Jester Posted May 13, 2008 Report Share Posted May 13, 2008 A bit of talk going on in the truck section on my new KC. Thought I would start a new thread here to keep the added threads to a min. Heres a few shots that aren't in the other. Fairly complete all brown interior. I do have the tray. Steriod: This is the chalky crap I was talking about. This is the worst spot. Not to sure what to do here as Steriod says these are RARE and hard to get hold of. Color is faded BAD!! Anyone have an extra light cover for this? Floor boards looked pretty good after cleaning Quote Link to comment
Jester Posted May 13, 2008 Author Report Share Posted May 13, 2008 As you can see, someone did a little HACK job on the wiring. The second photo shows a pic of the cluster of relays. Are these ALL correct and which one is missing. There appears to be a spot for one more under the one on the left (closest to the headlight). Starting from the Right (windshield side) I BELIEVE it goes; Ign relay, Horn relay, then it should be a 4 pin plug for the Choke relay, and then ????? Where should my wiring be plugged into? The wiring on the 620 site just isn't clear to me. But, I'm not an electician either. Quote Link to comment
]2eDeYe Posted May 13, 2008 Report Share Posted May 13, 2008 Anyone have an extra light cover for this? Those come up from time to time on ebay, just keep an eye out. Quote Link to comment
Icehouse Posted May 14, 2008 Report Share Posted May 14, 2008 What about a full truck shot from the outside :D Quote Link to comment
Icehouse Posted May 14, 2008 Report Share Posted May 14, 2008 Orange is my favorite color!! What are the plans? Quote Link to comment
Jester Posted May 14, 2008 Author Report Share Posted May 14, 2008 It does look Orange, but, it's actually a butterscotch color. I want to turn it into my new daily driver. I love my '76, it's just too damn small for me 6'1". Having a tuff time getting it to run. It gets power to both sides of the coil with the key at the on possition. Has the matchbox dist. Any thoughts? Quote Link to comment
Bleach Posted May 14, 2008 Report Share Posted May 14, 2008 verify spark replace plugs anyway spray a little starting fluid in there (if it fires, then it was a fuel issue) Quote Link to comment
]2eDeYe Posted May 14, 2008 Report Share Posted May 14, 2008 The negative side of the coil should only get flashes of power as you turn over the motor. This is the signal for the coil to fire. If there is constant power to the negative side when your turning it over then your module may be toast. Check that, then go through the list Bleach gave ya :) Quote Link to comment
Jester Posted May 15, 2008 Author Report Share Posted May 15, 2008 Thanks for the ideas. I didn't think both sides of the coil should have full power with just the key in the "ON" position. The PO did some fansy wiring and I suspect that is part of the problem. If you guys could take a look at the above pictures and tell me what, if anything, is missing that would be cool. I think I am missing a relay and that the one on the left is not correct. Thoughts? Quote Link to comment
Jester Posted May 16, 2008 Author Report Share Posted May 16, 2008 Went and took another look at the other KC ('78) the guy had. It DEFINITELY has a 5 speed. The sticker on the tailgate is still readable through the crappy rattle can paint job and I CHECKED the pattern for sure!! It also has an unmolested wiring harness for the engine. It appears to have a mix-match interior. Black dash but everything else seems to be brown. Even has the corner pieces and back for the KC in brown. SWEET!! Drivers floor was absolutely shot but well worth the $50.00. :D I'll post a few pictures of my new parts truck later this weekend. Thanks for all the feedback on my projects. You guys are all a lot of help. Jes Quote Link to comment
]2eDeYe Posted May 16, 2008 Report Share Posted May 16, 2008 How many 620's does it take to get a nice driver? As, many as it takes. :D Quote Link to comment
Jester Posted May 16, 2008 Author Report Share Posted May 16, 2008 I'll tell ya, my Hustler is just plain awesome! I love it! I just need some more room inside. How many?? As many as the wife will let me buy. :D Quote Link to comment
Jester Posted June 24, 2008 Author Report Share Posted June 24, 2008 Scored some 18" Titans tonight for $100. No center caps but I don't give a crap about that. Figured everyone knows what the look like so no pictures. :D Later Quote Link to comment
Bleach Posted June 24, 2008 Report Share Posted June 24, 2008 six spoke or five spoke? Correct bolt pattern or incorrect bolt pattern?!? :D lol Quote Link to comment
Jester Posted June 24, 2008 Author Report Share Posted June 24, 2008 six spoke or five spoke? Correct bolt pattern or incorrect bolt pattern?!? :D lol :fu: Oh, You mean I don't have the four bolt wheels?:blink: SHIT!!! Thinking 225-50-18's. Quote Link to comment
Bleach Posted June 25, 2008 Report Share Posted June 25, 2008 :fu: Oh, You mean I don't have the four bolt wheels?:blink: SHIT!!! Thinking 225-50-18's. I ran 225/45/18 I was actually hoping you did not get the 2005+ Frontier wheels as their six lug pattern changed spacing. Quote Link to comment
Jester Posted June 25, 2008 Author Report Share Posted June 25, 2008 I know I haven't been posting a lot here, but, I do read as much as I can. Plus, with everyother new guy that signs on asking about Titans.......:blink: Quote Link to comment
