How to remove airbag(s) from WRX seats
Mr. BOHICA
This is all straight-forward and easy to do. This is a good idea if your running the seats. I would think that the likelihood of the airbags deploying on their own is low but it's better safe than sorry. Usual disclaimers, I'm not responsible for you activating said airbag and breaking your stupid neck, yada yada, here goes:
Airbags are located on the side:
Unzip seat covers, two zippers on the back, and pull it up to locate the module:
Pull back the padding and locate the two nuts (that's what she said.) Remove said nuts and pull out the module. For safety's sake, keep the airbag "front" pointed away from you:
Cut the lines and remove them from the seat frame. Install padding to fill the void left by the module and zip er up, your done!
  • Replies 10
as funny as that sounds dont do it i set off an air back in a parking lot with the bag facing up and it shot 30 feet in the air
we have to blow them off before disposing, two will lift a dumpster 4 feet off the ground, at the Chevy dealership I worked at in Phoenix we had 4 or 5 hanging from the power lines like they were high tops in the ghetto
