Olivia - 69 2 door 510 sedan - fully built CA18DET
Engine: Ca18det
Cams: 260 duration / 8.8mm lift for intake and exhaust with adjustable sprockets
Valvetrain: Stainless intake / Nickel exhaust valves. All new valvetrain components (hydraulic lifters, valve seals, etc)
Block: Bored to 83.5mm
Head: 3 angle valve job
Pistons: CP 83.5mm 8.5:1 compression
Connecting Rods: Pauter
Turbo: GTX3071R
Fuel pump: Walbro 255lph
Engine management: Haltech PS1000
Injectors: 1000cc
Flywheel: Possibly a TODA? lightweight flywheel of unknown origin/construction... feels like aluminum
Wheels: Rota Grid-V 15X8 +0 offset
Suspension:
DP coilovers front and rear with koni inserts and 300# springs
DP camber/caster plates
T3 tie rods
Brakes: Willwood 4 piston calipers up front with 11" rotors. Single piston calipers in back. Stainless lines throughout with a 7/8 master cylinder
TODO:
  • Purchase new suspension bushings
  • Sway bar?
  • Wire windshield wipers
  • Need the top of the dash... if someone has one or knows how to get one, lemme know
  • Sand, primer and paint the rear fenders,
This is how I bought the car. There is a lot of terrible welding and the tunnel was cut to install the v8.
Here it is now
923470_10200463885151256_1788681381_n.jp
A picture of the V8, its a buick 215 (all aluminum but only 200hp)
I made a mistake.... shocks/brakes were terrible and I couldn't avoid the honda... :(
Pulling the V8
The ca18det i purchased (in pieces) ready to be freshened up
The previous owner somehow managed to snap the camshaft... still no idea how this happened.... i was surprised to say the least when I was taking it apart.
Making my own valve spring compressor because they don't make the one you need for the CA18 anymore
YES! CA18 is IN! (P.S. I'm not the tard that cut the core support to install a radiator)
From the front!
Ohhh yeah, turbo clearance is a HUGE issue...
  • Replies 982
This is the old crossmemeber... My welder got about 3 quarts of oil dumped on it, so it was toast... decided not to flip and buy something off ebay. 11.jpg
The crossmember I bought off ebay. I'd just like to point out that although these LOOK like they put the motor in the correct spot, they don't. It's too far tilted to the driver side. You can see if you look at the crossmember above that the motor will sit more flat if you use the flipped stock crossmember (and it costs less). Hope this tip helps someone else.
Installed!
This is how it sits just dropped in. Theres plenty of clearance. The biggest hurdle I personally faced, is where the turbo sits. I had a bottom mount manifold, I dropped it off to get flipped. I forgot this would invert the turbo..... to fix this, I had to rotate the turbo cartridge... which sucked!
The radiator I purchased from ebay. Seems to be of decent quality... some day I may pick up something better. I just miss driving the car so I want it running
Some Rota grid-v's I picked up. 15x8 +0 in gunmetal
Radiator installed, started routing hoses and brought out the wheels to start mounting
Side view. NOTE: I didn't cut the core support, previous owner did.... DICKHEAD!
Shot of the valve cover. Previous owner of the engine did this... i kinda like it... it's pretty subtle, it was hard to even get this shot, LOL
This is more than likely what I will put and keep on the motor. Same finish in purple.
Ahhhhhh yes... the joys of wiring an ECU
Mishimoto intercooler
Mocked up
Got my tires mounted! Dunlop Direzza 205/50/15! Some mild stretch...
Sard fuel pressure regulator, some lines and fittings and a walbro 255lph fuel pump
Front end with the wheels installed
Back with wheels installed.... need to roll the fenders... any tips?
FPR mocked up
Muh baby :)
Two other heads I have in the trunk. The person who I bought the car from was running the car on a 24v marine battery.... ?????31.jpg
Walbro fuel pump being installed
Dash being taken out and wiring being done. Anyone have hookups on a clean dash?
Everytning mocked up together... starting to get sexy....
Clutch Master/Slave cylinder
Test fitted... Need to make some holes so I can bolt it up
Turbo has been clocked (finally)
quick test run of where the IC piping will go. Needed some additional elbows, so I ordered those.
