Red 71 4dr - Carbed KA24DE
demo243
Well start with loading her up in CT - Had my good buddy Chris help me out and drive it over to the transporter
A week and a half later… Filthy… but made it to California. For anybody interested Golden Key Express was awesome! Very easy to deal with- only catch it it must be a runner. They were even nice enough to let me load all my spare parts in the trunk and race tires in the back seat
Once here I tore apart the 3.9 I got with that spare rear end and put in my spare LSD unit. Now I have a 3,9 LSD and a 4.11 in the car
Then I took her for a run up to busta's place
Then the following weekend down Skyline to 9 and back up highway 1
  • Replies 618
After seeing Kalani's dime and how quickly his paint came back to life I decided to save mine-
A little bit of elbow grease and some compound and then wax...
Not perfect but definitely brought some shine back.
Also did the compression test… but that info is a page or two back.
Changed her oil and even got my girlfriend to wash my truck … I just sat back and had a beer  B)
Then took her into the city before headed up to Busta's place again
While at Busta's I changed the motor mounts - hell of a difference- those pics are back a little ways… also noticed that my rear brakes were leaking… reservoir was dry… oh well filled it up and ripped the shit out of her the next day
Shots from the fun run -
Got here home and put her up on stands
Did some funky line bending… needed a 14 and 18" line… but Oreilly only had 12 and 20 so I got two 20s
Also installed some russel speed bleeders- Damn I should have done that earlier… so much easier!!! Ill try and get the part numbers latter
Anyway bleed the lines and there was a leak on the passenger side. wasn't stocked on the bend I did so I replaced that one again… bled the system… all was good… put some extra pressure on the pedal to make sure it was good… pedal went to the floor… a different juncture went out…
Decided fuck it and put the whole car up, time to rip out all the hard lines and replace them
Ended up pulling the whole rear end out while i was at it to make it easier to access the lines
Want to go find the guy who welded the exhaust together and smack him with an exhaust flange… Only one junction right after the header… that was it… so had to drop the whole rear end with the exhaust through the crossmember… tubes too big to pull through the x-member.
While it was up I also noticed the front fuel filter was filthy
So I replaced it… and replaced the rear and pulled that apart as well
Lots of crap in that one too….
Decided to clean my bench off before pulling all the lines so I finished up an old project of putting and open center unit back in the 3.7 I stole the LSD unit for the 4.11 from. Bringing my diff total to 3.7 Open, 3.9 LSD, 4.11 LSD and a dead 3.9.
Beers and Datsuns!
Then I got down to business and pulled all the hard lines- had to cut some of them to make it easier to get out
So now she sits… ordered parts and tools yesterday.
Ive got a flare tool, bending pliers, and 180 degree bender coming as well as 25' of NickelCopper brake tubing (supposed to be the easiest to bend), and a proportioning adjuster for the rears. Also picked up a Wildwood Reservior for the brake master to allow for more fluid on the rear end of it… hoping it fits… oh yea a velcro Fire Extinguisher roll bar mount as well. and the necessary T's and line nuts I will need.
So my current thought process is to get rid of the "safety" switch that is right after the master.  So basically the front brakes will go from the master to a T to each side. The rears will go from the master to the proportioning valve and then a T and out to each side. I think I am going to make a bracket and mount the proportioning valve inside the car next to the shifter on the passenger side.
Also to make it easier to run the front passenger line and to save some weight I am thinking about pulling my heater core… I am in Cali now! no need for that crap. And words of advice on removing that?
Also thinking about replacing the radiator since the coolant will all be drained. Sounds like the Koyo is the best option?
Here is a shot of my current "to-do" or thoughts list
Other plans while the car is up is to rerun the batter cable inside the car- should probably add a fuse???
New e-brake cable - ( would love to relocate that as well…. but more money… that Lokar handle looks pretty awesome)
Also thinking about replacing the clutch MC and line - both are pretty ugly. Is the clutch line the same size as the brake lines? slave cylinder was replaced not that long ago.
Further down the road…
I am really thinking about picking up a newer subaru 4.44 diff and swapping in an older center unit to make it usable.. to quick??
