SR20DETdatsun510 Posted November 9, 2011 Report Share Posted November 9, 2011 I am planning a rebuild of my SR20DET motor set over this winter and want to document it. I am currently amassing parts needed for the re-build (and some just because) Not going too crazy but I do want a solid runner. A little history on this car..... First off, I got beat up on the price when I first bought this car in 2008. Being a slight noob, I did not pay attention to the things I should have. But I've learned a massive amount in the 4 time that I've owned it. This car was a mess when I first got it. To give you an example, the r160 subi LSD diff blew 1 day after I got it. Sheared every ring gear bolt head right off. The fab for the swap was about the only thing done right on this car. It's been a California Car all it’s life and has little to no rust! The previous owner in L.A. cut so many corners and did some stupid back yard shit to it but she is my baby now and she's gonna get treated right. I rescued her from a hack and it will just take some time to go through it all. (This list will change over time)CHASSIS:APEXi Power FC with custom unused wire delete (By Jordan Innovations)BMW E32 HIDS2002 tii BMW Flag Mirrors1968 Grill w/ 68 JDM emblem1969 Metal C Pillar Vents Custom Datsun Sill Plates done in Texiluim Aluminated Carbon Fiber (Silver) (by Pare' Composites) S.E.V. Marchal 810 Yellow Fogs 2.5 Anniversary BadgeBRAKES: Front 4 pot Calipers (Jaguar)Rear 2 pot Wilwood Brakes (I also have the fronts but like the Brembo's for now)Brembo rotorsSS Brake lines throughout SUSPENSION:Techno Toy Tuning Adjustable Tension Rod. Datsport steering box brace support Front Ground Control Coilovers on 280z strutsRear QA1 Coilovers (QA1 Carrera - TSR)Perrin 22mm Rear sway bar w/ custom sunken spherical end-linksCustom slotted rear cross member w/ 3.5 exhaust hole.All poly bushings throughoutINTERIOR: Auto Meter 4378 Full Sweep Ultra-Lite WidebandAuto Meter Full Sweep Ultra-Lite Fuel GaugeAuto Meter Full Sweep Ultra-Lite Oil Pressure GaugeAuto Meter Full Sweep Ultra-Lite Oil Temp Gauge Auto Meter Full Sweep Ultra-Lite Water Temp GaugeAuto Meter Full Sweep Ultra-Lite Volts GaugeAuto Meter Full Sweep Ultra-Lite Tach GaugeAuto Meter Full Sweep Ultra-Lite Fuel GaugeAuto Meter Full Sweep Ultra-Lite MPH GaugeAuto Meter Full Sweep Ultra-Lite Boost GaugeSilvia Shift Knob and Trunk LockRecaro Evo 8 seats (Want to replaced these w/ some Bride Vorga HL’s in Black Graduation or Vorga Japan Series.) (drool)Personal 1979 Special Edition Monza Steering WheelCustom black Interior with black suede roof liner3 Pod Center Radio Bezel from ___SAFETY: Custom 4 point Roll Cage w/removable diagonal and hard Harness Bar Powder Coated Wrinkle Red (by Blain Fabrication) Custom reinforced roll cage mounting points (1/4" THK main stay landing pads tied into main body w/eye bolt locations for harness. Same with rear mounting points) (by Blaine Fabrication) Sparco 3” 4 point Cam Harness’ FUEL: Custom SS hard fuel lines Stock OEM FPR (Aeromotive Mini FPR) 850cc Sard Injectors All Earls/Russell fittings and hoses Surge Tank Setup Walbro 255 Intank Fuel Pump Bosche 044 Inline Fuel Pump Billet Fuel Pump Bracket ELECTRICAL: Optima Yellow Battery relocated to trunk NGK BKR8EIX Iridium Spark Plugs (+2 cold levels) Custom Mil-spec wiring and Sleeving from head to toe (By Jordan Innovations) Mil-spec bulkhead connectors on the firewall (By Jordan Innovations) MOTOR: Custom Blue Powder Coated Engine Braces BLOCK: (Built By Mazworx) Brian Crower Forged Billet Steel 91mm Stroker Crank Brian Crower Forged I Beam Rods (Upgraded) (WPC Treated) Heavy Duty Wrist Pins and Clips (WPC Treated) JE Forged Aluminum Pistons with Crown and Skirt Coating (Custom Machined for Oiler Clearance) JE Heavy Duty Ring Set Darton Sleeves Greddy Extended Oil Pan Greddy Pulleys (Blue) ATi Damper Power Enterprise Super V-Belt Reground Cams (HKS 264 IN/EX) GTiR 5 Hole Calico Coated Bearings Oil Grooves Machined into Race Mazworx Main Stud Kit Mazworx Machined Oil Skirt for Stud Clearance JDM Sard Magnetic Oil Filter HEAD: (Rebuilt By Mazworx) HKS 264 Cams IN/EX New OEM Rocker Arms Custom Dual Guide Conversion HKS Valve Springs HKS TI Valve Spring Retainers SI Stainless IN/EX Valves (http://www.sivalves.com/) New VVT Sprocket JDM Weld Coilpack Cover (also have CF one too) JDM ARC Coilpack Cover JDM ORIGIN Coilpack Cover Mazworx 90mm Metal Head Gasket Mazworx Custom Stepped Decking Mazworx Head Stud Kit Custom Blue Powder Coated VC with Mazworx Custom Engraving TURBO SETUP: S14 SR20DET Blacktop with VVT GT28 Garret Turbo Blitz V-mount Intercooler 3” In and Out Piping Synapse Synchronic BOV (open to atmosphere) Force 10-15psi Re-buildable Internal Wastegate Actuator Blitz ID electronic Boost Controller Blitz FATT Turbo timer INTAKE / EXHAUST: 60mm Bore Custom Primera Throttle body Z32 MAF Custom Aluminum Pie Cut Intake Tube HKS Limited Edition Mushroom Intake Greddy Intake Plenum Custom 3" down pipe and Exhaust all the way through (even more custom ex system to come) Apexi N1 Exhaust JDM Moonface Easy Throttle Pulley DRIVETRAIN: SR20 S14 5 Speed Tranny R200 Diff Nismo 2 way clutch pack LSD Wolf Creek Racing CV's (custom safety wired) Z31 Finned Diff Cover Exedy clutch (Blitz Dual Plate Clutch) Datsport Mustache Bar with Poly Bushings WHEELS: Extended lug studs Volk Formula Lugs Kics Neo R26 Lugs 15X7.5/8 4X114.3 Hoshino Impul Pro Mesh Wheels (Also have other sets) SERVICES: Mazworx Degreed Cams Mazworx Polished and Re-balanced Crank Mazworx Oil Groove for 5 hole GTiR BearingsMuch more details and still more to go………Had it Dyno'd and Tuned to a conservative 250HP with old motor but expect over 350 with current setup.Well, Here are some pics of my ride as it sits now....POSTED UPDATESPost #02 - THE CLEAN UP (pics) 11/10/11Post #03 - A FEW PROCUREMENTS (pics) 11/10/11Post #04 - A FEW TSR PARTS (pics) 11/11/11Post #36 - ARC Coil Pack Cover (pics) 11/15/11Post #55 - Spung Blitz Twin Disc Active Clutch (pics) 12/19/11Post #58 - Picked up an S14 short Block for rework (pics) 1/10/12Post #60 - Decision Update, I'm goin' with a stroked SR23DET 1/10/12Post #66 - Got my Stroker Kit (pics) 2/20/12Post #75 - New Rocker Arms (pic) 2/27/12Post #81 - All motor stuff packed up and ready to go! 3/05/12Post #82 - Engine Bay Over View (pics) 3/07/12Post #94 - uShip Quote 3/09/12Post #106 - Started tearing down engine for removal. Picked up the Paint for the Engine Bay (pics) 4/06/12Post #107 - Picked up my SUrge tank. (pics) 4/10/12Post #108 - Recieved first pics of my Motor from Mazworx. The Cleaned Block. (pics) 4/11/12Post #110 - Motor removed. Engine Bay Assesment. (pics) 4/12/12Post #115 - Polished up my Intercooler (pics) 4/14/12Post #123 - Polished up my Grill, eyebrows, brake master cylinder and SR water neck. (pics) 4/15/12SO MANY MORE UPDATES. Just got lazy. Lmao Quote Link to comment
SR20DETdatsun510 Posted November 9, 2011 Author Report Share Posted November 9, 2011 Ok, Frst of all, I have to clear some space to do the engine build and swap. Started by Cleaning and organizing my garage..... (sorry for the crappy cell pics) BEFORE: AFTER: Included a small Work Bench I still have some organizing and cleaning to do but got the shelves up. I hope there will be enough room to do the build with my 510 in the garage. I only have half of the garage available. It will be tight but it's do-able... Quote Link to comment
SR20DETdatsun510 Posted November 9, 2011 Author Report Share Posted November 9, 2011 Amassing parts.... New Tranny Mount (stock photo) (installed already) All new Timing Stuff (and a few other things) Fully Built Head. All new components. 1 Quote Link to comment
SR20DETdatsun510 Posted November 9, 2011 Author Report Share Posted November 9, 2011 I needed these real bad. Old QA1's were getting hashed and needed a rebuild. Got these for a great deal so I'll have the others re-built at my leisure... Black Anodized custom valved QA1 Carerra Coilovers with Hyperco springs and poly bushings built by TSR. New Ron Davis/TSR Radiator with twin SPAL fans and custom bracketry. NICE! A very important aspect of my build; the right radiator to keep everything cool. Quote Link to comment
SR20DETdatsun510 Posted November 9, 2011 Author Report Share Posted November 9, 2011 Reserved Quote Link to comment
SR20DETdatsun510 Posted November 9, 2011 Author Report Share Posted November 9, 2011 1 Quote Link to comment
SR20DETdatsun510 Posted November 9, 2011 Author Report Share Posted November 9, 2011 Quote Link to comment
