my first datsun
m_adamson_no_1
i recently obtained a 73 datsun 620 pick up in the process of puttin a small block 350 and 700r4 trans an comments or advice would b greatly appreciated
the truck
the motor
the trans
front clip removed
the motor set in place
again
inner fender well clearance driver
passenger
front clip set in place
  • Replies 15
Hmmmm... remove heater and start cutting the firewall and tunnel out.
Get a disc brake kit from on here. 'Cuz you WILL need to stop that thing.
Did you keep the torsion bars, I can't see them. If they are gone you don't need that bolt in brace across under the pan.
The diff is 4.375 and many 2wd 720s have 3.889 or 3.70 even down to 3.545 and lower that you can just. bolt the pumpkin in.
Someone asking about putting a V8 in a 620 is kind of cliche around here. Doing it is another story. Good luck with this.
removed all suspension out of front along w front brace installed aftermarket motor mounts/crossmember going to run a solid axle out of a 30s style chevy pick up and narrow it
ive got 95%of the stuff to install everything so just a matter of doing it lol
Sure is alot of negativity round here lol and for ur information its called a c-notch kinda have to cut out the bed and to not build something cuz the bed isnt bolted down is kinda a dumb reason if u read my descr it says FRAME OFF thanks for the motivation tho :-) and to pharough just running the leaf springs for now and itll b mono leafed in the rear w coils for now till i possibly link it
  • 3 months later...
