mrbigtankers 521
mrbigtanker
  • Replies 7.1k
Looks like its going to work out. Going to try to run the lines close to the valve cover and put the solenoids at the back side. Need to T off the fuel line and run the NOS line from bottle down and along the back so its not seen. Also I want to take the ITB balancer off the fire wall and mount it below the ITB's so its cleaner. It will look different some what.
  • Like 4
Started the lines and I must say that I can do them pretty good. I will take pics once it's done,the only problem I had was first my flare tool is a pile of shit so I fixed that but now the new one tore a couple ends or ripped them so took a break tonight. Also need to get a better cutting tool.should look good though when done or different some what.
Automotive porn!!
  • Like 3
so looks like I got half of it done, will try to make it as straight as possible. The only problem is i make a good bend then I go to flare it then it rips, done got to try to try it to grind down and flare again. Stainless steel is to strong for the flaring tools. But the little trick is to heat it up with a torch and make the metal a little more soft to flare with out tear. Stay Tuned
  • Like 4
