Just Joel Posted June 3, 2012 Report Share Posted June 3, 2012 Does anyone have a link to an install guide/write up for this? Or if not, could you give me a short tutorial of the steps, in order for completing the install on my 71 wagon? I've searches with little results and as I'm confident I could probably complete the task on my own, a little help before I start would be much appreciated. Thanks Joel Quote Link to comment
Laecaon Posted June 3, 2012 Report Share Posted June 3, 2012 Well the channel stuff is just held in by very old glue. Remove it, all the way into the door. It would be wise to remove the window. You can install the new stuff with or without glue, I didnt use glue and it holds fine. Inner squeegee is glued in, you will need to take a pick or something and remove the old stuff, That took some time for me. Installing the new stuff, I suggest making sure you can get it to sit right, And when you can, then you can glue it in if you wish. Outer Squeegees, these are a pain. Get the Door trim off. You will notice staples holding on the squeegee, undo the staples (they are probably very rusty). Now the squeegee can come off. The new squeegees should have come with clips to clip it onto the door trim. Reassemble anything you took apart. 1 Quote Link to comment
Rustina 510 Posted June 3, 2012 Report Share Posted June 3, 2012 GReat write up jakester Quote Link to comment
macgyver Posted April 15, 2013 Report Share Posted April 15, 2013 Well the channel stuff is just held in by very old glue. Remove it, all the way into the door. It would be wise to remove the window. You can install the new stuff with or without glue, I didnt use glue and it holds fine. Inner squeegee is glued in, you will need to take a pick or something and remove the old stuff, That took some time for me. Installing the new stuff, I suggest making sure you can get it to sit right, And when you can, then you can glue it in if you wish. Outer Squeegees, these are a pain. Get the Door trim off. You will notice staples holding on the squeegee, undo the staples (they are probably very rusty). Now the squeegee can come off. The new squeegees should have come with clips to clip it onto the door trim. Reassemble anything you took apart. I know this is an old thread, I'm in the middle of disassembly and so far it's all straight forward except this outer stainless/chrome door trim...Do I need to take off those clips that are inside the door panel? I popped one off and it looks like it just holds on the rubber squeegee in place??? Any help would be great... Thanks... Quote Link to comment
Laecaon Posted April 16, 2013 Report Share Posted April 16, 2013 To get the outer stainless off. Simply pry straight up. I hate this, as it feels like you are scratching paint. Do it evenly, to avoid bending the stainless trim. Once up, you will notice like 4-5 clips in the stainless, keep those attached. More importantly you will see staples holding the rubber onto the metal. Remove the staples / remove the rubber. Place new rubber in place, and use the clips that came with the rubber. You may need to trim the piece. Reinstall trim. Quote Link to comment
nismosilvia Posted April 16, 2013 Report Share Posted April 16, 2013 AH a few days to late. I fed up the stainless on one of my doors by thinking it was the staples holding it to the door not clips. Live n learn Quote Link to comment
Just Joel Posted April 16, 2013 Author Report Share Posted April 16, 2013 Ha, I forgot about this thread :) Funny part is I still haven't got this done yet :( Quote Link to comment
darc510 Posted April 18, 2013 Report Share Posted April 18, 2013 Love it when I just start to give some thing a little attention on my car I find the thread I need right at the top :) Just needed to make sure the felts could go in without glue...they will, thanks guys! Quote Link to comment
TENDRIL Posted April 19, 2013 Report Share Posted April 19, 2013 where did you guys get the felt? Quote Link to comment
Laecaon Posted April 19, 2013 Report Share Posted April 19, 2013 I got mine at DLSC. Quote Link to comment
Just Joel Posted April 20, 2013 Author Report Share Posted April 20, 2013 I got mine at DLSC. ^^^^^ this ;) Quote Link to comment
h2oprint Posted April 22, 2013 Report Share Posted April 22, 2013 What is that place? 1 Quote Link to comment
DatMo Posted April 22, 2013 Report Share Posted April 22, 2013 where did you guys get your stuff? I need all the channels and rubber for my door windows. inner and outer. i also need rear window. edit: how is the dtls stuff? good quality? edit again: lol. what is the felt exactly? Quote Link to comment
TENDRIL Posted May 7, 2013 Report Share Posted May 7, 2013 the felt it runs in the canal where you window goes up and down Quote Link to comment
TENDRIL Posted May 7, 2013 Report Share Posted May 7, 2013 http://www.frsport.com/Nissan-Genuine-OEM-Datsun-510-Glass-Rubber-Weather-Stripping_p_32907.html Quote Link to comment
Laecaon Posted May 7, 2013 Report Share Posted May 7, 2013 that looks like it would fold to become channel felt... other than that, I dont recognize it at all. Quote Link to comment
TENDRIL Posted May 7, 2013 Report Share Posted May 7, 2013 it looks really sturdy and i think im going to order a roll, and see how much it can do, it looks like maybe two doors, but i kind of like the rubber inside the felt? Quote Link to comment
Laecaon Posted May 7, 2013 Report Share Posted May 7, 2013 but i kind of like the rubber inside the felt? ? you want felt, its easier for the window to glide on, and wont stress the window regulator, or break your window crank. Quote Link to comment
dakotahchore Posted May 8, 2013 Report Share Posted May 8, 2013 Just buy DLSC felt. It fits well and there's enough for two doors in each roll. Why cheap out and have a shabby fit or improper materials? Quote Link to comment
TENDRIL Posted May 8, 2013 Report Share Posted May 8, 2013 its genuine OEM nissan, we will see i just ordered it 54.00 usd for 17' roll :w00t: Quote Link to comment
TENDRIL Posted May 8, 2013 Report Share Posted May 8, 2013 ? you want felt, its easier for the window to glide on, and wont stress the window regulator, or break your window crank. it does have felt on all the sides that the window would touch Quote Link to comment
tr8er Posted May 8, 2013 Report Share Posted May 8, 2013 I'll be watching this for the results. You must post when you put them in. Quote Link to comment
TENDRIL Posted May 14, 2013 Report Share Posted May 14, 2013 just got the roll today NISSAN part number H0335-89931 apparently it fits other models also B110 B210 510/610 130/C30 Quote Link to comment
Duncan Posted May 14, 2013 Report Share Posted May 14, 2013 Nice! Will that do 4 doors? I need some for my goon. Quote Link to comment