The new wiring harness, which I had to install. Pretty straightforward if you ask me... i really liked installing it!
In the process of installing new harness
The new license plate! ^.^
After the install of cams, valves, etc.... That is NOT obama in the background, even though it looks like him... but he can hook your grandma up with a reverse mortgage if she needs one :P42.jpg
All the crap I bought from a guy off zilvia.net.
The completed head!
Installing valve keepers... which was a pain in the ass!
completed head prior to install
All the goodies I installed into the head. There was a rad underneath, i didn't set it directly on the floor BTW
Thanks! I really appreciate the feedback. I must have written and re-written the text about 20 times, because i would be adding pictures and hit backspace, which was going back a page in the browser... kept causing me to re-start. I'll correct it. I've spent a lot of time on ratsun, just never had anything to add, so I never joined, just searched and read.
I measured my driveshaft. I need something 41" diff to trans. Any thoughts? Couldn't find a writeup about driveshafts and lengths.
I was putting new pictures up but they're all upside down... so I gotta wait to do that until i get to work.
MOAR OICS!!!!!!
I also cleaned and prepped the interior of the car with anti-rust paint. Probably throw some pictures up later.. it's just primer grey... not that impressive.
What am I purchasing tomorrow?
Coilovers
Haltech Platinum 1000
Wilwood brakes
I'm considering switching to a smaller t3 turbo but may wait. It really depends on how much money I have left after this sprint of buying.
Ran majority of wiring (since this pic, the cabin is all wired up with the brand new harness)
Picked up a new steering wheel
Picked up a dry cell battery.... fuck o'reilly in LB on spring. They sold me an incorrectly relabeled battery, didn't enter my waranty info so I couldn't exchange it for a good battery. Bought this instead.
Intercooler with piping... waiting for my BOV so I can install the rest
How the car sits now (wiring in front left is unused)
I picked 8 inch with 0 offset because i like the stance and was planning bubble flares from the get go. I've had 7 in in the past and although they're adequate I wanted to do the car exactly how I would have liked to with my other two (restricted by money because I was way younger).
The crossmember does suck ass and I'll probably swap it out.
I'd head out to the IE for a meet... theres a small track (adams motorsports park) which holds events thursdays i want to hit up... maybe i'll see you out there
Thanks fisch!
Picked up a Greddy Type-RS blow off valve, t3-50 trim, turbo manifold, external wastegate, haltech platinum sports 1000, 3 bar map sensor, troy-ermish coilovers (front and rear with koni shocks) and wilwood brake kit. Soooo..... i should have plenty of picks this next week! My GF will be gone next week so I'll have time to install all the goodies :D
Any tips on someone who lives in socal with welding experience who would be down to help me put together a transmission mount? I can throw some cash your way of course.
I'll be out of town, but when i get back on Monday... i'm installing this :D
t3 50 trim with a .48AR....
38mm wastegate
top mount turbo manifold.. (FINALLY)
haltech should be here in a week... going to ship the suspension out today if I can ditch work early. I think the brakes will be here towards the end of the week as well
It's been raining so I haven't made a ton of progress. I did get a few more parts back though. Here is my progress over the weekend. I'll have more parts later today so I should be able to throw them on Wednesday. Also, theres a local suspension guy (I think the shop is called DG Industries) who makes all the suspension for 510s... apparently even troy ermish rebrands his stuff. Sounds like his business might be in trouble... if you have suspension needs, hit him up! He specializes in 510 stuff and been in the scene forever from what I understand.
The new driveshaft :)
Turbo is clocked, got my silicone elbow and put the greddy blow off valve on!
Most recent engine oic.
It's raining.. so I can't work on the car... LAME... I put the haltech in but it seems like either the PNP harness or the wiring harness that came with the engine isn't actually a ca18det harness because it doesn't turn on. The blitz ecu does though, so I sent some info to haltech.. hoping to hear back in a few days so I can continue work. Should have coilovers and brakes this week... so I'll have even MOAR pictures this week.
Got intercooler piping sized up/cut.
Driveshaft installed
How it sits now
