72 1200 sedan! Either way, Hello!
baggyspandex
  • Replies 226
You may want to check to see if the residual check valve has been removed from your new brake master cylinder, brake line connection at the rear of the mater cylinder, feeds front brakes. It's a lot easier to check this before it's installed on the car.
http://datsun1200.com/modules/myalbum/photo.php?lid=23167
I have purchased new ones and some have it and some don't, if it's in there, the front brakes will drag- feels like the brakes are always slightly on
Interesting. I did not check for that before installing. The car is stopping fine and doesn't feel like there is any drag so I hopefully I'm good.
It's a connector for cooling an automatic transmission model, not applicable for your 1200. Check the lower tank for damage-cracks??
The brass connectors are fairly soft, probably OK. You can plug then off/cut them off flush with the gland nuts, they may not be in the way of mounting your radiator. You may want to check out a Sentra, in your local parts pick n pull for rubber isolators and mounting brackets for ideas on mounting your radiator.
Assuming I will need to get some different hoses too right? The mechanic took one look at it and didn't believe it would fit, but I said Ratsun and he was like, "oh."
0755BFDF-8195-486A-962A-00D6D6BA121E_zps
I actually have the right top mounts for the radiator but I couldn't find them at the time so I ended up just making some. I did end up getting the correct mounts from the PnP over Memorial day weekend, although I'm going to go with a different radiator for the KA.
  • 4 weeks later...
  • 3 weeks later...
This definitely looks easier to mount, I'd be interested in grabbing this one and donating the Sentra radiator if someone can confirm it will fit.
1994 Sentra 1.6 radiator.
Need to move horn.
Clearance on battery side.
Air Flow restriction.
Ideas on mounting underside, need to have some space between tank and bottom of core support, if not bent-up brackets, 1.5" exhaust tubing tack in place. I didn't get to top tank brackets, waiting for the them to come in from dealership- got factory mounting grommets!
Ready for surgery. Need to remove some of the sheet metal for more air flow.
Base for mounting bottom of new radiator.
Grommets and lower brackets.
Brackets need trimmed-up, mounting holes drilled and then painted.
A look from the passengers side.
And from the drivers side. Still need to get upper mounting bracket figured out. Ordered a couple different ones from the dealer. I will trim off the auto trans connections.
Plus the wiring, plumbing the hoses, cap and reservoir tank. Plus the stuff I forgot!
Core support mounting brackets painted, shortened lower 1200 radiator hose and reused.
New hose and cap.
I went with Pathfinder grommets and brackets- modified the brackets and made spacers under top rail of core support. Still need to mount fan and finish wiring. Might make Blue Lake picnic with Smurf after all...
Basically, spliced two radiator supports into the same radiator core support. 20.5" of the 25.5" of surface width is in the air flow. The white side is the side spliced into the core.
Fan fit nicely.
When with a flex hose, after cutting a couple of other guesses up!
Not much room left on the core support, used 210 overflow bottle with modified mounting bracket. Tested fan in the driveway, turned on and off- I like that part. Took it for a ride tonight on the freeway, fan didn't come on, but true test in in traffic on a hot day.
Thank you for letting me hi-jack this thread, this just one way to do this swap. I am sure there other and better ways to do the same thing. I am going to make to the picnic at Blue Lake with 9 1/2 hours to spare! Now about that roll-bar...
  • 4 weeks later...
  • 3 weeks later...
Car started up sounding like a lawnmower today. I was able to drive it around, but it was shaky and didn't have a lot of power. Any easy things I can check before taking it to the shop?
Spark plug wires (are they all connected well?)
Spark plugs (are they all clean/brown or is one wet/black?)
Distributor cap (any corrosion on the terminals inside it?)
  • 3 weeks later...
So the shaking stopped later that day randomly after stopping by work on the way home. There isn't the shaking or weird guttural noises any longer, but I am still concerned that something isn't right and haven't driven it much. I'm going to spend some time this week on it so hopefully I will have something more to update later. Thanks guys for the help!
After I changed the fuel filter the car has been running and driving without stalling. There is still some smoke upon acceleration and start up, but not as much. Not bad for changing a 3 dollar part.
I worked on swapping the soggy door card over the weekend and pulled a broken spring out of the bottom of the door.
After a little fishing around, I found the other end of the spring still connected to the locking assembly. This is probably the reason my door doesn't fully lock. I went out and found a similar spring and cut it to size, hoping I could blindly replace where it came from, but I ran out of daylight. I looked in the book and found some pictures of the lock assembly, but I can't seem to see exactly where this other spring goes. I would like to avoid removing the whole lock setup for now. Anyone have any thoughts?
Found this picture on datsun1200.com, which I think might be the angle that shows the spring.
If memory serves.....that does look familiar.  You may be able to pull the lock/latch assembly out enough to install the spring but I don't know for sure.
