Eagle_Adam's 74 620 DD
Bout damn time i started a build thread for my truck so here we go, I picked up this 74 620 autotragic about a year and a half ago looking like this
Had a blown head gasket, a warped head, i couldnt hear it run, and the bed was full of decaying yard debris was what i was told when i picked it up but for $150 it was worth it so i tossed it on a uhaul traler and towed it home
I dont have a lot of pics from what i did to the truck before i joined Ratsun (cus pics didn't matter till i joined :P ), but heres the story:
So began the to do list.
1. a good cleaning and a to do list ( which never seemes to end :P )
2. get it running
3. get it stopping
4. ................
So I got her all cleaned up and started dreaming as to what i wanted to do, now that she was not such a dirty little girl i figured i work on getting her heart beating again. I was told the head gasket was blown so i drained the oil and antifreeze and sure as shit they were mixed SO IT WAS OFF WITH HER HEAD!!!! After i got the head off it was obvious the cylinder walls needed cleaned and honed because i found sitting liquid in them. I ended up calling the guy i got the truck from to get some history and found out that he had the truck loaded with yard debris clear above the roof and blew the headgasket on the way to the dump. If you look at the pics from the day i got her you can see the yard debris have composted in the bed quite a bit so i figured the truck blew the head gasket and sat till i bought it -.-
Here was the engine after a good cleaning:
Rebuilt the original Hitachi carb
after an engine rebuild on the L18, a new empi carb, and a 5 speed
One it was running in driving i found a new seat with armrest and cup holders!!
Now that she was running and driving i was starting to feel brave so i started on body work and paint
stripped off the side molding and huge ass mirrors
Repairing dents in the tailgate:
Starting on the bed:
The truck needed new tires so once again it went up on stands so i could toy with it :)
stripped and cleaned
1st coat of primer
2nd coat of primer next to the 1st
shiny and painted :D
New tires, painted rims, and an alignment makes me happy ;)
  • Replies 285
At this point i had joined Ratsun, my truck had a rebuilt L18 and a 5 speed swap.
I replaced my dammaged passenger side fender with a NOS fender i got off CL.
To:
To:
And finaly:
I also had to jimmy rig my acceleration cable till a new one gets here cus it snapped angry.gif
Got new hood bumpers at some point too
The one in the middle is new the outside ones are the old ones
also had to replace the fuse box because of this;
This is the new fuse box installed
Got a new one piece drive line:
NOV 2011
i got hit by another driver on her phone a month or two ago and i finally have all the parts i needed to fix the damage caused. Sooooo i started down the road to recovery and imporvement:) I called my aunt to borrow her truck for a bit and started to strip mine down.. Time for a few pics
the replacement:
stripped and sanded
a fellow Ratsuner and i scrapped all of this undercoating vvv
out of here vvv
got por 15 on one of the fender wells
Well i cant seem to leave well enough alone, so now im going to POR15 the whole front end and the floor and back wall of the! smile.gif
I put the truck up on stands to do the next needed round of maintenance and upgrades.
On the list for this round is:
front wheel bearings and seals
breaks shoes on all 4 corners
wheel cylinders on all 4 cornersT
thermostat - DONE
heater core hoses - DONE
heater core valve - DONE
need to wire the lights for the tach - DONE
re-install the stereo - DONE
clean and refresh the heater core - DONE
replace the speedo cable - DONE
break springs on all 4 corners
clean the break adjusters on all 4 corners
drain and bleed the break system
install the DZ start module i picked up - DONE
figure out why only one headlight work when on but both work when the high beams are on :/ - DONE
& get the break drums turned - DONE (thnx to RedBanner!!!)
Paint the drums - DONE
Clean and paint the center console - DONE
Soooooooo, here we go :D
started today with Nismo Dr,Jassifrass, and nelsontr present, i wish my parking lot always looked like this! 610, 710, 210 all in the parking lot and my 620 in the garage with no work tomorrow :thumbup: 4198c861.jpgFirst up was the wiring for the tach and the mystery headlight issue, the tach was easy enough. Nismo Dr soldered a connection and regounded the tach and off we went!
The headlight issue was even easier, i put the wrong bulb in :blush:
Next up was the heater core and cooling system,Dropped in a new Nissan thermostat, installed new heater core hoses/grommets and refreshed/cleaned the heater core:
New foam seals
New hoses and grommets!
f5a031e7.jpg4378733b.jpg1532520a.jpgHeater core back in:4fa05ed1.jpg
What a KILLER deal for a sweet truck! B) I love an old stock/original 620 truck. Not running is the best cuz then you can got to town on it like u are. Keep us posted this one will be nice.
Painted the heater core cover and the package tray:
before
After:
before:
After::
Also painted the clips for the front of the heater core to match the fresh coat on the cover :D
Jumped forward on a few things in between coats:
A few days ago RedBanner game me a hand with turning the break drums!!!!
So i cleaned em up and painted them:
Got the DZ start button installed in the clam shell:
No kidding huh! the guy had yard debris stack clear above the cab and blew a headgasket on the way to the dump. Made it to his work and it sat there for an undetermined amount of time. So i towed it home, cleaned out the bed and tore off the cylinder head to find blown rings in one cylinder.
Ive done quite a bit to this truck to ill add more when o get a chance. Tomorrow i hope to tackle as much as i can on the list of to do's, im still waiting for parts from rockauto so the interior reassembly and DZ start will be tomorrow focus.
Hopefully i can have everything fixed up by Friday so i can get back to cruising with my pup
So out of all the Datsuns, and Datsun parts and other cool shit that is at my home 20, the only thing you decide to take a picture of is my brother and 620 brake drom and 4.23% OF A 1200 hundy coupe? WTF?!?!? :poke:
And any one noticeing i have a break lathe...... I sold it... Moments after we finished adams drums.... Or it was stolen... Or broken.... I broke into my brothers shop to use it. :ninja:
Wich ever sounds more believable :lol:
Fixed :rofl:
Wasn't my house greasemonkey, didn't wanna
Show off all ur toys ;) but ya, I could
Live in ur garage!!!
Understandable, but if you would have, just make sure you dont draw a treasure map, with a giant X
Duly noted, the flaired 2dr 510 with the cage was a dream come true to see! ive gotta make it to one of your races sometime.
This is awesome. I appreciate the fact that you're making it nice from the inside out, while still not neglecting the exterior. Good show.
Thanx micro! I've always focused on makin her run and stop but I do try to add the cosmetic fixes in when I can. One day she will be sitting on titans with a flat black paint job and the most annoying lime Green pinstriping I can find!!!
Thanks!! I am trying to take my time and do it right, it takes a little time to build a cage, and definetly need to make a race, would be nice to have some fellow datto guys out there showing some support
This topic is now closed to further replies.
