Zeusimo Posted January 3, 2014 Author Report Share Posted January 3, 2014 At This Point I Started The Motor And Drove It Around Parked It And Came Back Half Hour Later To Check For Leaks Sure Enough It Was Leaking Water Looked Around And Narrowed It Down To The Rear Freeze Plug Said The F Word A Few Times And Pulled The Motor... Again Quote Link to comment
Zeusimo Posted January 3, 2014 Author Report Share Posted January 3, 2014 I Replaced The Freeze Plug And Pressure Tested The Motor Out Of The Car To Make Sure It Was Good Installed Motor Again And Bled The Cooling System Quote Link to comment
Zeusimo Posted January 3, 2014 Author Report Share Posted January 3, 2014 Rebuilding This Motor Was A Big Pain In The Butt Running Back And Forth To Napa And The Machine Shop But The End Result Was Worth It 1 Quote Link to comment
Zeusimo Posted January 3, 2014 Author Report Share Posted January 3, 2014 I Know, The Hood Is Ugly... Too Lazy To Paint It 1 Quote Link to comment
Eagle_Adam Posted January 3, 2014 Report Share Posted January 3, 2014 came out lookn good man!!! Quote Link to comment
bonvo Posted January 3, 2014 Report Share Posted January 3, 2014 whats the deal with the cluster of red wires coming from the engine to the strut tower? home made ground strap? Quote Link to comment
Zeusimo Posted January 3, 2014 Author Report Share Posted January 3, 2014 Yeah When I First Started To Crank The Motor It Wouldn't Because Everything Had Been Painted So I Got A Couple Of Wires And Half Assed A Ground Together I Already Installed A Proper Ground I Just Didn't Want To Go To Walmart At 2 In The Morning Quote Link to comment
Zeusimo Posted January 13, 2014 Author Report Share Posted January 13, 2014 Finally Have A Job Now Going To Catch Up On Bills This Month Then Start Fixing Shit!! Quote Link to comment