SR20DETdatsun510 Posted November 9, 2011 Author Report Share Posted November 9, 2011 Ready to pull motor.......... Quote Link to comment
SR20DETdatsun510 Posted November 9, 2011 Author Report Share Posted November 9, 2011 Candy for the "Bay"be.... lol Quote Link to comment
SR20DETdatsun510 Posted November 9, 2011 Author Report Share Posted November 9, 2011 Some more polished goodness! Quote Link to comment
dennis Posted November 9, 2011 Report Share Posted November 9, 2011 LOL, not reserved 1 Quote Link to comment
blueghost510 Posted November 9, 2011 Report Share Posted November 9, 2011 That is the first 510 you stepped into as a "noob"? Damn I did it ALL wrong. I bought my first one 15 years ago in Sacramento for 500 bucks. The headgasket blew on the way home. My buddy showed up with his mothers Chevy Caprice and *pushed* my 510 home 20 miles on the highway! LOL...... That is a really nice 510! Quote Link to comment
SR20DETdatsun510 Posted November 9, 2011 Author Report Share Posted November 9, 2011 That is the first 510 you stepped into as a "noob"? Damn I did it ALL wrong. I bought my first one 15 years ago in Sacramento for 500 bucks. The headgasket blew on the way home. My buddy showed up with his mothers Chevy Caprice and *pushed* my 510 home 20 miles on the highway! LOL...... That is a really nice 510! Thanks man, believe me, it has taken ALLOT to get it where it is today. Practically the only thing not gone through on this thing is the motor. (but that's about to change) One of the biggest WTF's done to this car by the previous owner was he did a Maxima Rear Brake setup. But instead of making brackets for the calipers, he welded the calipers to the control arms.... Ya, I know, a huge WTF right! Not to mention he lied and totally misrepresented the car. Fuck, he even lied about the rear seat belts. He said they were stuffed under the rear seat. I didn't check because it had a roll bar and was a hassle to get the rear sear out to check. Besides, who the fuck lies about something as little as that???? Again, Thanks allot for the compliments Quote Link to comment
Topher88 Posted November 10, 2011 Report Share Posted November 10, 2011 Sweet dude. some day i hope mine looks this clean. Quote Link to comment
the510keeper Posted November 10, 2011 Report Share Posted November 10, 2011 i should make reservations to. looks good bud Quote Link to comment
SR20DETdatsun510 Posted November 10, 2011 Author Report Share Posted November 10, 2011 i should make reservations to. looks good bud Ya, specially when your gonna shave, fill and shoot my bay for me.... hahahaha Only if you were closer! :( Quote Link to comment
SR20DETdatsun510 Posted November 10, 2011 Author Report Share Posted November 10, 2011 Sweet dude. some day i hope mine looks this clean. Keep at it and it will. Believe! Quote Link to comment
jdmdime Posted November 10, 2011 Report Share Posted November 10, 2011 I like the color. Quote Link to comment
GUS-GUS Posted November 10, 2011 Report Share Posted November 10, 2011 Can't wait to see it next year Johnny!! Let me know if you need a hand as I'm always in the need of learning new things..... oh and I still have your wheels in mind especially now that I can help you fund your build. :P Quote Link to comment
SR20DETdatsun510 Posted November 10, 2011 Author Report Share Posted November 10, 2011 Can't wait to see it next year Johnny!! Let me know if you need a hand as I'm always in the need of learning new things..... oh and I still have your wheels in mind especially now that I can help you fund your build. :P Gus Bro, you are too cool mang! I will def need a hand with a few things. Quote Link to comment
SR20DETdatsun510 Posted November 10, 2011 Author Report Share Posted November 10, 2011 I like the color. Thanks. Me too, I love it. When I repaint, I am going to paint it the same color. I am planning on painting the bay the same color too. Going to paint the bottom bay rails and the front and back of the grill area all satin or flat black and then the rest of the bay the same blue color. Gonna look NICE! Quote Link to comment
SR20DETdatsun510 Posted November 11, 2011 Author Report Share Posted November 11, 2011 Oooo Weee, Post #2, #3 and #4 updates........ Quote Link to comment
