My new purchase
datsun 521 ute
  • Replies 111
OK, so you have a working wiper motor, I left the last one I seen at the wrecking yard, it was really dirty, and there were no discounts that day, I spent a lot of money for that set of 330 gears, but I needed them, so I bought them, but I did not buy anything else, it was to expensive.
We are having a 50 percent off weekend this holiday, I might check the inventories to see what's out there.
Wayno if its cheap and you can verify it works let me know how much to 92880.
The one I have works but i was told it has a short which makes no sense to me at all, there is no mother board or anything in it.
These things were around before anyone thought about mother boards.
I will pull any 521 wiper motor assembly I find in the wrecking yards when I go there, but they are few and far between lately, and I rarely even go now because of how expensive they(PNP) are.
Ok,no problem, I will try to make the 2 I have work.
OK, I just tested one, solid blue is hot/positive, black is ground, blue with white line is slow, blue with red line is fast, connect solid blue to positive, connect black to ground, now touch the blue with white line to ground, it should run slow, then touch the blue with red line wire to ground, it should run fast, the yellow wire doesn't do anything for me as I am not sure how to connect it, it could go to either I suppose, but I don't want to possibly short it out to find out, it likely has something to do with the return.
Sorry but I only have the one extra for all my trucks, so I cannot sell it, I do have two extra 520 motors, but they are only one speed.
I just checked the local inventory, the Sherwood yard has a 67 and a 70, but they have both been there for over 2 months, so it's a waste of time to go there, as neither have anything good on them anymore as I have looked at them both.
As I said, I will look out for a wiper motor for you, but it will likely take time to find one, we used to have people parting them out on craigslist, but I have not seen one being parted out for a few years now.
You get the rubber stuff from phils rotary?
Nice clock, can you invert the mount to put it on the bottom of the dash?
Hi Wayno.
Yeah got the rubbers from him. I am stoked with the clock and it can be inverted so just have to machine up a base plate to sit properly under the dash
So the tub, bonnet, and doors have all been sent to the soda blasters. Cab is almost in bare metal and hope to be completely back to bare today. Colour is going to be Super Jet Black.  More picture of the resto.
Both sills removed.
This is what came out of this sill
When taking repair sections out of the white cab this came out of the sill, measures about 40cm long. So glad I didn't end up using this cab.
New section getting welded on
More progress pictures, some panels and tub back from the blaster.
CA0BD8D5-7F59-4A1A-B7F3-5D16F9EA0D8B_zps
54B984FB-BDED-4F06-8E5F-5D75794401BF_zps
C229701D-8DA9-4A23-B117-262DAF6B270B_zps
The only rust in the tray which I am rather happy about.
C824D545-8201-41A4-9E33-06D7E0F4053D_zps
BD767472-616B-4C69-B0D3-117CEC3E4CBC_zps
AAD2B107-ECAF-4B5C-987A-33A03C88294D_zps
The bonnet was almost near perfect other that a small rust hole under the badge
741D2C47-16B9-482A-912A-C2EDD98A0420_zps
61A96661-144B-4C14-8243-960D96E54E59_zps
96344BA1-487E-4028-B7CC-0AC729EF5C05_zps
Previous repair will be removed and done properly and the only rust in the doors and one repair in progress
BB35B4A3-86D4-4BA8-A6FD-A02CBAC77691_zps
D8D7BEB3-3AC6-4FBB-A33A-C78773F62DC7_zps
6491251A-7B52-4E77-93A7-7FF81B0E59B3_zps
603A9DC7-AD9A-44CF-AB5D-82470D26392E_zps
9737A7C6-8C94-41C3-82F1-6DDF50F9E85A_zps
The original white ute now completely stripped and engine ready to be removed for chassis to be blasted
Anyone wanting any rust repair sections please let me know as this will be getting scrapped. i will let you know if the sections you are after are any good and can send pics.
