74 620 V8 AutoX
Cpl620
  • Replies 508
Did some work today. i was on a freakin roll and didnt waste time to take pictures. had to shut down to go see The Hobbit. the end is in sight. god willing, ill start the wiring tomorrow...
bringing this over to keep an eye on it.
Engine: -Seal oil pan -Seal EGR ports -Remove manifold studs -Install cam sensor -Make alternator bracket -Buy/make throttle cable -Plug oil dip -Make oil filter relocation plate -Plug water ports -Buy rad hoses  -buy spark plug leads
Fuel system:
10an to 3/8 hose barb x2
12Mx1.5 3/8 hose barb x2
3/8 fuel line x10'
flush lines
Body/frame: -Tack front end hinges -Weld exhaust brackets -Weld exhaust -Cut bed exhaust/ports -seat brackets -steering wheel bracket -break line flush/seal -fuel pump bracket -tower adapter -mount gas ped - make harness bar/mount harness  -hang flares - make battery tray
Wiring: -engine, starter, running lights, blinkers, head lights, break lights, wipers, horn, fuel pump, board mods, fan
seat bracket...
10478183_821142534598036_650620837115064
so i had a Badass shot of it all together. flares, lip, grill, lights...but that letters in my camera saying "no card" didnt catch my eye. alas, you shall not get any pictures until it is running on the road. but i did start the wiring today....
10885584_823062657739357_594687147261116
  • Like 3
so i got her to crank over tonight. its odd, i cant find a good ground in the cab. i had to run a ground all the way back to the rear towers because i dont want to grind up the paint on the frame. thankfully i tried to turn her over before i bolted and wired it all up. I had to shave down some of the bell housing that was getting in the way of the starter from engaging the ring gear. the alternator bracket took most of the daylight to make, that thign was kicking my ass. and i had to make 3 trips to get the right belt for the alternator since i fitted a KA alternator to it. (only one i had, and new alternators are expensive. plus the stock one runs on a serpentine belt and i dont have any other drives connected.) also got my oil filter relocation all finished. just need to mount it in place.
10801801_824501030928853_235667088451556
10559799_824501047595518_744937640914837
10888531_824501074262182_202367867702155
10806259_824501087595514_479153285237424
10906440_824501104262179_29478356509279310888717_824501120928844_310756674109166
well farmer might be right...i spend about 8 hours trouble shooting and trying to get my megasquirt box to work right today, so i didnt finish the wiring. we'll see what happens tomorrow. im just too tired to deal with it right now...
