Project Pistachio
Zeusimo
  • Replies 132
  • 3 months later...
I Also Threw Away That EI Dizzy I Put On
Rebuilt Dual Points And Runs Smooth
There Was So Much Shaft Play In The EI Dizzy
That The Rotor Was Eating The Dizzy Cap!!
I Also Picked Up Another EI Dizzy With No Shaft Play
I Already Rebuilt It...
But Not Enough Hours In Each Day To Put It In
Replaced My Leaky 13/16? (Stock) BMC
With A 15/16 280zx Master
Used Stock Adapter And Rotated Reservoirs To Clear Strut Tower
The Brakes Improved But Now I Feel Like I Need A Bigger Booster
Anyone Knows What Fits Nicely?
Also Bought Some #200 GC Coilovers
Installed Them Real Quick
Same Ride Height Just A Bit Stiffer
I Picked Up 4 New Tires Today
195/55/15 BFG Comp 2
But Not Installing Up Front Until I Get A Proper Alignment
Still Need Front End Poly Bushings, RCAs,
Rabbit Inserts (For MOAR LOAR(And To Get Rid Of My Positive Camber))
I Also Have A Terrible Sound Comming From My Rear End
But No Vibrations At All
Upon Inspection I Found
I Do Have 1 Bad U-Joint
And My Pass Axle Has Either Snapped Or Is Stripped
I Have Already Bought A Set Of U-Joints
Pinion Flange/Bolt, Seals And Carrier Bearing
(Just Waiting For The UPS Man To Come By My House)
But I Was Thinking About Replacing
Both Axles With 200sx Disk Brake Axles
I Haven't Looked Into This Much But It Does Need Some Attention Soon
Gases ?
  • 1 month later...
