TENDRIL Posted January 12, 2013 Author Report Share Posted January 12, 2013 sooo whats the rule with bondo can you apply it in below freezing conditions? Link to comment
TENDRIL Posted February 3, 2013 Author Report Share Posted February 3, 2013 oic dump of progress ... have about 12-15 hrs total so far with welding sanding hammering and bondo and motor cleaning fenders need a little bit of bondo work and should be ready for primer and the motor cleaned up, there was about a 1/2 in. of sludge all around the back side from a bad valve cover gasket 1 Link to comment
TENDRIL Posted February 3, 2013 Author Report Share Posted February 3, 2013 started on fixing the brake booster hole with help from a log and a rubber mallet i was able ti get a nice shape :geek: next i will cut the oval-ish piece fit it and weld in place Link to comment
Rocket Dog Posted February 4, 2013 Report Share Posted February 4, 2013 This is a great project. The only technical advice I'm qualified to offer is, switch from Pabst to something more drinkable. Link to comment
TENDRIL Posted February 4, 2013 Author Report Share Posted February 4, 2013 thanks lol its kind of a budget drink with me trying to get this truck to caNdy.. im just gland im getting hours in on this thing, working full time is a bit of a hinder on my truck but i told my GF and my self i will put at least 5 hrs a weekend into it until june and hopefully will have it together before canby 2 Link to comment
TENDRIL Posted February 6, 2013 Author Report Share Posted February 6, 2013 got this piece in tonight damn old sheet metal is tough to weld with a shit welder , it was fine on the new sheet metal, but as soon as i started to mate it with the old tin blow through everywhere... :ninja: Link to comment
wayno Posted February 6, 2013 Report Share Posted February 6, 2013 You cannot weld datsun sheet metal, it will either blow through or warp. Look how they(datsun) put these trucks together, they did not weld them, they spot welded them, your not going to find any real welding except on the frames. This is the only way your going to be able to weld sheet metal without issues, I put almost a whole kingcab together this way, and I have not had any issues with the welds. BTW, I did all my welding on my 521 kingcab with a shit harbor freight mig welder, did not even use a helmet on over half of it, I just aimed, closed my eyes, pulled the trigger for a second and moved ahead 4 inches, and repeated it over and over thousands of times. Link to comment
TENDRIL Posted February 6, 2013 Author Report Share Posted February 6, 2013 so with all those spot welds did you grind them smooth? and fill the spaces with bondo? Link to comment
wayno Posted February 6, 2013 Report Share Posted February 6, 2013 so with all those spot welds did you grind them smooth? and fill the spaces with bondo? Yes they were ground smooth by me, and then filled with bondo and painted by someone else, as I hate paint prep work, I have no patients for it, but I am trying to do the 520 project, that is why it is stalled right now. I did do some of the prep work, as you can see in this photo below, but I got tired of having to redo it over and over, so I sent it out. 1 Link to comment
TENDRIL Posted February 7, 2013 Author Report Share Posted February 7, 2013 going to be picking these up 2maro for the truck.. 130$ for all 4 cant beat that cant really read the brand and the lady didnt know what they were all she kept saying was they're "custom" dose any one know what brand? Link to comment
TENDRIL Posted February 7, 2013 Author Report Share Posted February 7, 2013 they are 15"s dont know the width but they were on an izuzu rodeo Link to comment
jrock4224 Posted February 7, 2013 Report Share Posted February 7, 2013 You cannot weld datsun sheet metal, it will either blow through or warp.Look how they(datsun) put these trucks together, they did not weld them, they spot welded them, your not going to find any real welding except on the frames. This is the only way your going to be able to weld sheet metal without issues, I put almost a whole kingcab together this way, and I have not had any issues with the welds. BTW, I did all my welding on my 521 kingcab with a shit harbor freight mig welder, did not even use a helmet on over half of it, I just aimed, closed my eyes, pulled the trigger for a second and moved ahead 4 inches, and repeated it over and over thousands of times. i have a sun burn today from using this technique with my shock towers last night...... not adviseable and my eyelids are sun burned..lol Link to comment
TENDRIL Posted February 7, 2013 Author Report Share Posted February 7, 2013 No mask eh!? Link to comment
