DOOR PANELS??
  • Replies 12
  • 1 month later...
The mdf board is fine for these cars these days, cuz many aren't used as daily drivers, thus much less potential moisture damage (guess that could depend on where you are!), which is often what happened to them. Use a THIN foam padding, a THIN vinyl material (so it will wrap around the edges nicely), 3M spray trim adhesive, cut the mdf from a pattern clean & smooth, sand the edges of the mdf so they are a l'il rounded. The corners are the trickiest, so if you haven't done it before, get a buddy to help that has. If you've got the $$ to pay an upholstry shop, they can "stitch" in a pattern, similar to the factory "heat seamed" pattern, or something custom!
Also keep in mind that you can buy any color factory original USED panels, clean them thoroughly, and paint them with the aerosol vinyl paint. I just did it on my last beater project, and it turned out really nice! I have used a gloss black vinyl paint in the past, but I used a matte/flat black last time, and I think the flat looks better...........personal preference.
Check this guy out, he might make a custom set of ABS ones for you. More pricey...but it is laser cut ABS.
http://oldskoolvw.com/ --->Stuff --->ABS Door Cards.
And yes...it's my name on the website. He bought it from under me when I lapsed (for over a year i think), not intentional I'm sure. He's a good guy. I still own a few other oldskoolvws domains so no big deal.
  • 3 weeks later...
