the Gypsy Green Goon
so i got mu goon 2 weeks ago and have been doing work sense then on it and i decided i wanted to start a build thread on here so this is it!
its a 71 pea green goon!
it was pretty stripped of everything when i got it. basically everything bolt on was already stripped off (carb, starter, distributor, radiator, alternator)
the drive shaft is missing as well and steering column was all messed up.
so far what i have done is get everything and put it back in so we could start it and see if it runs and it does!! hits on all 4 cylinders!
changed out the gas tank with a clean one.
stripped all the sound dampening tar shit off the floors
put in a new clutch master
replaced the left hub
new steering column
and replaced the window regulator because it didn't work at all. the window would fall every time
i know there is more stuff we have done to it but cant think of it at the moment but will be updating from now on out until its drive able!
doing the calipers and rotters this week!
and drive shaft
and everything else we can!
on the truck!
at the shop
back seat is in awesome shape too
window stays up :)
floors are pretty clean too!
except the drivers side but its not to bad
when it was running after got everything bolted back in!
will have more pictures up of the progress tomorrow
  • Replies 38
so today got some more stuff in on the goon!
new brake master
calipers
rotors
tail light lenses. well one of them
and prepped a few things for tomorrow!
tomorrow we are doing the drive shaft one new brake hose
new ball joints
and control arms for sure
how she is looking so far
old brake master
new shinny one =]
calipers and rotors.
so stoked maybe we will be able to drive it tomorrow!!
Thanks man:)
She is coming along nice:)
Today got one new ball joint and one used but still good put on
Two used but good tie rod ends
Some better. Control arms
Tie rod bushings
Sway bar bushings
Front band rear brake hoses
Got the drive shaft put in
Sorry didn't get any pictures today
Got a new used windshield but I have to get a new rubber! Don't want to put it in a used one ;)
Getting closer to getting her on the road!!
so this is the sad part because this is that part that is the distruction thread! we got another 2 door yesterday form a guy.. well the guy rob who got one of the 2 doors we found when we got all 5 of them got us this one cause it was already fucked and should be the one to get cut op and not the one we where which is... fixable.. with time..
but any ways this car was rolled atleast 2 times
the roof was caved slitly frame was kinda twisted.
rear control arms where bent. but the front floors where good the front clip and the rear spring mounts where good so we got it to cut up
cause i need the front clip for my 4 door cause it is kinda fucked cause i hit a gard rail with it.
and the other 4 door my buddy got needs floors and the spring mounts.
and the cutting begins
roof is gone
front clip is off
then we carried the car out side cause we needed the lift for some one who is actually paying!
its crazy how light they are with nothing on them.
2 of us carried it out side
but it was a pretty good day
also got some stuff done on the goon!
finished up the brakes
needed to replace the rear brake cylinders
and put in a seat! which is nice!
and got some nice ass vizors for the 4 door :)
hoping to drive it tomorrow!
got the other seat in today and took it for a drive around the block!! soo stoked on it! but the brakes felt like shit and we looked to bleed them agian and well the rear cylinder was puking every where on the left side so we have to change that out again and then tomorrow we are taking it for an alignment! soo stoked!!
so took it to get aligned and on its maiden voyage was interesting. we ran out of gas on the way. then got some in it then went to the station to fill it and then the tank started leking. we figured out it was the sending unit on top was not all the way tight. i think that was the problem any way. but then got it alined and it was pretty good has some positive camber but thats form the control arm stud is bent. need to fix that. and then on the way back to the shop the slave cylinder took a shit! and that was a good ride. then the front brakes over heated and we are not quite sure what is wrong with that. something with the master not releasing all the way i think. but we are close. it is fun to drive!! and it doesnt run to bad considering it has been sitting for 20 years
  • 3 weeks later...
so got her home finally today! so happy to get her home! we went and got the alignment re done and it still has some positive camber..
any one have any ideas on what might be causing it? let me know
but have the new windshield waiting for a rubber to put it in!
and got the roof rack that my buddy bought for me! love the factory racks they are sweet and done see enough goons with them!
but hoping to get a few more things done by the time of our 510 day cruse and BBQ cant wait!
I had the same wheels on my wagon. Easy way to clean them, get Napa aluminum brightener. Spray on, let sit for 30-40 seconds, spray off with hose. Before n after shots.... I did have to spray a little on and use a wire brush in the corners but easy as all hell.
Before
After
