Dirttrack510 Posted July 7, 2015 Author Report Share Posted July 7, 2015 I'm considering building another engine like this one only with lower compression for street use. I'm thinking of using Chrome rings this time though. I've never used em before though. Pros / cons? Quote Link to comment
metalmonkey47 Posted July 7, 2015 Report Share Posted July 7, 2015 I had some in my LZ, noticed compression was a little low until you got the motor good and hot. Read that it's a common issue, I guess they just expand differently? Ran fin though. Quote Link to comment
Dirttrack510 Posted July 7, 2015 Author Report Share Posted July 7, 2015 Did they have blow by issues? Quote Link to comment
metalmonkey47 Posted July 7, 2015 Report Share Posted July 7, 2015 Nope, none. Dyno'd 104HP on a 38/38 Weber. It had Mahle 86mm pistons, only reason we used chrome rings was because it will be getting boost and EFI. I no longer own it, but a buddy that built it has it in his 521 rock crawler. Quote Link to comment
Dirttrack510 Posted July 7, 2015 Author Report Share Posted July 7, 2015 Cool, maybe I'll give em a try. Quote Link to comment
Stoffregen Motorsports Posted July 7, 2015 Report Share Posted July 7, 2015 Chrome rings are usually superior to cast or moly rings not only for their sealing properties, but for their durability. A low tension chrome ring will also have less drag to help free up horsepower. The packaging of LT rings is much more compact too, making it possible to keep the ring grooves above the pin on a custom piston. No more pin buttons... Detonation can cause rings to break. Cast rings are bad wih detonation, but a chrome ring can take a bit more. Chrome rings can take a bit more to seat properly though. I would not use a chrome ring for the first time unless you are starting with a freshly bored or power honed block. Quote Link to comment
Dirttrack510 Posted July 7, 2015 Author Report Share Posted July 7, 2015 The block I am planning to use shows minimal cylinder wear,I was going to just do a good hone job, as you can still clearly see the original cross hatch marks. Quote Link to comment
