620 weight?
ddrum
  • Replies 14
  • 9 months later...
just wanted to bump this old thread because im excited
i got to weigh my truck yesterday.
(73 620, l16, 4 speed, approx 2-3 gallons of gas)
front: 1320
rear: 1100
total: 2480
this was with me in it, so -160 and you got 2320.
weight distribution is approx
F 55
R 45
this is with a bit of a rake, when i finally install those 720 springs it should
distribute more weight to the rear.
if 1 gallon of gas is 6.5, fill up the rest of the tank and i would add approx 58.5
to the equation, but not directly to the rear since again trucks at a rake and
the tank is more forward. eventually i would like to put the tank farther
rearward and more centerline.
  • 3 years later...
^Well... normal force is always opposite of gravitational force so yes to a point. But, frictional force will alter total force direction thus distribution. Not going to be huge though
If you recall, old gassers and hot rodders racked their cars for this effect.
Totally to the point actually, which was, weight distribution. Raising or lowering a vehicle is not going to change the weight on each axle. Weight transfer on acceleration is a different thing. Can't be measured except by comparing time slips. Raising the front or the entire car will cause a shift in weight to the rear, on acceleration. Soft or no shocks on the front will allow it to rise even farther on take offs and shifts.
