Busta Nut Posted October 28, 2014 Report Share Posted October 28, 2014 Don't forget to goo the edges........ How many foot pounds again :confused: No.....but for real..... 3 Quote Link to comment
Janksun Posted October 28, 2014 Report Share Posted October 28, 2014 I always do 25 then 45 then 65. What did you end up doing? Quote Link to comment
freetheoranges Posted October 28, 2014 Author Report Share Posted October 28, 2014 33, 65. Quote Link to comment
datsunfreak Posted October 29, 2014 Report Share Posted October 29, 2014 Interesting intake......first I've seen...... Anybody have any info on these?? What do you want to know? Other than the obvious, that it's a 70s Offenhauser dual plane intake, there's not much else to know. I've seen plenty of them, but they are getting pretty rare these days. If you run it, knife-edge the split where it meets the head. It flows a little better that way. It's designed to increase torque, and it does. A bit. ^_^ 2 Quote Link to comment
Busta Nut Posted October 29, 2014 Report Share Posted October 29, 2014 What do you want to know? Other than the obvious, that it's a 70s Offenhauser dual plane intake, there's not much else to know. I've seen plenty of them, but they are getting pretty rare these days. If you run it, knife-edge the split where it meets the head. It flows a little better that way. It's designed to increase torque, and it does. A bit. ^_^ Thx!! Not much was obvious to me other than it was different.......had no idea what the purpose was..... .......hadn't had time to research yet....... Knife edge idea is great....but I'm on a time budget......will do in the future though.... Quote Link to comment
freetheoranges Posted October 29, 2014 Author Report Share Posted October 29, 2014 We got 'er back together minus coolant and hooking up the exhaust. Called it a night before hearing her run. Thursday night I go back to pick her up. 2 Quote Link to comment
Busta Nut Posted October 29, 2014 Report Share Posted October 29, 2014 Couple issues though....... -Carb needs new internals....idle will not drop...still diesels.....dammit!! -Radiator decided to start pissing in my face as I was adjusting timing....doh!! Other than that......she needs brakes.....baaaad.. Engine sounds strong though!! :thumbup: 2 Quote Link to comment
Busta Nut Posted October 29, 2014 Report Share Posted October 29, 2014 Another HUGE issue I forgot to mention.......probably needs to be addressed ASAP...... What would cause this?? I didn't have time to look into it......it'll go back on the rack tomorrow to check more things out...... ....but has this happened to anyone?? :o :o Something bent?? installed wrong/backwards?? :confused: Quote Link to comment
Busta Nut Posted October 29, 2014 Report Share Posted October 29, 2014 Ok......so.....found out during lunch it's most likely the oil pan...... Gotta find a new one......who's got the stock pile on oil pans?? .........I'll take a couple..... :D Anyways...... Last nights progress....... Quote Link to comment
Busta Nut Posted October 29, 2014 Report Share Posted October 29, 2014 Had issues with the base plate.... First.....the studs go too far......had to grind them down........but when they were flush and I set the carb on it.....it wobbled..... So I dug up my old one for a temp until I can mill this one...... .........or learn how..... :lol: 1 Quote Link to comment
datsunfreak Posted October 29, 2014 Report Share Posted October 29, 2014 Another HUGE issue I forgot to mention.......probably needs to be addressed ASAP...... What would cause this?? ....but has this happened to anyone?? Ok......so.....found out during lunch it's most likely the oil pan...... That is a 620/610 oil pan. It has a longer sump than a 510 pan. To put any L-series engine into a 510 you must use a 510 oil pan. A lot of guys on here don't believe me when I say this, but at least 9 times out of 10 this is what happens when you don't. 2 Quote Link to comment
Busta Nut Posted October 29, 2014 Report Share Posted October 29, 2014 One hole was a little messed up.....so I cleaned it up hoping some threads will grab.... ......they did.... Quote Link to comment
Janksun Posted October 30, 2014 Report Share Posted October 30, 2014 Lookin good man! Quote Link to comment
Ranman72 Posted October 30, 2014 Report Share Posted October 30, 2014 looks like a truck oil pan compare to your cars pan there is a role missing to clear the steering 1 Quote Link to comment
the510keeper Posted October 30, 2014 Report Share Posted October 30, 2014 Datsun make that fucker run run forest run :) Quote Link to comment
Busta Nut Posted October 30, 2014 Report Share Posted October 30, 2014 ^^............You should really post when you're sober...... Your statements make sense to only you........ :rofl: Where's my rear crossmember?? 1 Quote Link to comment
Busta Nut Posted October 31, 2014 Report Share Posted October 31, 2014 Linkage was an issue before...... .................actually......I didn't like the hacked look..... So I dug through our brake spring box......... Pin box....... .....and a warsher... Voila!! Quote Link to comment
banzai510(hainz) Posted October 31, 2014 Report Share Posted October 31, 2014 If idles high I would ckeck the speed screw. try adjust idle mixture and timming. also for the Pinging ck with timming light so your positive your not off a tooth and try SUper Gas also I didnt see if you ran a water line to the intake. as these might cool the mixture slighly so it dont preignite. also most L20s cam with a cutoff Selinoid on the stock carb. But if this is the Closed chamber head I would think it wouldnt do this as I run cheap gas on my l16 18 with closed chamber and not pingin. I see you not running a heater. just make sure you dont have a airbubble in system Quote Link to comment
freetheoranges Posted November 3, 2014 Author Report Share Posted November 3, 2014 Hainz, you talk about a cutoff solenoid however everyone has told me it is just an electronic choke [i do not have either]... is there a difference? Quote Link to comment
freetheoranges Posted November 8, 2014 Author Report Share Posted November 8, 2014 After a lot of run around by my boss I was finally able to pick her up on Wednesday afternoon. Brakes are terrible but still can come to a stop. Increased height of the carb changed the accel. angle and fell out a couple of times. Has that awesome tin-ny sound but will need a hot adjust sometime soon. Radiator holding fluids, however recore next pay day. Yes I want the stock rad look. No I don't want to fab to make something else work. Yes, I'm sure. Quote Link to comment
skyblue Posted November 8, 2014 Report Share Posted November 8, 2014 Wait, are you sure you're sure? Quote Link to comment
r0p0doe Posted November 8, 2014 Report Share Posted November 8, 2014 After a lot of run around by my boss I was finally able to pick her up on Wednesday afternoon. Brakes are terrible but still can come to a stop. Increased height of the carb changed the accel. angle and fell out a couple of times. Has that awesome tin-ny sound but will need a hot adjust sometime soon. Radiator holding fluids, however recore next pay day. Yes I want the stock rad look. No I don't want to fab to make something else work. Yes, I'm sure. Sooo is your car better than what it was? sounds like some minor things, bleed the brakes, adjust carb, "I" would get an aftermarket radiator my stock got hot tanked and didn't do the job for my motor... Quote Link to comment
Janksun Posted November 8, 2014 Report Share Posted November 8, 2014 Koyo has a bolt in radiator for a 510 1 Quote Link to comment