Also looking to swap in some Corbeau racing seats since they have a bolt in bracket for the 510
Then front and rear coil overs, with camber plates up front
….  the rest will be a long way off
Ive been busy-
Ripped out the heater core- should have done this a long time ago… nice to have the open space up in the foot well.
Also ripped out the stock e-brake handle.
Oh yea-  Christmas is coming early this year...
Got my brake stuff in the other day… this shit is a bitch to bend and flare…. and the worst part is I won't know if all my flares are good until i finish the whole system….
Will have some pictures soon.
Made a simple bracket to mount my Proportioning valve inside the car next to the shifter. just need to decide if I want to run my front portion of the rear brake line inside the car to the valve and then underneath after the valve… or underneath and pop it up inside the car to the valve and back under after. will probably do the later - under -> valve-> under as it should make for a cleaner finished look
Also ordered the lokar e-brake handle- going to fab a bracket under the car as a cable stop and use the stock wires from the split back. Will update with pics on this when it arrives but not till wednesday.
Ordered the Koyo Radiator… here on friday.
Pictures to come… hand tight… lots more work to do
Trying this from my phone... Pardon any typos
Teaser shots
Bending long brake lines is a bitch
That's the front "T" to pass line
Here are some teaser shots of my in car brake proportioning valve
Once I get the lines bent and attached I'll try and get some rubber edging to clean up the holes
What the finished in car proportioning valve will look like... Unfortunately I ran out of tubing so the out put line was too short... But apparently you can get 25' coils of nickle copper line from o'reilly pn# 3300cn so that will be at my local store tomorrow. Hopefully button up the brake system soon.
Slowly getting there... Again just praying my flares are tight...
sorry hosted on the ugly fbook….. will get em on photo bucket soon
…Because … RaceCar…. Proportioning valve set up inside the car and relocated e brake
…  my bench is too small...
Updated… reposted photos
  • Like 3
Ok another update…  Much more to come tomorrow and Monday. Hoping to get her back on the ground by monday night...
I have an awesome girlfriend. She felt bad for me crawling around on cardboard under the car so she got me a creeper
As i teased before I picked up that Koyo radiator so I started to mock it up
Some slight fitment issues… the brackets that mount it are a bit short so I will need to space it out with some washers or hopefully something nicer
More to come tomorrow---
I'VE GOT BRAKES!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
The project is not done yet… still need to adjust the drums… put the rear springs and diff back in and fill the radiator with coolant… but holy shit I have brakes!!!! about 30-35 feet of tubing including the clutch line and about 2 feet of wasted line.
FUCK…. Or Not….
Didn't put the springs back in before putting the crossmember back in and the soft lines need to be removed for the arms to drop low enough…. maybe if I had spring compressors I might be able to squeeze them in there… but need to pull the rear lines apart any way… didn't put the T split back in the same way…. and doesn't work well on the passenger side…. looks like the long line from the prop valve to split will be ok… but might have to rebend the two hard lines out of that….
Ok… All is well… Hopefully...
Seems like I got really lucky….
Undid the necessary lines, put the springs back in and rebolted up the rear end… got really lucky in that I was able to rebend the hard lines without removing them and make it work… not a pretty as it was before…  but after rebreeding the rear end it feels good. and so far no leaks… again...
hoping for the best...
Tomorrow I will run out and get a radiator cap and then probably bleed the brakes one more time, then put the diff back in and hopefully drop here and drive her!
Hopefully…
Too late for pics tonight…. more tomorrow
The car is looking good.  You going to be coming out to the ESCA autocrosses next year?  It would be cool to have another 510 out there.
For mounting the radiator, I like to use rubber mounts to help take some of the strain off of the mounting brackets.  Like these:  http://www.mcmaster.com/#vibration-damping-sandwich-mounts/=uu5nki
So she is back on the Ground!!
Took it for a quick spin around the block. everything seems ok… except my temp gauge decided to stop working… should have definitely gotten hot enough to register but the needle didn't move. It has been finicky in the past but I am nervous  to run it with out that gauge. Could this be from draining and refilling the system?  any recommendations on what to trouble shoot next?
Pics to come I promise! Need to pull em off my phone and onto photo bucket
Planning on it!
I should get some of those…