Jester Posted July 22, 2008 Author Report Share Posted July 22, 2008 Did some MORE swapping of parts tonight. Finally go the other KC home and have torn the living shit out of it. Used the wiring harness from it and the good KC to make one good one. Got the relays all dialed in. Working on getting the 5spd. out of the shit bucket to put in my good truck. The back panel and both side panels for the KC were in tact and in good shape. And brown no less. The inst. panel was perfect! Kept the slider in the back window. Nicely tinted and in good shape as well. Stole a bunch of parts in the doors to get the other one in good shape. Now BOTH doors close and have windows. I have been looking at all the pictures that Bee posted in the 620 threads. There was one truck in particular that had a "75? grill in a KC. Looked bitch'n. I have been thinking of doing the same thing. Well, I finally did it tonight. I couldn't bring myself to just throwing the crappy looking '78 grill in my nice daily, so, I gave it a shot with some Krylon Fushion. I used the "Nickle Shimmer" color. Damn does it ever look good. I'll try to remember to post some pics tomorrow. It's a little too dark to get any good photos tonight. Quote Link to comment
Jester Posted September 1, 2008 Author Report Share Posted September 1, 2008 Hey all. Have a question. I tried looking at the 620 site for head info, but, it's down. I have three heads to choose from. U67 W53 W58 Please don't ask if they are open or closed. I have no idea at this point. In general, which one would be a good choice for a daily driver with a stock cam (for now) and bottom end. Have a Holley 32/36 waiting for a home. Looking for a set of smog free manifolds for it too. Quote Link to comment
datzenmike Posted September 1, 2008 Report Share Posted September 1, 2008 U-67 has the square exhaust ports so you would need a matching square exhaust manifold for it. The W-53 is about the same as the U-67 but the intake ports are smaller The W-58 is very basically a U-67 but with round exhaust ports needing a round exhaust manifold. Here's a closed chamber, or p-nut head: http://i138.photobucket.com/albums/q251/datzenmike/01300019.jpg[/img]"] Here's an open chamber head: http://i138.photobucket.com/albums/q251/datzenmike/motorW-58openL20B78620.jpg[/img]"] Quote Link to comment
Jester Posted September 2, 2008 Author Report Share Posted September 2, 2008 OK. So the W58 has the crap in the exhaust. Is it removble? Are these an open champer head only? Are they in the U67 also? Right now the KC has the W53. I will be putting new exhaust and intake manifolds (and gaskets) on so why not do a head gasket and see how things look on the topside. Should I just leave it or do some swapping? Thanks for the help Mike!!!! Quote Link to comment
Jester Posted September 2, 2008 Author Report Share Posted September 2, 2008 WOW! I need to update some photos here. I've been so damn busy this summer I have just been pecking away at little shit till this weekend. I pulled the engine and 5spd from the parts truck, pulled the rebuilt engine out of the good KC, put the 5spd behind the rebuilt and reinstalled them together. Repainted the engine bay flat black and left the engine blue. (Po's color choice) Not a lot of progress on the interior. I did order a new set of brass shifter bushings so that's one less rattle to listen to.:D Scored two gallon of OSU orange paint from the painter on the job site. :rolleyes: He said just scuff it, wipe it and shoot it. It's kind of a satin orange. Will look bitch'n with a satin black windshield cowl, hood and the top part of the fenders. Thinking I may have to have the Titan's painted too.:cool: Quote Link to comment
Jester Posted October 7, 2008 Author Report Share Posted October 7, 2008 Hey all, Got it running last night. I don't have the radiator in yet, so, it was just a short little burst. Got the fuel pump and new carb primed, set the timing mark at 10 deg (for now), cranked the dist. close to fire point and she fired RIGHT NOW! The wife and daughter came running out when they heard the exhaust coming from the GSXR muffler I put on. :D Fuck'n sounds cool! Felt good to have all the effort I've been putting into this damn thing pay off. So now it's time to find a VW alum. radiator and get that sucker mounted. I want to drive this SOB! Finally switched back to 5-8's instead of 4-10's at work. Should be able to take some pics in the daylight so I can update this thread. Quote Link to comment
Jester Posted October 8, 2008 Author Report Share Posted October 8, 2008 Went to the wrecking yard today and ordered my radiator. Went to just look at some alum. radiators and the guy behind the counter asked what year. I told him they don't have what I need I just want to look. As it turns out he had a 521 that he put a 90's Volvo 240 radiator in. He is getting me the entire system for $65.00. Right now it's in Portland and will be here in a couple days. I don't get paid till Thursday so I'll just have to wait. Also, took the washer bottle motor apart to clean it. It wasn't working. Imagine that. LOL The old hose was rotted so I used a 1/2" vacume cap that I cut the end off of and it fit perfect. No leaks. Quote Link to comment
