Cooper - 1969 1600SSS Bluebird Coupe
Time for some panel beating...
Here is a look inside the fender well facing forward.
large.5a45de4965992_12232017cooperrepair
As I started to pull the fender out away from the unibody - I could confirm that the inner fender well was not damaged in any way.
large.5a45de4b00e63_12232017cooperrepair
I am NOT a professional - but besides the creases, a good bit of time with blocking, prying, and hammering eventually got things back into fender shape.
large.5a45de4c7abb1_12232017cooperrepair
Which shed a little light on the now obvious - the core support is bent back 90 degrees outside the headlight area.
large.5a45de4e0abad_12232017cooperrepair
Wavy gravy!
large.5a45de4f9ba38_12232017cooperrepair
  • Replies 305
I was going to remove the fender for better access to both sides but (and this should surprise no one) the very first bolt I removed broke.  I really didn't want to play that game so I just left the fender in place.
large.5a45de5552544_12232017cooperrepair
I am pretty sure the headlight assembly was not bent but just in case, I replaced it with a spare.
large.5a45de53131ec_12232017cooperrepair
large.5a45de57a92c2_12232017cooperrepair
Here you can see the result of the bent back wing on the core support
large.5a45de5b6ec01_12232017cooperrepair
I don't have a correct spare side marker but I do have this arrow style one I was going to use on Granny.  I'll use it here for now.
large.5a45de609a625_12232017cooperrepair
You can see the replacement turn signal lens here as well.
large.5a45de629a8b3_12232017cooperrepair
Sorry, I had opened the page before you posted more :) One trick is to go ahead and tighten the bolts untill they snap, rather than reverse which jams up the threads. Then run them through the rest of the way with a regular drill bit or from the back with vice grips or welded on nuts.
Yeah, I understand that works for the upper row of bolts but there is still the one behind the door, the one in the rocker, the one(s) between the fender and valance, and the one(s) between the fender and core support.  I'm sure something else would have gone wrong - especially since the lower rear of the fender is completely rotted away.  I just wanted to get back on the road. It's way more fun to drive than to look at in the garage.
First test drive went well but I found I have no right blinker.  Hopefully just a bulb needs to be replaced behind that new lens as everything worked fine before the incident.
Got a Christmas present from Japan!
large.5a495fbd00abf_12292017coopergrill(
A box of Japanese newspaper!!!
large.5a495fc569da5_12292017coopergrill(
large.5a495fcab7bf0_12292017coopergrill(
The packing job was really nice but even so, this grill is pretty heavy and the screen sticks out past the main structure and so at some point in the trip it tried to get out of the box and ended up folded over but I should be able to straighten it out okay.
large.5a495ff14c191_12292017coopergrill(
  • 4 weeks later...
It's been so nice driving Cooper again.  I'm reminded that I need to fix the exhaust though.  It makes an annoying buzzing sound as you go up through the revs.
In the mean time, I found one of these!!!!  Excited that I'll have the right parts to put the car back together with eventually.
large.5a6cc0ea90cf2_01252018cooper.JPG.7
And in the mean time, I can replace the corrugated hose I'm using for the defroster vents with proper ones from Japan.  Also got a fuse box with correct JDM cover.
large.5a5ac960e661c_01112018cooper(2).JP
  • 1 month later...
A Datsun guy in the U-district was having to move from his place.  He had already sold his car and had a few leftover parts.  I told him I'd help him find a home for them and after I was done loading up the truck, he comes running out with a brand new set of RetroBelt retractable seatbelts which he no longer had use for - and just gave them to me.  What an awesome community we have!
This is the kit - I've installed as set in one of my old wagons.
https://www.retrobelt.com/products/european-style-shoulder-belt-with-hardware-included
I was excited to put these in my coupe because the belts in there now (from an early Z-car) are quite worn and constantly have to be adjusted and being non-retractable, are always in the way getting in and out of the car.  Not so with these:
large.5ab1727ff2479_03162018cooperseatbe
Out with the old:
large.5ab17283d9469_03162018cooperseatbe
In with the new
large.5ab17287d7175_03162018cooperseatbe
Takes 15-20 minutes per side and you don't even have to remove the seats.
