jarvitron Posted March 21, 2012 Report Share Posted March 21, 2012 Well, I know for a fact that you can use an MGB Cannon intake manifold to put a weber on a J13 (since that is what I have on mine), but has anybody ever tried using an MG (1800) header on a 520? I know it's a pretty simple flange design and it wouldn't be terribly hard to make a "custom" header, but I am secretly hoping that one of the cheapie Pacesetters will drop in. They're cheap enough I'll probably order one if nobody has tried it before, just seeing if I'm the only one. Quote Link to comment
merlin Posted March 22, 2012 Report Share Posted March 22, 2012 i read a lot about a series swaps into brit cars, but have never read about a j swap, but it might be worth googling it to see as im sure a header was likey part of the swap to make it fit. 1 Quote Link to comment
jarvitron Posted March 22, 2012 Author Report Share Posted March 22, 2012 The price for an "expensive" "ceramic coated" header for the MG is like $200 and I found an unpainted angle exit for $80 on Amazon. I am gonna go do some eyeballing to see if it'll clear Datsun engine compartment obstacles. I'm thinking the angled exit will work fine but who knows, maybe that first tube will ram straight into the fuel pump. It'd be worth $80 to me to get rid of the bohick lookin' plate I had to put in over the intake heat riser hole. Quote Link to comment
fletchmpoon Posted July 24, 2012 Report Share Posted July 24, 2012 I've got a Pierce intake and weber on my E1 (L320). I thought about doing the same thing. Did you pull-the-trigger on the header project? I was thinking that I could cut the header primary pipes and weld them into bungs/openings in a straight piece of 2 inch tail pipe (cap the front end, of course) and then just chase the same single exhaust pipe path out the back of the truck. Couldn't be any more restrictive than what I have now, would remove the hokey cover plate issue, I could control the length of the primaries and avoid fitment issues and who-knows.... it might be a decent mod. My only concern, without seeing the headers is the quality/thickness of the flange. Quote Link to comment
banzai510(hainz) Posted July 24, 2012 Report Share Posted July 24, 2012 I seen a header on a J motor and it was a leaky stinky son of a bitch Think it was from Pierce manidolds Quote Link to comment
ggzilla Posted July 24, 2012 Report Share Posted July 24, 2012 The J engine bolts in place of an Austin B engine. The Datsun A-series is totally different although of a similar size. Most people weld up their own custom header. Quote Link to comment
datsunaholic Posted July 24, 2012 Report Share Posted July 24, 2012 Big issue is clearing the steering box then the torsion bars. You would need a custom header; MG specific ones won't fit in the space available. Quote Link to comment
fletchmpoon Posted July 26, 2012 Report Share Posted July 26, 2012 Yep. That's what I figured. Cheap headers have crappy flanges and they leak.... Quote Link to comment
jarvitron Posted September 6, 2012 Author Report Share Posted September 6, 2012 I pulled the trigger but the headers are still in a box, unfortunately, my daily driver decided to grenade the engine and force an engine swap. After doing some tape-measure dangling it doesn't look good, I'll post pics once the shop is ready for the truck. Quote Link to comment
520datsun Posted September 9, 2012 Report Share Posted September 9, 2012 I have pacesetter headers on my j13 love em!!! Not a great fit but what else are you going to run lol...video on my post with straight side dump 2.5 exhaust...I also have a webber and an intake manifold from a mgb racecar setup pretty slick http://community.ratsun.net/topic/46703-steves-single-headlight-520/#entry749028 Quote Link to comment
