Doty (Deal of the year)
skyblue
Cut a 1/4 coil from the rear this weekend.
2B9A06A4-8745-4C25-B700-3B09CCC6FC99_zps
Gave me about a 3/4 in. Drop
Before
B6A25F0F-D2C8-4C81-B374-691BC0C85AF8_zps
After
B3B5C090-F6B6-461B-BDF0-43DC5B4489BA_zps
Put the DR's back in rear to Check clearance.
B0D9D78C-7844-49F8-B257-A77C5C027BDF_zps
But, they rub even more now.
10C648F8-78F8-47F6-9F39-E28B20EBC3AD_zps
Driver side rubs more on "bump"
F8EBBFBA-6583-4093-ADF6-A0E98E43A628_zps
Passenger side
476B852E-8219-4981-ADD1-D4D4E3602CFE_zps
It was pretty bad so I put the snowflakes back on till I cut and weld the "bump"
DAC4BF4B-96F3-4303-959B-BC8FFF0AA272_zps
Looks pretty good. But, Still a little rake left so I might cut another 1/4 coil.
  • Replies 1.9k
I was able to run those wheels at any height, with a heavily hammered bump .. it didn't look pretty when you opened the door, but it got enough clearance. Cutting and welding might allow you to run a bigger tire.
This was the lowest I could drive, and it felt horrible (bottoming out shocks and bad camber/traction):
  • Like 3
Photo dump.
7D6885AA-22D8-43F3-B0B3-4CE8375F73F3_zps
E78C304D-DCD5-4163-B96E-257E4462EB95_zps
5D79E0FB-0AD9-4736-9C95-0F5E00C293B2_zps
Demo243 came by with one of his Rotas 15x7 +25 with 205/50 on it to see how it would fit. They fit great. And look bad ass.
65D74B56-DD6B-4271-AB40-0DC86654DF14_zps
7B57237F-2DE2-4362-B80E-68308D0CC06C_zps
427BD389-44DB-4DA6-9BD2-E6191CE5B88A_zps
And mine on the rear.
949E84EC-65F6-4469-9101-DC362BCCC5CF_zps
E660292B-BDF4-4C56-A503-0A06D80EB1E3_zps
BE5B05E0-1CC6-49F2-9E59-D570EC2A3DB6_zps
Still waiting on lugnuts and one more wheel. Lugnuts should be here tomorrow and the last wheel should be here next Monday from Ohio. :-/
lug nuts came In today! So I Mounted and balanced the other 2. And put on 2 up front. Mostly to see if they would give me any vibration at freeway speed. Cause even though they balanced I noticed they were a little wobbly on the balancer.
2E941518-A4BA-4245-B931-1A57B8C0411F_zps
47B833CC-1D8B-4D22-94E3-375DFBEC96D6_zps
7219C16C-EC08-4CD1-B8DE-D8389924C308_zps
Happy to report that there was no vibrating at freeway speed! Now just still need to cut the rear bump and wait for the last wheel to arrive.
And if there not DOT you won't run them on the street.who gives a shit enjoy them.
correct. its not an issue of giving a shit. but, the streets are mean around here. and even though the wheels are fairly inexpensive i don't want to be replacing one every time I hit a pothole or uneven asphalt and denting the shit out of them. DOT versions are thicker and can take a little more abuse than the race only versions that's why they are heavier. Its a function reason. If I had tanker money i would not have this concern. :thumbup:
Exactly, there like Bogart wheels and so forth just be careful.