TENDRIL Posted February 7, 2013 Author Report Share Posted February 7, 2013 I just wasn't sure if you could fill gaps like that with bondo Link to comment
wayno Posted February 7, 2013 Report Share Posted February 7, 2013 i have a subn brn today from using this technique with my shock towers last night...... no adviseable and my eyelids are sun burned..lol I wasn't using gas, so I would lay the gas shield on the metal, aim and pull the trigger for a second, the gas shield blocked most the light. Any other way would take forever spot welding sheet metal, and it's easy to aim if you can actually see. If I weld anything, I use a helmet, like a shock tower, that needs to be welded, not spot welded, but thick metal like that won't warp or blow holes like trying to weld sheet metal, especially 40+ year old sheet metal. Link to comment
jrock4224 Posted February 7, 2013 Report Share Posted February 7, 2013 No mask eh!? no the mask was laying on the welder, auto darkening too......just to much tough guy...not enough womanly common sense ... i use alot of waynos technique though too .. i use the shielding nozzle to block the light too....still not advisable ... and if my wife saw me i woulda got the laundry basket thrown across the garage at me ... but she was at work...yeah.,...let the dumbness ensue Link to comment
jrock4224 Posted February 7, 2013 Report Share Posted February 7, 2013 I just wasn't sure if you could fill gaps like that with bondo pretty sure that was the first pass......the idea is no gaps..... and i only use the no helmet technique for tacking, my brackets were all modular .. so there was a good 20 tacks per side... the few short passes i made were when i grabbed the auto darkening....for waynos roof auto darkening is a must.... u could just go and go and go till u remember u werent supposed to and step back to see your roof now holds water....lol....i was just lazy when i was doing the first one (twice..) and paid the price...my face feels tight today...lol Link to comment
wayno Posted February 7, 2013 Report Share Posted February 7, 2013 I just wasn't sure if you could fill gaps like that with bondo Them spot welds are fairly close together, the point is to weld each spot far enough away from the last one you did to not let the metal get hot and warp, so once I got around the top a few times the welds started getting within an inch of each other, so then I start skipping ahead 4 inches, and by the time I get around the metal is cool enough to touch, so around I go again. I can actually weld between each of the welds again if I wanted to, they would then mostly be touching each other, but I don't see a point, as it will hold the way it is. Link to comment
The Taterhead Posted February 7, 2013 Report Share Posted February 7, 2013 [img=http://images.craigslist.org/3Ke3I83N85He5Mb5J2d25336aa48071ac12ee.jpg] going to be picking these up 2maro for the truck.. 130$ for all 4 cant beat that cant really read the brand and the lady didnt know what they were all she kept saying was they're "custom" dose any one know what brand? Ultra type 5051 maybe? http://www.google.com/search?hl=en&tbo=d&site=webhp&tbm=isch&source=hp&q=ultra+wheels&oq=ultra+wheels&gs_l=mobile-gws-hp.3..5j0j0i24l3.3962.12984.0.13540.13.11.0.2.2.0.422.2595.1j0j3j4j1.9.0.les%3B..0.0...1ac.1.2.mobile-gws-hp.Iy4-xgUpnf0&biw=480&bih=268&sei=tAcUUf3CDImq0AHPu4HwDA#i=22 Link to comment
TENDRIL Posted February 7, 2013 Author Report Share Posted February 7, 2013 Yea that's what the are .. and radium was saying for slight stretch I want to get 185/55/15 for 8 in width? Link to comment
The Taterhead Posted February 7, 2013 Report Share Posted February 7, 2013 Sounds about right. If you know the dimensions of the wheel, I use this to calculate what it would look like. http://www.rimsntires.com/specs.jsp Link to comment
TENDRIL Posted February 9, 2013 Author Report Share Posted February 9, 2013 tried these on rear.. front found a really sweet deal for some 195/55/15 tires all four 280$ and they ended up 15x8s Link to comment
Spoona_Jay21 Posted February 9, 2013 Report Share Posted February 9, 2013 i'm not entirely sure why, but i like this truck. i also like the effort you have put into it even though it isn't the easiest task, hope too see more stuff soon =D Link to comment
TENDRIL Posted February 9, 2013 Author Report Share Posted February 9, 2013 there a stamp that also says 19 or 18mm offset Link to comment
JoeCool Posted February 9, 2013 Report Share Posted February 9, 2013 It's hard to believe the hack jobs some people will do to their own vehicle! Good thing somebody cares enough to fix it right now. It's coming along nicely. Link to comment
