Best way to eliminate manifold water passages.
68Datsun510
  • Replies 6
1/4 inch pipe plug.
1/4 inch is the allen size. go to a good hardware store and theyll gove you the correct tape for it.
If you have a stock head with the stock water passage hole all you need to do is run the tap. as the hole is already the correct size or close to it already so no need to hole size it for the tap.
my cheat sheet shows
1/4 plug NPT
1/4- 18 NPT
use a 7/16 drill bit if needed. If close to 7/16 just use the tap/
Keep it if possible. It warns up and drives better sooner with it. On really hot days with high under hood temps, or if you have a lot of radiant heat from a header, it actually 'cools' the intake. It keeps the intake air at a more constant temp over a wider range of applications.
It doesn't get particularly cold here, coldest we've EVER had was 16. Ave mid 30's for lows at worst. Im just wanting to avoid the whole, pull the intake, flood the garage with coolant crap. Thinking of just plugging the head holes and be done with it.
