Alternate 510 master cylinder
  • Replies 15
Yes for a stock system a larger diameter master is NOT and upgrade. It only makes working the brakes harder.
What is the 510, a 3/4" master? I think the 710 is also 3/4". I put a later S110 (200sx) 13/16 (that's 1/16" larger) on my 710 and the peddle is noticeably firmer. It's ... ok but wouldn't want more.
The S10 '77-'79 200sx has a 3/4" master and so does the 610/710/B-210 and they share the same piston cup part number. This doesn't mean the master is exactly the same ... just 3/4" but likely to fit.
The 620 is also 3/4" but the outlets are facing the fender and won't clear the strut tower on a car.
Second gen 200sx is the S110 '80-'83 and they had 13/16" master '80-'81. The '82-'83 S110 used a 7/8" master
So draynor1995 has a master cylinder going out on his 510 wagon and brake flui is going onto the floor boards it's gettin so bad.
We can locate a new master cylinder so... Will any other "easier to find" master cylinders work?
Please help and thx
Rock Auto has the correct master cylinder for pretty cheap, but I have and still use a 1978 Datsun 510 master cylinder in my 1969 race wagon.
  • 1 year later...
Easier to see the difference between the sizes!
Fraction  =         3/4                  13/16                 7/8                       15/16                    1"
Decimal =          .7500             .8125                 .8750                    .9375                    1.0000
Metric     =          19 mm           20.63 mm         22.250  mm          23.815  mm         25.4  mm