Old on left, new on right.
large.5ab1728b35f8e_03162018cooperseatbe
The only thing you have to watch for is that the belts are originally designed for two lower mounting points.  Since the 510 only has one lower mounting point, the retractor and fixed end mount to the same bolt.
large.5ab1728f932e4_03162018cooperseatbe
When you tighten the bolt, the fixed end is pressed against the real and provides too much friction for it to work smoothly
large.5ab172927f83f_03162018cooperseatbe
So I put a lock washer in between the fixed end and the retractor and that eliminates the issue
large.5ab172956ae4a_03162018cooperseatbe
large.5ab172977e501_03162018cooperseatbe
I was going to install the lap portion of the old belts in the back seat but couldn't find any anchors.  They may be under the folding rear seat back.  I'll have to look again when I'm more motivated as I'll have to figure out how to remove the seat.
large.5ab1729996d7d_03162018cooperseatbe
large.5ab1729bf100f_03162018cooperseatbe
I have contemplated installing retractable belts, but I actually don’t mind my non-retractable seat belts (not stock, unsure what they came from). I have mine adjusted so it’s just snug on my torso. Makes me feel safer even though it probably isn’t.. I have the passenger belt adjustment almost maxed out to the shortest length so it’s not piled on the seat/floor, and to keep it from flapping in the wind. I rarely have passengers, so it’s mostly unused.
Those seatbelts look nice. The price is reasonable, but I’m not fond of the country of manufacture.
  • 2 months later...
  • 2 months later...
Paul and I put in an order with Futofab for parts for his '68 bluebird 4dr and crash repair parts for Cooper.  It was a FutoFabulous delivery!
large.1159097319_04112018futofabulous(1)
large.1081329067_04112018futofabulous(2)
large.926108965_04192018cooper.JPG.46b91
But before I could get them home, another nice big rock chip to go with my now cracked windshield.
large.1464602898_04172018cooper.JPG.5bec
I made another half-hearted attempt at getting Trouble on the road to take to Canby but it just didn't happen so Brenda and I loaded up in Cooper and headed down.
We took the Canby Ferry this year just for fun.  Let me assure you - that ferry is NOT made for lowered cars!
large.1528495458_06092018Canby2018(2).JP
And this is what Canby looked like when we rolled in!
Super glad we went - as always.  But the ride home was a little rough.
The weather cleared up for Sunday so that part was good but there was a huge accident just south of exit 68.  Fortunately, we were watching the the reports and ducked off I-5
South of the accident, getting back on the freeway at exit 68 (Hwy 12) and avoided the whole thing, but after a mile or two I heard a big *clank-ting-BRAAAAAAAAAAAAAP*  as it sounded like the exhaust blew off! We had another 100+ miles to go and let me tell you something.  It was LOUD!!!  I had a massive headache by the time I got home.  Turns out there was a reason it sounded like an open header...
Check out the end of the Y pipe
large.52240535_06132018cooper(2).JPG.29b
large.1893988699_06132018cooper(1).JPG.2
Fancy cars have exhaust cut-outs like this for performance right?  : )
This might be just the thing I need to finally take Cooper off the road and put it under protection until I can restore it so the body rust doesn't get any worse...  I really miss driving it this summer!
large.264395828_06172018cooper(1).JPG.51
large.296799354_06172018cooper(2).JPG.0a
large.1063519416_06232018cooper.JPG.e559
Such a pretty car!
  • 1 year later...
Time flies and plans change.
My green FJ car needs some work and Cooper was the closest road-worthy replacement in my garage so it was time to put it back into service.
But first - a little rewind...
It snowed a little last year!
large.632892861_02042019coopersnow(1).JP
large.1321827527_02042019coopersnow(2).J
large.767621288_02042019coopersnow(3).JP
large.418249732_02042019coopersnow(4).JP
large.701586893_02042019coopersnow(5).JP
large.334017025_02042019coopersnow(6).JP
large.1781590325_02042019coopersnow(7).J
large.1263416308_02092019cooper.JPG.e89c
And then it REALLY started to snow.
large.1033501492_02122019cooper.JPG.5e27
Notice the tree behind the car broke and landed on the roof (no harm, it was protected by 6-8" of snow at that point)
The weight of the snow on the windshield actually folded over and broke one of the wipers if you can believe that!
