and an el dizzy for less than $100!
off to dinner with the family and i should be able to get everything cleaned up tomorrow!
  • Replies 181
got the greasy ass block & oil pan cleaned up
also go the new el dizzy cleaned up
front timing cover and what ever the plate is called between the block and the trans got cleaned up
the engine bay is cleaned and ready to go
ditched the grill and headlights to clean up the front end a bit too
then i got a wild hare a preped the front end for a little black paint behind the grill ;)
got the primer on!
when i called and out it on the northwest Z account it was $70+
Who ever you talked to wasnt aware, that the $70 kit is discontinued from Fel-Pro
Its 2 parts, $25 for the "Convertion kit" which is the lower engine stuff, and $33 for the "Head Gasket Kit". Anyways, it appears they are out of the convertion kits...
Sure is fun reassembling a car!
more cleaning and rust removal
found some holes in the passenger side too so i picked up some fiber glass to reinforce it
POR 15 and fiber glass is done! and ROCK HARD!!!
also treated a few spots in the engine back with rust converter and primer
not a perfect color match or really even close but it will work for now
started cleaning up parts
Then it was onto the motor assembly
timing parts are on
prepped the block surface and off we go
Heads on
thought this was a cool pic that shows how a timing block works
Got the front cover on, new KA oil pump in and clocked, then the oil pan on, and then i snapped a bolt installing the water pump.....
so i grabbed my eazy out kit and removed the stud only to find out the hole is cross threaded and i need a new timing cover
i was talking to Nismo Dr about that and it looks like its too close to the water jacket for that and i dont have a helicoil kit, and i got a new timing cover from Redbanner today so its not all bad. I have the motor on a stand so id rather take a few steps back right now rather than later when the motor is installed.
picked up an L20 motor from RedBanner monday, and tore it down last night to get the timing cover
Now i gotta clean up the new timing cover and tear down the motor from my dads truck to install the timing cover
i picked it up for the front cover and am hoping the block is good, from the looks of it and from what i was told it blew a HG and then sat outside in the rain for a while.
To me the head is toast, the block and lower end is TBD
the old fly wheel needed some help so i tossed out a feeler and dislexic dime answered with a new one :
Old
Floors are done, seat is in, and new black retractable seatbelts are in
Skib, jassifrass, nismo dr and I dropped in the motor and trans on sunday
Now to plumb and wire everything :)
This topic is now closed to further replies.
