Dog leg 5 speed
goes2fast
Similar but not the same. It's the 63-series but has an L-motor bellhousing on it.
Goes2fast, unless it gets run out of oil (or you don't know how to drive tongue.gif ) it'll likely never need work. They are the largest transmission put behind an A-series. I've been running one for about 7 years and it's held up better than I ever expected.
I think the second gear syncro is starting to go, gets a little finiky when cold. :confused:
  • Replies 58
Try synthetic oil it's 'thinner'. But you do risk oil leaking past old seals. I noticed my 71b was 'easier' to shift when starting off cold. Good thing about the 63A is all the synchros are the same part.
Already has Royal Purple in it. :huh:
Instead of Royal Purple 75W140, try Royal Purple 75W90. Its thinner. Or better yet, replace the worn syncro.
Didn't say I had 75W140 in it, it's 75W90, and that is why I wanted to know what my trans was from, to find parts.
