WTB throwout bearing sleeve
  • Replies 9
13/4 from where to where??I have this one that`s brand new that i thought was for a 77 dogleg but my memory is pretty foggy ...I just slid this on a 4speed 620 trans and it was way to big for shaft .. is dogleg bigger??
Generally the larger diameter the pressure plate the shorter the release housing.
Ignore the labeling of these collars above, it's just for example.
The distance that is important is the one marked 29(mm) on the one on the far left. This is the distance from the clutch fork contact to the actual bearing. It's possible there are collars the same length but with these distances different.
Measurements are in inchs because dial can`t be zero-ed and i cant find vernier clampers...sorry if all this doesn`t help
Again disregard dial numbers
Thanks for taking the time to measure it up but that one won't work for me. It looks to be similar to the one for the 200sx. I just found a timken on eBay that had all its dimensions listed and it looks like it will work. So untill further notice I won't be needing another one.
