derricks 69 datsun 1000 build
i dont know if i posted my 1000 or not i cant find it so making another.
been working on this for the last year. i picked it up 2 years ago for $200 bucks running but clutch and brakes did not work. as of now its bare metal waiting to get sand blasted.
my plans are to repaint it blue and have a rebuild a14 with a mild crane cam, double spring lifters, port and polished and a header. yet to get a carb set up. my bro gave me a set of 91 honda cbr 750 carbs (4 carbs). have a b210 drive train to pop under it aswell.
here are some pics
got an original crate engine for $400 a few months after i bought the car.
http://i245.photobucket.com/albums/51a3af06.jpg
pulling the engine
stripping in down bare
cut out the dash to get to more rust
this is my next project 1970 mazda b1800 i got for $100
  • Replies 41
Nice find and wow with the extent you are going with it. I was originally a huge Datsun 1000 fan. My first car was a 1000 coupe which I owned for about 12 years before only selling a couple years ago and have owned probably about 10 x 1000's total.
What are your plans for brakes? I know of a few little things you can do. Also check out these sites here in oz as there are still some 1000's kicking around.
datsun1200.com
datsun1000.com
datnet.org
ozdat.com/forum
Here is a couple pics of my first 1000 Coupe
Yes that is a 20B triple rotor, unfortunately I never got it finished and to the track.
Good luck with the build and look forward to seeing the progress.
Wow that's coupe is crazy. For the brakes I'm not sure kinda figure it out once I get there. There is a few set ups but there all from cars we don't have here or are just as hard to find here. I'm all over Datsun1000.com few of e guys have helped a lot the host gave me a few parts from Australia.
I used the rear disc brakes from a Nissan Bluebird/910 for the front but only 14" and bigger wheels fit over. If you want pictures of the conversion I still have access to my friends 1000 ute which I did the conversion on. Do you have the 910 over there?
Here is a link from Ozdat listing another conversion and mine.
http://www.ozdat.com/forum/viewtopic.php?f=31&t=20600
Also for a brake booster setup I used one from a Mitsubishi Lancer LB/LC or you call them a Plymouth/Dodge Arrow. Although they might be different as you are LHD. Bolts straight in but the only thing is you need to do is push a very small area of the inner gaurd in for clearence, only like and inch. This is what they look like.
yes, we go the Datsun 910. It was badged "810" and then "Maxima" over here.
We use the 910 rear brake calipers on Datsun 1200 fronts with 280ZX discs, all bolt on stuff
The Lancer booster we also use on 1200s, it comes on Chrysler badged mitsubishi cars.
  • 4 weeks later...
  • 7 months later...
march 11-13 my brother picked up the parts car an a13 and a header.
so as of now ill be finishing up my Z then ill dig my 1000 out and clean the sand out prob come the end of april.
i got a welder for christmas so i can start welding again.
im also toying with a fuel injection set up with 4 thottle bodies and a custom intake. but thats a ways away
here is what we all love pictures.
the welder
B3D32BA4-0A5D-464E-87D6-02DF7846441F-935
took apart the heater box. no holes but bad heater core. scored a can opener too.
FC736037-57A2-429E-B98A-58C2A12D8D27-785
FF1BB27A-58B6-4387-93F8-894D73EA430F-785
7EF8D3F2-0FE8-4581-BEDF-4559FC2E9A2C-785
loading newest tresure
barely fits
