1974 Datsun 260Z for sale: Clean Title, Up to date,Drives Amazing! Los Angeles, CA
Hey everyone,
ASKING $3800 OBO OR TRADES
Early 1974 Datsun 260z
:+: Car’s info :+: 10/10
*Clean California Title
*Title in hand, I am the 3rd owner.
*Tags, registration, insured and “Zero” fees owed.
* 1974 so it’s smog exempt “woot”
:+: Engine/Trans :+: 8/10
*Original Inline 6- L26 (2.6 Liter) OHC Produces about 140-160hp.
*I did a compression test on it, and all 6 cylinders produced at least 180psi
*Clifford aluminum 6=8 manifold
*Holley 390cfm 4 barrel carburetor
*Holley tuned with .25 discharge nozzle and blue pump cam
*Header
*ZX Electronic Distributor upgrade
*MSD ignition coil
*Custom Strut bar
*Custom fuel hard lines
*Custom Wire tuck
*New Kyosan mechanical fuel pump
*New Duralast thermostat-water pump-belts- life time warranty
*New freezeplugs
*Castrol GTX high mileage 10w-40
** Original 4 speed manual 9/10
*Pennzoil 80/90 + Pennzoil Syncromesh (For transmission)
*Pennzoil 80/90 in stock open differential 3.54
:+:Cooling:+: 9/10
*3 row aluminum radiator
*2 (10”) Electric fans
*Adjustable thermostatic switch (Kragen) Lifetime (Temp set at 174 degrees)
*New Dayco upper and Lower radiator hoses
*New Polished 2X13” aluminum upright coolant reservoir
:+:Braking / suspension/wheels:+: 10/10 !
*Z32 (300zx) Dual Diaphram ABS brake booster upgrade
*S13 Brake master cylinder upgrade
*New brake hardlines
*Modern Motorsports 240sx rear disc conversion upgrade:
*MM Brackets, Z31 rotors, + 240sx rear calipers with Duralast Gold pads
*Front Calipers were rebuilt and they have P.B.R. soft Aussie pads.
*Front rotors are Brembo blanks.
*Sitting on Eiback Lowering Springs + 4 New Monroe shocks
*New all sway bar end-link bushings
*15” ZX swastika wheels + newer rear tires
:+: Interior / Exterior:+: 6/10
*Custom Dash (Aluminum formed)
*Custom Center Consol (Aluminum formed)
*JDM HUB
*Cheapo 330mm steering wheel
*Custom shifter
**2008 Mazda Miata MX5 seats! Brand new
*with the seat belt unit retrofitted
**Chrome Roll bar
**Rear Custom Strut bar
**Thin MDF wood grain panels / trim panels
**Stock gauges (all function)
**Acc/On/ Start switches
**LED bulb upgrade
*JDM/Euro amber tail lights
*New Winshield + rubber
*New Kia sportage door weather seals
*New Fox body mustang rear hatch seal
*Xeson front dam/lip
*Custom front grill
*Bosch 7” Motorcycle E-code H4 housings
*Generic H4 HID 6000k kit.
*Magnaflow XL muffer
*240z rear bumper with 240z front bumperettes.
*Vented Z hood with grills
Please give me a call or text to test drive her. (818) 748-7111
I am testing the waters and I have an early 1974 Datsun 260z for sale. I will consider cash offers as well as trades.
Description/Summary:
I am looking to sell or trade this cool Datun 260z as I am a bit bored of it. I’ve spent countless hours upon hours working on her and it was quite fun as well as a very enlightening experience. Now that it’s almost coming to an end, I need a new project. As I’ve always wanted to own a Z, I’ve done so and now I”ve gained a lot of knowledge and realization how much money and time it takes to own and maintain/restore one. I am looking to sell this car or trade it for a nice daily driver that either has 4 doors or large or just gets good mileage and practical for daily commute. With regards to the engine and drivetrain, it’s 10/10. She starts up every time, may it be cold or hot, no choke needed because of the dependable Holley carb set up. With regards to interior and exterior, she needs a little bit of work, but most of which I’ve done.
There floor pan is rusty and I’ve cleaned up as much as I could and Por15 treated it as well as Herculine truck bed lined it. She needs a little finesse and body work, and interior work. Floor pans should be fixed but can and will survive for a while.
  • Replies 5
  • 3 weeks later...
