datzenmike Posted March 2, 2016 Report Share Posted March 2, 2016 Heat is heat so left heat or right heat doesn't really matter. Just like an upside down sandwich tastes the same. But if you must, the hot water from the head goes through the firewall to the 'water cock' on the side of the heater fo adjusting the heat. From there by a short hose to the front pass side of the core. Ther rear passenger side exits the core, goes through the firewall and across the passenger side of the block and into the lower rad return hose fitting on the timing cover. Hot water is the upper hose and is U shaped to turn inside the firewall and point down into the water cock. Return is straight out from the core underneath. 1 Quote Link to comment
Lockleaf Posted March 2, 2016 Report Share Posted March 2, 2016 That upsidedown sandwich comment made me laugh for some reason. Excellent analogy! Quote Link to comment
